[SOLVED] Splitting Strings in Rules
I would also like to split a string within a rule.
My Powermax binding gives a status from the ITEM here.
String Powermax_LCD “System LCD Display [%s]” (GPowerMax) {powermax=“partition_status”}
this returns a value like.
Disarmed, Ready, Violated (Motion) in Zone 2
Wanted to split this into 3 Items
String AlarmLCD1 “System LCD Line 1” (GPowerMax)
String AlarmLCD2 “System LCD Line 2” (GPowerMax)
String AlarmLCD3 “System LCD Line 3” (GPowerMax)
I have tried using the following within a rule.
val LCDLines = Powermax_LCD.state.split(“,”)
postUpdate(AlarmLCD1, LCDLines[0])
but this generates errors.
What is the correct way to split a string within a rule.
Thanks.
Can this help you a little bit?
rule "send notification bei eingehendem Anruf"
		Item Call_Incoming received update
		if (Call_Incoming.state==ON) {
				val tel00 = Call_Incoming_No.state.toString.split(',').get(0)
				val tel01 = Call_Incoming_No.state.toString.split(',').get(1)
				if (tel00=="012345" && tel01=="0987654") {...
The problem is the usage of the array-syntax in a rule, which isn’t possible.
Instead of “LCDLines[0]” use “LCDLines.get(0)”.
That has been written already in the other thread in which you have posted the same question.
