[SOLVED] Subtract / Compare Number:Temperature items?
Hello everyone! Hope I can get some help with a problem…
Running openHABian on a Raspberry Pi 3B
What I’m trying to accomplish…
  • The ability to control multiple HVAC systems with one set of rules.
ITEMS
Group AC
Group Heat
Group HVAC_Control
Group Lockouts
Number:Temperature HVAC_Temp_1 "Living Temp [%.0f °F]" <temperature> (AC,Heat)  { channel="onewiregpio:sensor:living:temperature" }
//-----Proxy items used in rules-----//
Switch AC_Sys_1 (AC, HVAC_Control)
Switch Heat_Sys_1 (Heat, HVAC_Control)
String Fan_Sys_1
Switch SysStatus_AC_1
Switch SysStatus_Heat_1
Switch Lockout_AC_1 (Lockouts)
Switch Lockout_Heat_1 (Lockouts)
//-----Relay Items used to turn on/off air handler-----//
Switch  AC_Relay_1   {gpio="pin:27 activelow:yes initialValue:high"}
Switch  Heat_Relay_1 {gpio="pin:21 activelow:yes initialValue:high"}
Switch  Fan_Relay_1  {gpio="pin:13 activelow:yes initialValue:high"}
//-----Setpoint & Thresholds-----//
Number:Temperature AcSetpoint_Temp_1 (AC)
Number:Temperature AcUpper_Threshold_1
Number:Temperature AcLower_Threshold_1
Number:Temperature HeatSetpoint_Temp_1 (Heat)
Number:Temperature HeatUpper_Threshold_1
Number:Temperature HeatLower_Threshold_1
RULES
// These rules control the HVAC system... the goal is to have a single set of rules that control multiple
// HVAC systems, without the need to duplicate and modify rules
import org.eclipse.smarthome.model.script.ScriptServiceUtil
        rule "Turn on AC when needed"
        Member of AC changed
        val system = triggeringItem.name.split("_").get(2).toString
        //logInfo("Trigger", system)
        val ac = ScriptServiceUtil.getItemRegistry.getItem("AC_Sys_"+system) as SwitchItem
        val fan = ScriptServiceUtil.getItemRegistry.getItem("Fan_Sys_"+system) as NumberItem
        val acRelay = ScriptServiceUtil.getItemRegistry.getItem("AC_Relay_"+system) as SwitchItem
        val fanRelay = ScriptServiceUtil.getItemRegistry.getItem("Fan_Relay_"+system) as SwitchItem
        val temp = ScriptServiceUtil.getItemRegistry.getItem("HVAC_Temp_"+system) as NumberItem
        val acSet = ScriptServiceUtil.getItemRegistry.getItem("AcSetpoint_Temp_"+system) as NumberItem
        val acUpThreshold = ScriptServiceUtil.getItemRegistry.getItem("AcUpper_Threshold_"+system) as NumberItem
        val acLowThreshold = ScriptServiceUtil.getItemRegistry.getItem("AcLower_Threshold_"+system) as NumberItem
        val acLockout = ScriptServiceUtil.getItemRegistry.getItem("Lockout_AC_"+system) as SwitchItem
            if(acLockout.state == OFF && ac.state == ON && (temp.state >= (acSet.state + acUpThreshold))){
                if(acRelay.state == OFF && fan.state == 1){
                    logInfo("AC", "Turning ON AC system for system" + system)
                    // sendCommand("Fan_Relay_"+system, ON)
                    // sendCommand("Fan_Sys_"+system, ON)
                    // Thread::sleep(500)
                    // sendCommand("AC_Relay_"+system, ON)
                    // sendCommand("AC_Sys_"+system, ON)
                    // sendCommand("SysStatus_AC_"+system, ON)
            else{
                if(ac.state == ON && (temp.state <= (acSet.state - acLowThreshold.state))){
                    if(acRelay.state == ON && fanRelay.state == ON){
                        logInfo("AC", "Turning OFF AC system for system" + system)
                        // sendCommand("Fan_Relay_"+system, OFF)
                        // sendCommand("Fan_Sys_"+system, OFF)
                        // sendCommand("AC_Relay_"+system, OFF)
                        // sendCommand("SysStatus_AC_"+system, OFF)
                        // sendCommand("Lockout_AC_"+system, ON)
    rule "Turn OFF AC/Heat when control proxy switch changes from ON to OFF"
    Member of HVAC_Control changed from ON to OFF
    val mode = triggeringItem.name.split("_").get(1).toString
            if(mode == "AC"){
                logInfo("AC_OFF", "AC Control switch changed to OFF... turning AC OFF for System " + system)
        else{
            if(mode == "Heat"){
            logInfo("Heat_OFF", "Heat Control switch changed to OFF... turning Heat OFF for System " + system)
            // sendCommand("Heat_Relay_"+system, OFF)
            // sendCommand("SysStatus_Heat_"+system, OFF)
            // sendCommand("Lockout_Heat_"+system, ON)
    rule "Turn OFF "Lockout_" + mode + system after 5 mins"
    Member of Lockouts changed from OFF to ON
            if(mode == "AC"){
                logInfo("AC_Lock", "Turning OFF AC Lockout in 5 mins for System " + system)
                // createTimer(now.plusMinutes(5), [ |
                // sendCommand("Lockout_AC_"+system, OFF)
        else{
            if(mode == "Heat"){
                logInfo("Heat_Lock", "Turning OFF Heat Lockout in 5 mins for System " + system)
                // sendCommand("Lockout_Heat_"+system, OFF)
LOG
Unknown variable or command '-'; line 38, column 54, length 34
When I log out the states ie: temp.state and acSet.state I get… 76 °F and 75 °F.
I would think that if I did (76 °F - 75 °F) I’d get 1 °F back?
What am I doing wrong?
Thanks! :slight_smile:
Which is line 38?
I think your problem is going to be that you are trying to do arithmetic with item.state, and unlike numbers, state objects don’t have arithmetic methods. (item.state can have values “banana”, OFF, etc. not just numeric)
You’ll need to cast as numeric types.
Thanks for the info. I tried adding .state as QuantityType.intValue to the end of the ScriptUtil vals… getting a “Could not cast 72.500 °F to void”
I think I’m going to remove the UOM and go from there.
Bad syntax there, it would be
(myItem.state as QuantityType<Temperature>).intValue
Joy!
Changed the vals to…
val temp = (ScriptServiceUtil.getItemRegistry.getItem("HVAC_Temp_"+system).state as QuantityType<Temperature>).intValue
val acSet = (ScriptServiceUtil.getItemRegistry.getItem("AcSetpoint_Temp_"+system).state as QuantityType<Temperature>).intValue
val acUpThreshold = (ScriptServiceUtil.getItemRegistry.getItem("AcUpper_Threshold_"+system).state as QuantityType<Temperature>).intValue
val acLowThreshold = (ScriptServiceUtil.getItemRegistry.getItem("AcLower_Threshold_"+system).state as QuantityType<Temperature>).intValue
Test rule…
logInfo("Vals", "Living temp --> {} , AC Setpoint --> {} , AC UpThreshold --> {} , AC LowThreshold --> {}", temp, acSet, acUpThreshold, acLowThreshold)
val sum = temp + acSet
logInfo("Sum", "Sum of temp and acSet is  --> {}", sum)
if(sum > 100)logInfo("Sum Compare", "True " + sum + " is > 100") else logInfo("Sum Compare", "False " + sum + " is < 100")
Log…
Living temp --> 72 , AC Setpoint --> 73 , AC UpThreshold --> 2 , AC LowThreshold --> 1
Sum of temp and acSet is  --> 145
True 145 is > 100
Thanks @rossko57!
