I got everything up running. But I seem to have a problem with my Sonoff RF Bridge 433mhz and JSONPATH.
This is the openhab log when the RF Bride receives at key (RfReceived):
2019-09-12 11:09:04.071 [WARN ] [l.generic.ChannelStateTransformation] - Executing the JSONPATH-transformation failed: Invalid path '$.RfKey1' in '{"RfReceived":{"Sync":8320,"Low":290,"High":820,"Data":"AB7BC2","RfKey":1}}'
2019-09-12 11:09:04.076 [WARN ] [eneric.internal.generic.ChannelState] - Command '{"RfReceived":{"Sync":8320,"Low":290,"High":820,"Data":"AB7BC2","RfKey":1}}' not supported by type 'OnOffValue': No enum constant org.eclipse.smarthome.core.library.types.OnOffType.{"RfReceived":{"Sync":8320,"Low":290,"High":820,"Data":"AB7BC2","RfKey":1}}
2019-09-12 11:09:04.107 [WARN ] [l.generic.ChannelStateTransformation] - Executing the JSONPATH-transformation failed: Invalid path '$.RfKey1' in '{"RfReceived":{"Sync":8320,"Low":290,"High":820,"Data":"AB7BC2","RfKey":1}}'
2019-09-12 11:09:04.110 [WARN ] [eneric.internal.generic.ChannelState] - Command '{"RfReceived":{"Sync":8320,"Low":290,"High":820,"Data":"AB7BC2","RfKey":1}}' not supported by type 'OnOffValue': No enum constant org.eclipse.smarthome.core.library.types.OnOffType.{"RfReceived":{"Sync":8320,"Low":290,"High":820,"Data":"AB7BC2","RfKey":1}}
2019-09-12 11:09:04.117 [WARN ] [l.generic.ChannelStateTransformation] - Executing the JSONPATH-transformation failed: Invalid path '$.RfKey1' in '{"RfReceived":{"Sync":8320,"Low":290,"High":820,"Data":"AB7BC2","RfKey":1}}'
2019-09-12 11:09:04.123 [WARN ] [eneric.internal.generic.ChannelState] - Command '{"RfReceived":{"Sync":8320,"Low":290,"High":820,"Data":"AB7BC2","RfKey":1}}' not supported by type 'OnOffValue': No enum constant org.eclipse.smarthome.core.library.types.OnOffType.{"RfReceived":{"Sync":8320,"Low":290,"High":820,"Data":"AB7BC2","RfKey":1}}
2019-09-12 11:09:04.144 [WARN ] [l.generic.ChannelStateTransformation] - Executing the JSONPATH-transformation failed: Invalid path '$.RfKey1' in '{"RfReceived":{"Sync":8320,"Low":290,"High":820,"Data":"AB7BC2","RfKey":1}}'
2019-09-12 11:09:04.152 [WARN ] [eneric.internal.generic.ChannelState] - Command '{"RfReceived":{"Sync":8320,"Low":290,"High":820,"Data":"AB7BC2","RfKey":1}}' not supported by type 'OnOffValue': No enum constant org.eclipse.smarthome.core.library.types.OnOffType.{"RfReceived":{"Sync":8320,"Low":290,"High":820,"Data":"AB7BC2","RfKey":1}}
My thing file looks like the above:
Bridge mqtt:broker:mosquitto "mosquitto" [ host="10.4.28.200", port=1883, secure=false, username="openhabian", password="openhab" ]
Thing topic sonoffpow1 "Sonoff Pow1 " @ "A Room" {
Channels:
Type string : reachable "Reachable" [ stateTopic="tele/sonoffPOW1/LWT" ]
Type switch : power "Power" [ stateTopic="stat/sonoffPOW1/POWER", commandTopic="cmnd/sonoffPOW1/POWER" ]
Type number : powerload "Power load" [ stateTopic="tele/sonoffPOW1/SENSOR", transformationPattern="JSONPATH:$.ENERGY.Power"]
Type number : voltage "Line voltage" [ stateTopic="tele/sonoffPOW1/SENSOR", transformationPattern="JSONPATH:$.ENERGY.Voltage"]
Type number : current "Line current" [ stateTopic="tele/sonoffPOW1/SENSOR", transformationPattern="JSONPATH:$.ENERGY.Current"]
Type number : total "Total energy today" [ stateTopic="tele/sonoffPOW1/SENSOR", transformationPattern="JSONPATH:$.ENERGY.Today"]
Type number : totalyest "Total energy yesterday" [ stateTopic="tele/sonoffPOW1/SENSOR", transformationPattern="JSONPATH:$.ENERGY.Yesterday"]
Type number : totalall "Total energy alltime" [ stateTopic="tele/sonoffPOW1/SENSOR", transformationPattern="JSONPATH:$.ENERGY.Total"]
Type number : rssi "WiFi Signal Strength" [ stateTopic="tele/sonoffPOW1/STATE", transformationPattern="JSONPATH:$.Wifi.RSSI"]
Thing topic sonoffbm "RF Bridge" @ "second Room" {
Channels:
Type string : reachable "Reachable" [ stateTopic="tele/sonoffbm/LWT" ]
Type string : recieveddata "Received Data" [ stateTopic="tele/sonoffbm/RESULT", transformationPattern="JSONPATH:$.RfReceived.Data"]
Type string : recievedsync "Received Sync" [ stateTopic="tele/sonoffbm/RESULT", transformationPattern="JSONPATH:$.RfReceived.Sync"]
Type string : recievedlow "Received Low" [ stateTopic="tele/sonoffbm/RESULT", transformationPattern="JSONPATH:$.RfReceived.Low"]
Type string : recievedhigh "Received High" [ stateTopic="tele/sonoffbm/RESULT", transformationPattern="JSONPATH:$.RfReceived.High"]
Type string : recievedrfkey "Received RfKey" [ stateTopic="tele/sonoffbm/RESULT", transformationPattern="JSONPATH:$.RfReceived.RfKey"]
Type switch : button1 "Button 1" [ stateTopic="tele/sonoffbm/RESULT", commandTopic="cmnd/sonoffbm/RFKEY1", transformationPattern="JSONPATH:$.RfKey1" ]
Type switch : button2 "Button 2" [ stateTopic="tele/sonoffbm/RESULT", commandTopic="cmnd/sonoffbm/RFKEY2", transformationPattern="JSONPATH:$.RfKey1" ]
Type switch : button3 "Button 3" [ stateTopic="tele/sonoffbm/RESULT", commandTopic="cmnd/sonoffbm/RFKEY3", transformationPattern="JSONPATH:$.RfKey1" ]
Type switch : button4 "Button 4" [ stateTopic="tele/sonoffbm/RESULT", commandTopic="cmnd/sonoffbm/RFKEY4", transformationPattern="JSONPATH:$.RfKey1" ]
Type number : rssi "WiFi Signal Strength" [ stateTopic="tele/sonoffbm/STATE", transformationPattern="JSONPATH:$.Wifi.RSSI"]
It´s ONLY the RF Bridge which returns this error.
