Hi All, a little of the topic for OH but i am sure someone here can help me
I am running tasmotha on my sonoff basic R1 , i am using GPIO 14 for a rocker switch and its working great, this sonoff is so close to the door that i must use it for door sensor
do i have any more GPIOs that i can configure as a door sensor
i know some of the pins have some resistors and some don’t , and this is where it gets tricky for me, I don’t really understand why I need them so if someone can help it will be great
i was thinking maybe using the LED indicator that i don’t really see because the sonoff is fixed in the light
or maybe the toggle that i dont really use, but then the sonoff will be bricked?
Ok sure so i will do …
“SerialLog 0” on console
then i will connect the sensor to GPIO 3
and configre this as a switch ?
say what are the numbers on the side of the switch
relay1 relay2 relay3 …was never able to understand this
You can have up to 8 switches directly linked to 8 relays
To change the link between the switch and the relay you have get get reading on tasmota
docs. look for swichmode and switchtopic
