[SOLVED] Total timeout 1000 ms elapsed after Update to OH2.4
I’m running OH2.4 on Debian Linux (Upgrade with apt-get), have cleared the cache etc. so that all errors except this one are gone (at the moment):
[ERROR] [.smarthome.model.script.actions.HTTP] - Fatal transport error: java.util.concurrent.TimeoutException: Total timeout 1000 ms elapsed
I use the http-Binding with a 30000 ms timeout via http.cfg and don’t know why this error comes with this rule:
stvRequest = “https://user:pwd@home.myopenhab.org:443/rest/items/switch”
sendHttpPostRequest(stvRequest, “text/plain”, “ON”)
I also tried to catch the timeout with several catch-versions but i wasn’t able to catch this too.
try{
catch(Throwable t){
logInfo(“Fehler”, stvRequest)
How can i set the timeout bigger, how can i catch the timeout and what could the timeout caused by? At the moment i this error everytime but home.myopenhab.org is reachable and my internet is up.
Best regards
Michael
First, please use the code fences
I know it is not documented but have you tried:
stvRequest = "https://user:pwd@home.myopenhab.org:443/rest/items/switch"
sendHttpPostRequest(stvRequest, "text/plain", "ON", 5000)
PS: I have not idea if it will work or not…
Dear Vincent,
works in that way that the switch was set and i didn’t an error. If it changes the timeout vom 1000 to 5000 ms we will see in the future.
Thank you very much.
Best regards
Michael
That’s what the 5000 is, the time out.
It’s not in the docs though.
Please tick the solution, thanks
