What do you mean with the device ID? The node ID in openhab?
This is node 74…
The module ID is TZ36D, as you can see in the rest api, here below
"statusInfo": {
"status": "ONLINE",
"statusDetail": "NONE"
"editable": true,
"label": "Sch_2Knops",
"bridgeUID": "zwave:serial_zstick:2f4ef5d0",
"configuration": {
"binding_cmdrepollperiod": 1500,
"group_4": [
"controller"
"action_failed": false,
"group_1": [
"controller"
"action_remove": false,
"group_3": [
"controller"
"binding_pollperiod": 3600,
"group_2": [
"controller"
"action_heal": false,
"config_1_1": 1,
"switchall_mode": 255,
"config_2_1": 1,
"action_reinit": false,
"config_3_1": 1,
"config_4_1": 0,
"config_5_1": 0,
"node_id": 74
"properties": {
"zwave_class_basic": "BASIC_TYPE_ROUTING_SLAVE",
"zwave_class_generic": "GENERIC_TYPE_SWITCH_BINARY",
"zwave_neighbours": "1,32",
"modelId": "TZ36D",
"zwave_version": "2.1",
"zwave_plus_devicetype": "NODE_TYPE_ZWAVEPLUS_NODE",
"versionMin": "2.1",
"vendor": "TKB Home",
"defaultAssociations": "1,2,3,4",
"zwave_routing": "true",
"zwave_beaming": "true",
"zwave_secure": "false",
"zwave_class_specific": "SPECIFIC_TYPE_POWER_SWITCH_BINARY",
"zwave_devicetype": "3",
"zwave_frequent": "false",
"zwave_listening": "true",
"manufacturerId": "0118",
"manufacturerRef": "0003:0003,0311:0202",
"dbReference": "605",
"zwave_deviceid": "3",
"zwave_nodeid": "74",
"zwave_lastheal": "2019-08-20T00:38:50Z",
"zwave_plus_roletype": "ROLE_TYPE_SLAVE_ALWAYS_ON",
"zwave_manufacturer": "280"
"UID": "zwave:device:2f4ef5d0:node74",
"thingTypeUID": "zwave:tkb_tz36d_02_001",
"channels": [
"linkedItems": [
"Sch_2Knops_Binary"
"uid": "zwave:device:2f4ef5d0:node74:switch_binary",
"id": "switch_binary",
"channelTypeUID": "zwave:switch_binary",
"itemType": "Switch",
"kind": "STATE",
"label": "Switch",
"description": "Switch the power on and off",
"defaultTags": [],
"properties": {
"binding:*:OnOffType": "COMMAND_CLASS_SWITCH_BINARY,COMMAND_CLASS_BASIC"
"configuration": {}
"linkedItems": [
"Sch_2Knops"
"uid": "zwave:device:2f4ef5d0:node74:scene_number",
"id": "scene_number",
"channelTypeUID": "zwave:scene_number",
"itemType": "Number",
"kind": "STATE",
"label": "Scene Number",
"description": "Triggers when a scene button is pressed",
"defaultTags": [],
"properties": {
"binding:*:DecimalType": "COMMAND_CLASS_SCENE_ACTIVATION"
"configuration": {}
"location": "Achtertuin"
