Is there a way to fix this?
I use this item
String CommonId_DE “Weather [MAP(weather_de.map):%s]”
weather_de.map file:
Partly Cloudy=teilweise bewölkt
The problem is, that the original value is “Partly Cloudy” with a space. It looks like map does not interpret this correct.
Could not transform ‘Partly Cloudy’ with the file ‘weather_de.map’ : Target value not found in map for ‘Partly Cloudy’
any idea?
