I am trying to create a timer that starts the fan when someone comes into the room (use the change of tradfri light to indicate that). Based on a script I found in the internet - it seems to work, but then copied for another room and there the power off after a while did not work. I double checked the code but found no differences - any idea?
kind of working:
var Timer WCHerrenLuefterTimer = null
val int WCHerrenLuefterTimeoutMinutes = 20
rule "WC Herren"
Item DeckenkeuchteWCHerren_Helligkeit changed to 100
sendCommand(WaschraumHerrenWC_Switch2, ON)
rule "WC Herren automatisch aus"
Item WaschraumHerrenWC_Switch2 changed to ON
if(WCHerrenLuefterTimer === null) {
WCHerrenLuefterTimer = createTimer(now.plusMinutes(WCHerrenLuefterTimeoutMinutes ), [|
sendCommand(WaschraumHerrenWC_Switch2, OFF)
else {
WCHerrenLuefterTimer.reschedule(now.plusMinutes(WCHerrenLuefterTimeoutMinutes ))
here the fan starts but timer never switches of the fan
var Timer WCDamenLuefterTimer = null
val int WCDamenLuefterTimeoutMinutes = 20
rule "WC Damen"
Item DeckenkeuchteWCDamen_Helligkeit changed to 100
sendCommand(WaschraumWCDamen_Switch2, ON)
sendTelegram("bot1", "item WaschraumWCDamen_Switch2 to %s", WaschraumWCDamen_Switch2.state.toString)
rule "WC Damen automatisch aus"
Item WaschraumWCDamen_Switch2 changed to ON
if(WCDamenLuefterTimer === null) {
WCDamenLuefterTimer = createTimer(now.plusMinutes(WCDamenLuefterTimeoutMinutes ), [|
sendCommand(WaschraumDamenWC_Switch2, OFF)
else {
WCDamenLuefterTimer.reschedule(now.plusMinutes(WCDamenLuefterTimeoutMinutes ))
or any other timer recommendations?
