Dear,
I’ve created a my template widget with this code:
<div>
<table class="auto-style1">
<tr>
<td>
<div style="width: 100%; height: 100%>" ng-init='SamsungAC_Power={
"name": "Stato",
"sizeX": 1,
"sizeY": 1,
"item": config.power_item,
"type": "switch",
"hidelabel": false,
"hideonoff": false,
"iconset": "smarthome-set",
"icon": "power-button",
"icon_size": "32",
"row": 1,
"col": 1
}' ng-style="{opacity: 1.0}">
<widget-switch ng-model="SamsungAC_Power"></widget-switch>
</div>
</td>
<td>
<div ng-init='SamsungAC_Mode={
"name": "Modalità",
"sizeX": 1,
"sizeY": 1,
"item": config.mode_item,
"type": "selection",
"nolinebreak": false,
"icon": "thermostat",
"icon_size": "32",
"choices_columns": 3,
"choices_source": "csv",
"choices": "0=Auto,1=Freddo,2=Deumidif.,3=Aria,4=Caldo",
"keep_open": false,
"no_highlight": false,
"row": 1,
"col": 1
}' ng-if="itemValue(config.power_item)=='ON'" ng-style="{opacity: 1.0}">
<widget-selection ng-model="SamsungAC_Mode"></widget-selection>
</div>
</td>
<td>
<div ng-init='SamsungAC_Wind={
"name": "Direzione",
"sizeX": 1,
"sizeY": 1,
"item": config.wind_item,
"icon": "air-conditioning-indoor",
"icon_size": "32",
"choices_columns": 2,
"choices": "0=Su/Giù,1=Fissa",
"keep_open": false,
"row": 1,
"col": 1
<widget-selection ng-model="SamsungAC_Wind"></widget-selection>
</div>
</td>
<td>
<div ng-init='SamsungAC_Fan={
"name": "Ventola",
"sizeX": 1,
"sizeY": 1,
"item": config.fan_item,
"icon": "ventilation",
"icon_size": "32",
"choices": "0=Auto,1=Bassa,2=Media,3=Alta,4=Turbo",
"keep_open": false,
"row": 1,
"col": 1
<widget-selection ng-model="SamsungAC_Fan"></widget-selection>
</div>
</td>
<td>
<div ng-init='SamsungAC_Temp={
"name": "Temperatura",
"sizeX": 3,
"sizeY": 1,
"item": config.temperature_item,
"floor" : 16,
"ceil": 30,
"step": 1,
"hidelabel": false,
"hidelimits": false,
"vertical": false,
"showTicks":true
<widget-slider ng-model="SamsungAC_Temp"></widget-slider>
</div>
</td>
</tr>
</table>
</div>
It works, but I’d like to expand always the slider fom its position to end of widget width, but I don’t understand how.
thanks for the help
