Philipp
(Philipp)
November 21, 2017, 10:51am
1
I am currently upgrade my JSR223 Python rule to Groovey and need some support to setup my IDE correctly. Since my editor offers code completion, I would like to refer the Eclipse Smarthome code to use this feature. Therefore, I downloaded the last source code version and put it in /conf/lib/esh. After that, I marked this folder as “Source Folder” in my IDE. Unfortunately, it only works for some of the classes. I guess the issue is releated the namespace and the file location. If I open an ESH class, I can see some warning regarding the class path.
Can someone tell me which folder of the ESH source code I need to mark as “Source Folder” so that ESH packages are appearing in the namespace scope?
I am using the IntelliJ IDEA IDE by the way but the problem should be the same for all editor.
Philipp
(Philipp)
November 22, 2017, 12:55am
2
I found a suitable solution
Download ESH Libraries via Maven (pom.xml attached)
Add the maven repositories as external library to your IDE
Now you can use the code completion for ESH classes.
pom.xml
<?xml version="1.0" encoding="UTF-8"?>
<project xmlns="http://maven.apache.org/POM/4.0.0"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 http://maven.apache.org/xsd/maven-4.0.0.xsd">
<modelVersion>4.0.0</modelVersion>
<groupId>dev.openhab</groupId>
<artifactId>openhab</artifactId>
<version>1.0-SNAPSHOT</version>
<repositories>
<repository>
<id>Eclipse</id>
<name>Eclipse</name>
<url>https://repo.eclipse.org/content/groups/releases/</url>
</repository>
</repositories>
<dependencies>
<dependency>
<groupId>org.eclipse.smarthome.automation</groupId>
<artifactId>org.eclipse.smarthome.automation.api</artifactId>
<version>0.9.0.b6</version>
</dependency>
<dependency>
<artifactId>org.eclipse.smarthome.automation.module.script</artifactId>
</dependency>
<dependency>
<artifactId>org.eclipse.smarthome.automation.sample.java.demo</artifactId>
</dependency>
<dependency>
<groupId>org.eclipse.smarthome.config</groupId>
<artifactId>org.eclipse.smarthome.config.core</artifactId>
</dependency>
<dependency>
<groupId>org.osgi</groupId>
<artifactId>org.osgi.service.component</artifactId>
<version>1.3.0</version>
<scope>provided</scope>
</dependency>
<dependency>
<groupId>org.slf4j</groupId>
<artifactId>slf4j-api</artifactId>
<version>1.7.25</version>
</dependency>
<dependency>
<artifactId>org.eclipse.smarthome.automation.module.timer</artifactId>
</dependency>
<dependency>
<artifactId>org.eclipse.smarthome.automation.providers</artifactId>
</dependency>
<dependency>
<artifactId>org.eclipse.smarthome.automation.module.script.rulesupport</artifactId>
</dependency>
<dependency>
<artifactId>org.eclipse.smarthome.automation.module.core</artifactId>
</dependency>
<dependency>
<groupId>org.eclipse.smarthome.model</groupId>
<artifactId>org.eclipse.smarthome.model.script</artifactId>
</dependency>
</dependencies>
</project>
