Have you linked items to all the channels?
Anyhow, as you see and Bruce before you from the other thread, it can be a little tricky getting the battery powered zwave devices working, but I have found them to be rock solid once configured.
Thanks for input! Yes, the channels are all linked. All other battery devices have worked like a charm compared to this SP-816. I’ve now managed to make them useful by configuring them to send an ON/OFF command to a peer node which I in turn can listen to that node’s events. This I configured using the Paper UI so it obviously can talk configuration to the device.
It seems I’m getting closer to solving this. It seems that this device must be included securely for it to be successfully identified by OpenHab. For a Aeotec Z-stick Gen5 that means that it must remain in the USB-port when including and inclusion mode on the Z-stick must be All Devices.
However, one problem still remains… I still get no communication on the channels. What get is this:
2019-11-03 09:47:26.159 [ERROR] [mmandclass.ZWaveSecurityCommandClass] - NODE 34: Error decapsulating security message
java.security.InvalidKeyException: No installed provider supports this key: (null)
at javax.crypto.Cipher.chooseProvider(Cipher.java:892) ~[?:?]
at javax.crypto.Cipher.init(Cipher.java:1248) ~[?:?]
at javax.crypto.Cipher.init(Cipher.java:1185) ~[?:?]
at org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveSecurityCommandClass.generateMAC(ZWaveSecurityCommandClass.java:501) ~[227:org.openhab.binding.zwave:2.5.0.M1]
at org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveSecurityCommandClass.getSecurityMessageDecapsulation(ZWaveSecurityCommandClass.java:303) [227:org.openhab.binding.zwave:2.5.0.M1]
at org.openhab.binding.zwave.internal.protocol.ZWaveNode.processCommand(ZWaveNode.java:1233) [227:org.openhab.binding.zwave:2.5.0.M1]
at org.openhab.binding.zwave.internal.protocol.ZWaveTransactionManager$ZWaveReceiveThread.run(ZWaveTransactionManager.java:485) [227:org.openhab.binding.zwave:2.5.0.M1]
Any ideas on what above means and how to solve it? I get that the key is missing, but why and how to fix it? There’s a network key in the configuration.
