I’ve figured that battery powered z-wave devices can take some time and effort to configure.
Unless you’re aware of
Wakeups
NIF (Network information frame)
it seems as if your Z-wave devices become available to OpenHab at random which can be very frustrating.
Most battery powered devices have a physical button to make it wake up and/or send a NIF.
My problem is, what do you do if you can’t make the device wake up or send a NIF on demand?
Currently I have a device (Nexa SP816 motion detector, which would translate to thing type everspring_sp816_00_000) and last time it woke up was over 24 hours ago. It’s still an unknown device to OpenHab and I wonder if I’m just supposed to wait?
Does it matter if the device is added as a thing or should I only try to add it from the inbox once it has been identified? Is there a possibility to force the identification in some way? Especially since I know what thing type it is?
Assuming there is no “physical button to push”, I think I’d try multiple cycles of “remove battery, wait a couple of minutes, reinstall battery, wait a couple of minutes” on the theory that it will force a wakeup.
Battery devices can be problematic under ZWave, but there’s no real way around this. Battery devices sleep most of their time, and must be woken in order to communicate with them - this isn’t an openHAB issue, it’s just how battery devices work under ZWave.
Why can’t you want it up? Really, I would expect all battery devices to have the ability to be woken up - not just most of them.
According to the docs, this device is woken up by tripple pressing the tamper switch.
I guess you mean - does it matter if it’s added as a thing before it’s identified, or is it better to add it as a thing after it’s identified? It doesn’t really matter - either way you want be able to use it until the system knows that the device is, and what functions it offers.
You can probably force this by using static thing types, but I’m not sure it will really help you as the device still won’t work. It MUST be woken up to allow the binding to configure the device - without this, it can’t be configured, and without configuration, it won’t send reports when it detects motion.
Thanks for great input! The official documentation doesn’t say anything about the wake up command, but I see that the openHab documentation on the device mentions 3 clicks and I’ve found that it works. I still have the problem though, that no matter how many times I wake it up (which I can see on the last woke up time in openHab), it doesn’t seem to transmit the manufacturer information needed to configure the device.
Could it be that some devices doesn’t transmit a NIF? I’ve added POPP and Aeon labs battery devices and no trouble at all with those.
The device is next to the controller.
What roughly am I looking for in the log?
The log looks almost identical for when a successful device discovery happens. Could it be some security related issue? This below stood out, “Unsupported command class” (I figure “application update request” is what I want working)
There is no wakeup message being received - until the device is awake, the binding cannot communicate with the device. If it can’t talk to the device, then it can’t work out what services it supports, or what device type it is.
Please post logs either as attachments/links or use code fences so that it’s more readable (I’ve edited your posts to fix this).
I believe this is the documentation for the device in question? link to pdf document
At the bottom of the last page there is a troubleshooting section that does include instructions on how to manually put the device into inclusion mode which is the same as saying ‘wake up’ the device.
Here is a link to a thread I started a while back about OpenHAB friendly motion sensors. In this thread, you can read about my trials and tribulations getting several brands of battery powered motion sensors working. Some needed woken up numerous times. Feel free to add your review of your sensor to the thread after we get it going
Hi! Thanks for all great input and thanks for fixing the post.
I’ve gone through the logs and looked more in detail. From what I can understand from the logs, the node does wake up but when it’s asked for information the controller gets nothing back. The log below is heavily pruned so I hope I got in the relevant lines. Could it be that it needs to be securely included somehow? Or would there be any other reasons why it doesn’t respond with any data (see last log line)?
16:21:29.627 - NODE 14: Node Status event - Node is AWAKE
16:21:29.627 - NODE 14: Commands 1.
16:21:29.628 - NODE 14: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandCl
16:21:34.743 - NODE 14: TID 250: Timeout at state WAIT_DATA. 3 retries remaining.
16:21:34.743 - TID 250: Transaction CANCELLED
16:21:34.743 - NODE 14: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
16:21:34.744 - NODE 14: notifyTransactionResponse TID:250 CANCELLED
16:21:34.749 - Transaction SendNextMessage 0 out at start. Holdoff false.
16:21:34.750 - Assembled message buffer = 01 09 00 13 0E 02 84 08 25 16 56
16:21:34.750 - NODE 14: Sending REQUEST Message = 01 09 00 13 0E 02 84 08 25 16 56
16:21:34.752 - Message SENT
16:21:34.753 - Transaction SendNextMessage started: TID 310: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 22
16:21:34.753 - Receive Message = 06
16:21:34.754 - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
16:21:34.754 - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
16:21:34.754 - lastTransaction null
16:21:34.754 - Received msg: ACK
16:21:34.754 - ZWaveReceiveThread queue empty
16:21:34.754 - Transaction SendNextMessage 1 out at start. Holdoff false.
16:21:34.755 - TID 250: Transaction event listener: DONE: CANCELLED ->
16:21:34.755 - NODE 14: Node Init response (1) org.openhab.binding.zwave.internal.protocol.ZWaveTransactionResponse@1a3a5f39
16:21:34.755 - NODE 14: No data from device, but it was ACK'd. Possibly not supported? (Try 1)
Why prune the log? I’m not really sure I understand it and generally speaking really short logs like this are very difficult to use as there is no context. What happens before this? The device seems to be awake, but why? Is the binding sending something? It seems so, but maybe it’s timing out. It’s really very difficult to use this sort of log - sorry.
It’s unlikely - secure devices normally allow basic functions, such as discovery, to be undertaken without security. Again though, I’m really guessing with no information.
Inclusion and wakeup are normally very different things. Maybe this device works differently, although the manual doesn’t say that wakeup is the same as inclusion.
To be clear - wakeup is a very specific message that a device sends. Another message that also works as a wakeup is a NIF - inclusion is not really related here.
Ok, I just think there were lots of log lines. Attaching the complete log for what I hope is the relevant time frame.
Thanks for clearifying the inclusion and wakeup concepts. logOpenHab.txt (24.4 KB)
Sure, but I can very easily filter this down. I normally deal with logs that are 10 to 20MB - you log file is still only 24k, so I don’t think it’s too big
I see, you have log reading tools That makes it easier.
I just caught the whole wakeup-discovery sequence in the attached log.
I’ll try to do a exclude and re-include as well.
Hi, again. I did a full log of exclude and re-include. The exclude and re-include is done with an Aeotec Z-stick Gen5 detached.
I managed to get in a broken-pipe exception in the log as well. Don’t know if it’s a bug.
Node 10 is also a SP-816. The re-included node 14 is now node 16.
I had to zip the log but change the ending to pdf of log to be able to attach it. Sorry … so change it to zip and unzip.
Anyway, it looks like this device is not responding to the first request it makes in the initialisation. Ironically, that request is the node information frame - the device does send this as the wakeup which is quite normal, but the binding initialisation doesn’t use this as it has a procedure it follows that needs to work for all devices.
It looks like it doesn’t therefore complete this stage of the initialisation sequence, but it’s unclear why the device isn’t responding to this command.
Since the NIF is sent when you wake the device, you could try performing the wakeup repeatedly so that the binding receives a NIF while it’s requesting one - that would hopefully make it move to the next stage. Of course it may not respond to other requests as well so maybe there’s something else up somewhere, but it’s worth a try.
It actually worked to wake the device by tripple-clicking it repeatedly. When the log is turned on I can see that the clicking pace is right (since too fast triple-click doesn’t wake it up).
It seems as if this device doesn’t really conform to the communication standard if I understand you correctly.
Just a note on the triple-clicking. I had another exactly the same device to add and tried to replicate the successful device configuration. It’s really hard to replicate. I noticed that the USB Z-stick can is put into inclusion mode when searching the inbox which removes the need to physically remove the stick in the adding process.
So what seemed to work this time was, remove SP816 from the network, put the Z-stick in inclusion mode using OpenHAB:s search function, remove the batteries of the SP816, put in the batteries (enters autoinclusion mode), tripple click the tamper-button repeatedly.
However, one problem remains. Even though the device is configured, none of the channels work (no events are generated in openHAB). I can see in the debug log that there are messages coming from the device put they are not picked up by OpenHAB. Any guess on how this could be? I have had no problems configuring other devices.
Hi Andrew! Thanks for the feedback! I was looking for a wakeup section in the manual, so I missed that it was in the troubleshooting section. The Nexa manual (rebranded Evergreen) wasn’t clear on how to wake it up.
Anyhow, once I get this device working properly I’ll certainly share my experience about it. It seems it’s not the easiest device to configure. The device is now configured but only the battery-channel is available to OpenHAB (no alarms) which is a bit weird.
