[SOLVED] System slows down, Unknown Error messages
my System was running for years very well.
(Running in Pi 3B+ with openhabian)
After updating to latest stable (2.5.1-2) the system slows down dramatically.
After a restart I get a lot of these messages in openhab.log:
[WARN ] [me.core.internal.events.EventHandler] - Dispatching event to subscriber 'org.eclipse.smarthome.core.thing.i
nternal.CommunicationManager@1ae9ddd' takes more than 5000ms.
[WARN] [me.core.internal.events.EventHandler] - Dispatching event to subscriber 'org.eclipse.smarthome.core.internal.items.ItemUpdater@1945e99' takes more than 5000ms.
[WARN ] [me.core.internal.events.EventHandler] - Dispatching event to subscriber 'org.eclipse.smarthome.io.monitor.internal.EventLogger@ae910c' takes more than 5000ms.
[WARN ] [me.core.internal.events.EventHandler] - Dispatching event to subscriber 'org.openhab.core.events.internal.EventBridge@1e57d3f' takes more than 5000ms.
I’ve no idea what’s happening. In the end, the system gets unusable…
Any Idea how to figure out, what causes the issue?
Thanks a lot
You could try stopping OH and clearing the cache & tmp folders. The next start will take longer.
Some people have found that OH needs up to 3 restarts to settle down.
Take a look at your Disk I/O performance.
I observed the same and happened to me, because my SD card was near it’s end… And it was only able to read/write with a few MB/s.
Hi I’m using a SSD no SD Card, so this should not be the problem
I still cleared the cache and I rebooted several times…
Didn’t fixed.
Seems like the system runs well after about 25-30 minutes. Afterwards the erorr messages above occurs and the system slows down
What version did you update from?
First I updated from 2.4.0 to 2.5.0 and then to 2.5.1-2
Did it work OK from 2.4.0 to 2.5.0? Invalid addons can cause all addons, including bindings, to reload every minute as the loader tries to load invalid bindings. As documented, a common culprit is restdocs since it moved from misc to ui.
Check your addons.config file in the userdata tree. Stop OH before modifying that file though.
I had this error after upgrading from 2.4.0 to 2.5.0 and I corrected it.
Afterwards it was running well an dthe addons didn’t restarted.
Today I don’t have any log entries that shows up restarting addons
I have not yet updated to 2.5.1 on my production system. Could you post your addons.config here? Perhaps another set of eyes can spot something.
EDIT:
For some reason the forum is posting your messages twice.
sure, here’s the config:
:org.apache.felix.configadmin.revision:=L"8"
action="mail,xbmc,telegram"
binding="avmfritz,exec,tinkerforge1,wol1,fritzbox1,fritzboxtr0641,network,kodi,astro,amazonechocontrol,gpstracker,panasonictv1,mqtt,openweathermap,zwave,dwdunwetter,http1"
felix.fileinstall.filename="file:/var/lib/openhab2/etc/org.openhab.addons.cfg"
legacy=B"true"
misc="openhabcloud,hueemulation"
package="expert"
persistence="rrd4j,mapdb"
remote=B"true"
service.pid="org.openhab.addons"
transformation="map,regex,xslt,exec,javascript,scale,xpath,jsonpath"
ui="classic,basic,paper,habpanel,habmin,restdocs"
The Reply function isn’t working… that’s why it is posted twice
This config looks fine to me.
This is a Reply post from Chrome
this is also a reply from chrome
Now I frequently get:
l.items.ItemUpdater@19d994e' takes more than 5000ms.
Is it possible to figure out which ITEM/Thing/RULE ist causing it?
What does @19d994e mean?
This are the threads running, ordered by CPU Time:
That is likely an Item, Rule or Event number. You can try turning on debug logging to get more log information.
I just noticed you have exec as a transformation and a binding. I do not know if that is correct. You could try stopping OH, deleting both, start OH, install exec.
→ I just noticed you have exec as a transformation and a binding. I do not know if that is correct. You could try stopping OH, deleting both, start OH, install exec.
Where did you saw this?
What can I do exactly? (Not sure what you mean)
