I have implemented several roller shutters as blinds via zwave-Binding which works quite well for moving the shutters UP and DOWN and also STOP works via Paper UI and also via BASIC UI.
item:
works via quite well.
and also works as it should.
now I have created a role to move all Blinds (Roller Shutters) UP, DOWN and STOP
both proposals are working, the “received command UP, DOWN and STOP” for which I have to modify my rules and also the suggestion with the group which is the more smart version. Unfortunately with group only “Slider” is working, I can not use the Blinder (Rollershutter) buttons:
Any idee whats wrong or is it not possible via Groups to make use of the “Rolleshutter” buttons:
thank you very much for the coding. This works quite well and the group concept is very smart also for “Switches”, “Sliders” and not only for “Groups”, concerning witch I was not aware of. This is exactly what I was looking for. But I think I identified an issue with the openHab-App on iPhone, which does not displays these buttons. Via browser on the iPhone they appear on and do what they should do. Also on the Android-App the buttons appear an work. Do you know to whom this information should be forwarded to so that this “bug” could be corrected?
