LarsB
(Lars)
November 3, 2018, 3:59pm
1
Hi
Im trying to set up Sonos in openHAB, and I’m using Spotify (premium) as music source
Things file (udn part anonymised)
Thing sonos:PLAY1:living [ udn="RINCON_xxxxxxxxxxxxxx400", refresh=60, notificationVolume=25] //Left speaker
Thing sonos:PLAY1:living [ udn="RINCON_yyyyyyyyyyyyyy400", refresh=60, notificationVolume=25] //Right speaker
sonos.item file
Player Sonos_Controller "Controller" (gSonos) {channel="sonos:PLAY1:living:control"}
Dimmer Sonos_Volume "Volume [%.1f %%]" <soundvolume> (gSonos) {channel="sonos:PLAY1:living:volume"}
Switch Sonos_Mute "Mute" <soundvolume_mute> (gSonos) {channel="sonos:PLAY1:living:mute"}
Switch Sonos_LED "LED" <switch> (gSonos) {channel="sonos:PLAY1:living:led"}
String Sonos_CurrentTrack "Now playing [%s]" <text> (gSonos) {channel="sonos:PLAY1:living:currenttrack"}
String Sonos_State "Status [%s]" <text> (gSonos) {channel="sonos:PLAY1:living:state"}
String Sonos_CurrentAlbumartUrl "AlbumCoverUrl [%s]" (gSonos) {channel="sonos:PLAY1:living:currentcoverarturl"}
Image Sonos_CurrentAlbumArt "AlbumCover [%s]" (gSonos) {channel="sonos:PLAY1:living:currentcoverart"}
sonos.sitemap file
sitemap sonos label="Sonos"
Frame label="Sonos" {
Default item=Sonos_Controller
Slider item=Sonos_Volume
Switch item=Sonos_Mute
Switch item=Sonos_LED
Text item=Sonos_CurrentTrack
Text item=Sonos_State
Image item=Sonos_CurrentAlbumartUrl
Everything is working just fine (Volume up/down, play, Current Track etc.) execpt from AlbumArt
I guess I’m missing something, but cannot figure ou what I’m missing ??
I’m not seeing any errors in the openhab.log, but I do see this warning when I open the Sonos.Sitemap
2018-11-03 16:40:07.761 [WARN ] [eclipse.jetty.servlet.ServletHandler] - /proxy
Does anyone have any ideas what I have done wrong/ am missing?
/Lars
jwiseman
(Mr. Wiseman (OH 4.2 Snapshot on Pi4))
November 3, 2018, 4:19pm
2
Hey Lars,
Here’s my stuff for Sonos and I play Spotify all day long and everything works.
Things:
Thing sonos:PLAY1:LivingRoom [ udn="RINCON_7828CAAabc123", refresh=60, notificationVolume=40 ]
Items:
Player Sonos_LivingRoom_Controller "Controller" { channel="sonos:PLAY1:LivingRoom:control" }
Dimmer Sonos_LivingRoom_Volume "Volume [%.1f %%]" <soundvolume> (Sonos) { channel="sonos:PLAY1:LivingRoom:volume" }
Switch Sonos_LivingRoom_Mute "Mute" <soundvolume_mute> (Sonos) { channel="sonos:PLAY1:LivingRoom:mute" }
String Sonos_LivingRoom_CurrentTrack "Now playing [%s]" (Sonos) { channel="sonos:PLAY1:LivingRoom:currenttrack" }
String Sonos_LivingRoom_CurrentAlbumCoverArtURL "URL [%s]" (Sonos) { channel="sonos:PLAY1:LivingRoom:currentalbumarturl" }
Switch Sonos_LivingRoomPlayOrPause "LivingRoom [MAP(sonos_play_pause.map):%s]" (Sonos) [ "Switchable" ]
Switch Sonos_LivingRoom_StandAlone "Stand Alone" { channel="sonos:PLAY1:LivingRoom:standalone" }
String Sonos_LivingRoom_ZoneGroupID "Zone Group ID [%s]" { channel="sonos:PLAY1:LivingRoom:zonegroupid" }
String Sonos_LivingRoom_ZoneName "Zone Name [%s]" { channel="sonos:PLAY1:LivingRoom:zonename" }
String Sonos_LivingRoom_Coordinator "Coordinator [%s]" { channel="sonos:PLAY1:LivingRoom:coordinator" }
String Sonos_LivingRoom_Remove "Remove [%s]" { channel="sonos:PLAY1:LivingRoom:remove" }
Switch Sonos_LivingRoom_LocalCoordinator "Local Coordinator" { channel="sonos:PLAY1:LivingRoom:localcoordinator" }
Switch Sonos_LivingRoom_Stop "Stop Player" { channel="sonos:PLAY1:LivingRoom:stop", autoupdate="false" }
Switch Sonos_LivingRoom_ClearQueue "Clear Queue" { channel="sonos:PLAY1:LivingRoom:clearqueue" }
Sitemap:
Frame label="Sonos Living Room" {
Default item=Sonos_LivingRoom_Controller
Slider item=Sonos_LivingRoom_Volume
Switch item=Sonos_LivingRoom_Mute
Text item=Sonos_LivingRoom_CurrentTrack
Text item=Sonos_LivingRoom_CurrentAlbumCoverArtURL label=""
Switch item=Sonos_LivingRoom_StandAlone
Text item=Sonos_LivingRoom_ZoneGroupID
Text item=Sonos_LivingRoom_ZoneName
Text item=Sonos_LivingRoom_Coordinator
Text item=Sonos_LivingRoom_Remove
Switch item=Sonos_LivingRoom_LocalCoordinator
Switch item=Sonos_LivingRoom_Stop
Switch item=Sonos_LivingRoom_ClearQueue
Hope this helps . . .
Best, Jay
MickUrsell
(Mick Ursell)
November 3, 2018, 4:31pm
3
Lars,
I use the Plex binding and had similar issues with displaying the cover art.
One thing that might be worth trying is change your sonos.item file to remove the formatting for the cover art url
Try this
String Sonos_CurrentAlbumartUrl "AlbumCoverUrl" (gSonos) {channel="sonos:PLAY1:living:currentcoverarturl"}
This could help as you want to resolve the url and not display it.
Mick
LarsB
(Lars)
November 3, 2018, 7:27pm
4
Hi both
Thank you both, for pointing me in the right direction
The issue was me - I had made a typo
The description says “Cover art URL of the album currently playing” but the Channel Type ID is “currentalbumarturl” (I had typed “currentcoverarturl”)
Everything is working now
/Lars
