Does OpenHAB support international characters for item transforms?
If so, I have a problem: Item text passing a .map transformation is not encoded correctly in the web interface (sitemap).
I’ve created a .map transformation file (sv.map) with non-english characters, UTF-8 encoded (like all other configuration files) and the result looks like this:
The web page html specifies UTF-8 encoding. Labels for sitemap and items are encoded correctly.
OpenHAB 1.8.1 on Windows 7. Latest Chrome and Firefox.
Ok thanks. With this help I realized the .map files could be regular Java properties files which uses ISO-8859-1 encoding which fully supports my used language (swedish). Using this encoding the text was shown correctly on the web page.
This also explains why the *.items file had no problems since it’s not a Java properties-file.
Btw for languages not supported the native2ascii tool can be used to convert whole files.
