[SOLVED] Simple rule with 2 items triggers only first action
here the rule
rule "Bewegung_Terrasse an"
Item Bewegung_Terrasse1 changed to ON
	if (Helligkeit2 == ON)
	sendCommand(Light_EG_Terrasse_Markise,ON)
	sendCommand(Light_EG_Terrasse_Mauer,ON)
if it gets triggered only the first item is updated (i swapped them to prove it), tried with brackets but then nothing is turned on :frowning:
any idea ?
thanks
Thomas
Ok, what is the behaviour you want to achieve?
First error, you failed to use .state
Second, you need to use {} after an if statement
Third, you should use the .sendCommand(command) method syntax instead of the action syntax sendCommand(item, command)
    if (Helligkeit2.state == ON) {
        Light_EG_Terrasse_Markise.sendCommand(ON)
        Light_EG_Terrasse_Mauer.sendCommand(ON)
Thanks again !
Thomas
It’s ok.
Just make sure you understand the errors that you made.
Copy the changes, don’t copy and paste. Writing it yourself will make you learn it.
Please tick the solution, thanks
