- Platform information:
- Hardware: Synology/Docker
- OS: Synology/Docker
- Java Runtime Environment: (whichever comes with the Docker image)
- openHAB version: openHAB 2.5.0 Release Build (latest Docker image)
I have defined all my MQTT things and items exclusively with .things and .items files and did nothing in PaperUI. However, if I view the command topic in PaperUI, it shows the wrong topic, and, judged by watching all MQTT traffic with MQTT.fx, the command gets really sent to that wrong topic!
This is displayed in PaperUI. I marked the topic discrepancy in red:
And this is the relevant portion of my things file. You’ll see that the commandTopic is defined as zwave/DevoloThermostat05/thermostat_setpoint/heating_1/set
while the display in PaperUI is zwave/DevoloThermostat01/thermostat_setpoint/heating_1/set
Bridge mqtt:broker:mosquitto "Mosquitto MQTT Broker" [ host="homeserver", secure=false, clientID="openHAB_docker" ]
Thing topic DevoloThermostat01 "Devolo Home Control Radiator Thermostat (Bad)" @ "Bad" {
Channels:
Type number : temperature "Temperatur" [stateTopic="zwave/DevoloThermostat01/sensor_multilevel/unknown",
transformationPattern="JSONPATH:$.value"]
Type number : battery "Batterie" [stateTopic="zwave/DevoloThermostat01/battery/battery_level",
Type number : setpoint "Zieltemperatur"[stateTopic="zwave/DevoloThermostat01/thermostat_setpoint/heating_1",
transformationPattern="JSONPATH:$.value",
commandTopic="zwave/DevoloThermostat01/thermostat_setpoint/heating_1/set",
min=10, max=28, step=1]
Type string : status "Status" [stateTopic="zwave/DevoloThermostat01/status",
Thing topic DevoloThermostat05 "Devolo Home Control Radiator Thermostat (Office)" @ "Office" {
Channels:
Type number : temperature "Temperatur" [stateTopic="zwave/DevoloThermostat05/sensor_multilevel/unknown",
Type number : battery "Batterie" [stateTopic="zwave/DevoloThermostat05/battery/battery_level",
Type number : setpoint "Zieltemperatur"[stateTopic="zwave/DevoloThermostat05/thermostat_setpoint/heating_1",
commandTopic="zwave/DevoloThermostat05/thermostat_setpoint/heating_1/set",
Type string : status "Status" [stateTopic="zwave/DevoloThermostat05/status",
And this is the corresponding part of the .items file:
Number:Temperature
thermostat01_temp_RawSensor
(gRawSensor)
{channel="mqtt:topic:mosquitto:DevoloThermostat01:temperature"}
Number:Temperature
thermostat01_temp "Thermostat Bad [%.1f %unit%]"
<temperatur>
(gPersist,gLastUpdt)
Number:Temperature
thermostat01_setpoint "Zieltemperatur Bad [%.1f %unit%]"
<temperatur>
(gPersist,gSetpoint)
{channel="mqtt:topic:mosquitto:DevoloThermostat01:setpoint"}
Number thermostat01_batt "Batterie [%d %%]"
<battery>
(gPersist,gBattery,gLastUpdt)
{channel="mqtt:topic:mosquitto:DevoloThermostat01:battery"}
DateTime thermostat01_lastUpdt "Last Update [%1$tm/%1$td %1$tH:%1$tM]"
(gPersist)
Number:Temperature
thermostat05_temp_RawSensor
(gRawSensor)
{channel="mqtt:topic:mosquitto:DevoloThermostat05:temperature"}
Number:Temperature
thermostat05_temp "Thermostat BĂĽro [%.1f %unit%]"
<temperatur>
Number
thermostat05_setpoint "Zieltemperatur BĂĽro [%.1f %unit%]"
<temperatur>
{channel="mqtt:topic:mosquitto:DevoloThermostat05:setpoint"}
Number thermostat05_batt "Batterie [%d %%]"
<battery>
{channel="mqtt:topic:mosquitto:DevoloThermostat05:battery"}
DateTime thermostat05_lastUpdt "Last Update [%1$tm/%1$td %1$tH:%1$tM]"
(gPersist)
I left out DevoloThermostat02
… DevoloThermostat04
, but they show the same error, all linking to the command topic of the first.
I don’t know how many times I’ve checked that the numbering of all my things and items is correct. I’ve commentend the things and items out and in, restarted openHAB inbetween and such, but I still wind up with the wrong command topic. A grep search for DevoloThermostat01
in the openHAB folders only found the logs and the .things and .items file, so I have absolutely no idea why this command topic is attached to more than one thing
Is this a bug in the MQTT binding? I have some “tasmotarized” Sonoff switches with a similar numbering scheme, they work fine.
