I’m using Danfoss Z-wave 014G0160 thermostat to control the temperature in my home. I want to set up the rule that on different times of the day it regulates temperature differently.
For example, keep the temp low in the night, heat the room up for the time I wake up and again keep the temp low when I go to work etc. I use cron times to regulate that.
The problem is that for some reason the setpoint keeps resetting after some random time and I can’t figure out why. Is there anything wrong with the rule code or is there something that I’m missing in the thermostat configuration? When testing then the reset happens on random times - sometimes on the same second as the rule activates, sometimes minutes later, sometimes half an hour later.
Currently I set up the rule with only one cron rule and this is the only rule file I have:
rule "Setpoint to 26.0"
Time cron "0 31 9 ? * MON-FRI *"
ElutoaSetpoint.postUpdate(26.0)
rule "Elutoa temperatuur"
Item ElutoaSetpoint changed or
Item ElutoaTemp changed
var Number cur_temp = ElutoaTemp.state as Number
var Number setpoint = ElutoaSetpoint.state as Number
val Number hysteresis = 0.5
if (cur_temp < (setpoint - hysteresis)) {
if (ElutoaRadikas.state != ON) {ElutoaRadikas.sendCommand(ON)}
else if(cur_temp > setpoint + hysteresis) {
if (ElutoaRadikas.state != OFF) {ElutoaRadikas.sendCommand(OFF)}
**2018-09-03 09:31:00.446 [vent.ItemStateChangedEvent] - ElutoaSetpoint changed from 24 to 26.0**
2018-09-03 09:31:00.463 [ome.event.ItemCommandEvent] - Item 'ElutoaRadikas' received command ON
2018-09-03 09:31:00.467 [vent.ItemStateChangedEvent] - ElutoaRadikas changed from OFF to ON
2018-09-03 09:31:38.931 [vent.ItemStateChangedEvent] - ElutoaTemp changed from 24.61 to 24.65
2018-09-03 09:31:38.971 [me.event.ThingUpdatedEvent] - Thing 'zwave:device:6675270d:node3' has been updated.
2018-09-03 09:36:39.930 [vent.ItemStateChangedEvent] - ElutoaTemp changed from 24.65 to 24.71
2018-09-03 09:36:39.980 [me.event.ThingUpdatedEvent] - Thing 'zwave:device:6675270d:node3' has been updated.
**2018-09-03 09:36:40.088 [vent.ItemStateChangedEvent] - ElutoaSetpoint changed from 26.0 to 24**
2018-09-03 09:36:40.113 [ome.event.ItemCommandEvent] - Item 'ElutoaRadikas' received command OFF
Here’s the information about the thermostat, if needed:
Here’s the picture of the current (factory default) settings of the thermostat:
https://drive.google.com/open?id=1RUhsQXthVbcD1ej2RwGnL_4ySAzhv1r3
