Hi There
I’ve been playing around some time now with Openhab2 and during the last couple of months I had mixed results.
Last year I managed to get the unofficial TADO binding working and it did it’s job great!
This year I decided to start over because a lot of new bindings that I can use have been added. The problem that I face right now is that whenever I start from skratch (uninstall/reinstall of Openhab2) I can’t seem to get a good reading from all the items I add via Visual studio. I’m currently working on a Ubuntu installation:
| Distributor ID: | Ubuntu |
| Description: | Ubuntu 16.04.5 LTS |
| Release: | 16.04 |
| Codename: | xenial |
Running the latest Openhab2
tado.things
Bridge tado:home:34DF7685 [ username="XXXXXXXXX@gmail.com", password="XXXXXXXXXX" ] {
zone LRHeating [id=1]
mobiledevice Arisa [id=176326]
mobiledevice Bart [id=855929]
tado.items
//Tado Thermostat
Number:Temperature HEAT_inside_temperature "Inside Temperature" { channel="tado:zone:34DF7685:LRHeating:currentTemperature" }
Number HEAT_humidity "Humidity" { channel="tado:zone:34DF7685:LRHeating:humidity" }
Number HEAT_heating_power "Heating Power" { channel="tado:zone:34DF7685:LRHeating:heatingPower" }
String HEAT_hvac_mode "HVAC Mode" { channel="tado:zone:34DF7685:LRHeating:hvacMode" }
Number:Temperature HEAT_target_temperature "Set Point" { channel="tado:zone:34DF7685:LRHeating:targetTemperature" }
DateTime HEAT_overlay_expiry "Setting Expiry" { channel="tado:zone:34DF7685:LRHeating:overlayExpiry" }
Number HEAT_timer_duration "Timer Duration" { channel="tado:zone:34DF7685:LRHeating:timerDuration" }
String HEAT_operation_mode "Operation Mode" { channel="tado:zone:34DF7685:LRHeating:operationMode" }
//Geolocation Devices
Switch Phone_atHomeA "Arisa [MAP(presence.map):%s]" { channel="tado:mobiledevice:34df7685:176326:atHome" }
Switch Phone_atHomeB "Bart [MAP(presence.map):%s]" { channel="tado:mobiledevice:34df7685:855929:atHome" }
tado.sitemap
sitemap tado label="Tado"
Frame label="Heating" {
Text item=HEAT_inside_temperature
Text item=HEAT_humidity
Text item=HEAT_heating_power
Setpoint item=HEAT_target_temperature minValue=5 maxValue=25
Selection item=HEAT_hvac_mode mappings=[OFF=off, HEAT=on]
Selection item=HEAT_operation_mode mappings=[SCHEDULE=schedule, MANUAL=manual, UNTIL_CHANGE="until change", TIMER=timer]
Setpoint item=HEAT_timer_duration minValue=5 maxValue=60 step=1
Text item=HEAT_overlay_expiry
Frame label="Presence" {
Text item=Phone_atHomeA
Text item=Phone_atHomeB
If I open the sitemap on my mobile phone it only show partial information:
It becomes even more strange due to the fact that if I use PaperUI to link the channels that it does work, sort of…
Can somebody help me where I go wrong?
UPDATE: When I link all the channels in Paper UI it does work except for the Heating Power…
Thanks!
