Just getting started with OH2 and trying to test a telegram bot message when a door sensor changes to open. /etc/openhab2/rules/telegram.rules looks like this:
rule “Send telegram with Formatted Message”
Item zwave:device:xxxxxxxx:node10 changed to OPEN
sendTelegram(“botname”, “Front door opened”)
When I restart openhab I get this in the log:
Configuration model ‘telegram.rules’ has errors, therefore ignoring it: [3,2]: no viable alternative at input ‘:’
I’m pretty sure I’m missing something simple, just having a hard time finding good examples to learn from.
Item “Front Door” changed to OPEN
I’m editing with vim.
And still getting an error:
2019-02-23 12:55:19.393 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model ‘telegram.rules’ has errors, therefore ignoring it: [3,5]: no viable alternative at input ‘“Front Door”’
It’s the quote marks. I changed the item’s name to Front_Door, edited the script to have the name without quotes and the rule loads now. But I’m getting a different error now.
2019-02-23 13:07:15.666 [ERROR] [internal.handler.ScriptActionHandler] - Script execution failed: ReferenceError: “sendTelegram” is not defined in at line number 1
Have a look at VSCode with the OH extension, you can thank me later.
I was referring to the overall look of the quotes posted in the original rule. The solution to the first issue was to use the Item name in the when section of the rule. Had nothing to do with quotes per say.
Have you setup the the telgram.cfg file and defined “botname”?
VS Code with the openhab extension will syntax highlight for starters and help you write valid rules, also does a drop down feature that will suggest things/items/etc from your OH. https://marketplace.visualstudio.com/items?itemName=openhab.openhab << Example animation of VS Code in use.
As for quotes around the item name in the when statement quotations are not needed, copy and paste your item name as it is in your items file or PaperUI depending on how you set the item up.
Example:
rule "Garage lights when its dark and garage door is closed"
Item door_to_garage_con changed from CLOSED to OPEN
sendTelegram("bot1", "door has been opened")
Got it working this morning. Had to change the item to the more discreet door sensor rather than the thing. Not sure I’m using the right verbiage there but it’s working and I understand how to write more rules better now.
My working rule uses an Item and what I see in the log when the door opens. So now my thought is the physical sensor is the thing and it has multiple items like whether it’s open or closed, battery level etc.
Yes you trigger the rule based on the Item as shown in the second post. You could also trigger the rule using Channel.
Example:
rule "Send telegram with Formatted Message"
Channel zwave:device:xxxxxxxx:node10 changed to OPEN
sendTelegram("botname", "Front door opened")
Interesting, I never thought about triggering off at the thing level.
Only downside I can think of is if you want to be notified on multiple doors via group it would require all things under when…unless I also missed group things with recent releases, which is very possible.
