I would log onto to the Karaf console and restart the binding bundle.
Using bundle:list to get the number of the Tankerkoenig bundle and bundle:restart thenumber.
Additionally reading the documentation reveals that changing the refresh interval would restart the Webservice as well!
Did you notice any suspicious log entries when it started?
BTW: No problem observed on my side, so it doesn’t sound like a problem with the server of Tankerkoenig.de
Edit: Could you check before restarting the bundle if the web requests are still performed. You migth need to raise the log level for tankerkoenig to DEBUG. When getting the posted message the binding should NOT stop the web request!
I haven’t seen this SSL problem for some time and I have to admit that the documented solution to overcome it is not provided by me ( it’s a bit over my knowledge). Never heard of anybody having it after it did work!
Could you give some more details on your openHAB installation?
Java version used, openHAB version, openabian installation? or how did you install?
So i installed certificate in different ways but no luck. SSL error stay.
Openhab Version 4.2.7
java version “1.8.0_65”
Java™ SE Runtime Environment (build 1.8.0_65-b17)
Java HotSpot™ Client VM (build 25.65-b01, mixed mode)
Linux Raspbian GNU/Linux 9
