When the Python file is loaded it executes the commands from top to bottom. You could put your code from the System started Rule just at the top level of the file and it should execute those lines when the file is loaded.
This is how I write a lot of my tests. For example, here is the test file I use to test my countdown_timer library.
import time
import personal.countdown_timer
reload (personal.countdown_timer)
from personal.countdown_timer import CountdownTimer
from core.log import log_traceback, logging, LOG_PREFIX
#from org.joda.time import DateTime
from datetime import datetime, timedelta
log = logging.getLogger("{}.TEST.countdown_timer".format(LOG_PREFIX))
func_called = False
def test():
global func_called
func_called = True
# Create a couple of Items to test with
from core.items import add_item
log.info("Creating test Items")
number = "Countdown_Timer_Test_Number"
string = "Countdown_Timer_Test_String"
add_item(number, item_type="Number")
add_item(string, item_type="String")
try:
# Test that func_called on even seconds.
log.info("--------------------------- seconds")
timer = CountdownTimer(log, (datetime.now() + timedelta(seconds=2)), test, number)
time.sleep(2.1)
assert func_called
# Test that func_called on fraction of seconds.
log.info("--------------------------- milliseconds")
func_called = False
timer = CountdownTimer(log, (datetime.now() + timedelta(seconds=2, microseconds=100000)), test, number)
time.sleep(2.2)
assert func_called
# Test that number gets updated properly
log.info("--------------------------- number Item")
log.info("number item is starting at {}".format(items[number]))
assert items[number] == DecimalType(0)
timer = CountdownTimer(log, (datetime.now() + timedelta(seconds=5)), test, number)
time.sleep(0.1)
log.info("number item is now {}".format(items[number]))
assert items[number] == DecimalType(4)
time.sleep(1)
assert items[number] == DecimalType(3)
time.sleep(1)
assert items[number] == DecimalType(2)
time.sleep(1)
assert items[number] == DecimalType(1)
time.sleep(1)
log.info("number item is finally {}".format(items[number]))
# Test that string gets updated properly.
log.info("--------------------------- string Item")
log.info("string item is starting at {}".format(items[string]))
timer = CountdownTimer(log, (datetime.now() + timedelta(seconds=5)), test, string)
time.sleep(0.1)
log.info("string item is now {}".format(items[string]))
assert str(items[string]).startswith("0:00:04")
time.sleep(1)
assert str(items[string]).startswith("0:00:03")
time.sleep(1)
assert str(items[string]).startswith("0:00:02")
time.sleep(1)
assert str(items[string]).startswith("0:00:01")
time.sleep(1)
log.info("string item is finally {}".format(items[string]))
assert str(items[string]) == "0:00:00"
# Test that hasTerminated works
log.info("--------------------------- hasTerminated()")
assert not timer.hasTerminated()
time.sleep(2)
assert timer.hasTerminated()
# Test that cancel works.
log.info("--------------------------- cancel()")
time.sleep(0.1)
old_val = items[number]
timer.cancel()
time.sleep(2)
except AssertionError:
import traceback
log.error("Exception: {}".format(traceback.format_exc()))
timer.cancel()
else:
log.info("CountdownTimer tests passed!")
finally:
log.info("Deleting test Items")
from core.items import remove_item
remove_item(number)
remove_item(string)
When this file is put into a folder where it’s picked up it immediately executes the tests, and it only executes them when the file is loaded.
So you can just put the code that you have in your System started rule outside of any functions and it will be executed when the file is loaded. Or you can put them into a function and put a call to that function at the top level of your script.
def on_load():
# do stuff
# do more stuff
on_load()
I don’t know if there is any sort of issue with doing it like this but based on my experience it should work.
