well, I tried to include my new Shelly I3 into OpenHAB3, as I did for several other Shelly 1 and 2.5. Primarly I like to use it to controll rollershutters.
So I’d like to identify the S/SS/SSS/LS/SL pushes. Therefore I made a new thing and a string channel. As item I tried this piece of code:
It returns the whole event string that is published by the I3:
{"event":"S","event_cnt":14}
I see the S for the short push I did, but how can I get only the letter so I can use it in a rule?
Unfortunately I am quite lost and I am looking forward to any hint from you, guys!
Hi Chris,
I opend the advanced option in the channel config and yes, I found the section “Transform Value”
For “Incoming Value Transformation” I put in
JSONPATH:$.device.status.event
But it still shows:
Do you have any example how to make the right transformation? Do I have to make the JSONPATH in my .items file?
