i try to migrate from telegram v1 to the new telegram binding, i get messages to my phone but in the logs i get a lot of warnings, its spamming me the logs:
Telegram exception: GetUpdates failed with error_code 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
i get this on oh 2.5.11 and oh3
i have setup the rule with action, this is working and whe i restart my oh 2.5 i get the messages i got before.
According to your post #1, you already have multiple things for the bot all to use the same UID inside one instance. And yes you cannot reuse the ID with a different endpoint no matter if that’s the same instance or not. Think from the telegram network side: which IP/port is Telegram expected to send to when it has a message for your ID ?
I’d guess that >1 thing results in an attempt to setup multiple telegram endpoints so that 409 ist just the logical consequence.
thank you, i have now deactivated telegram on the second instance (OH3, different ip, different place), now on the first instance the warning is away after a restart.
i will setup different bots for this now, thx for help
