(solved) Transform ON / OFF into another value (e.g. string)
Hi, my weather station sends for rain the command “ON” and for no rain the command “OFF”.
openhab.log:
2016-03-28 09:10:23 - Rainsensor received command OFF
2016-03-28 09:11:54 - Rainsensor received command OFF
2016-03-28 09:13:28 - Rainsensor received command OFF
2016-03-28 09:15:01 - Rainsensor received command OFF
item:
Switch Rainsensor { knx=“<(60)3/7/9”}
What is your proposal or idea to best transform the value “OFF” into “It’s not raining” and the value of “ON” into “Its raining”
Click
Thanks, an example would be much more useful
Please keep the conversation in english.
The link John posted does include the following example
Let’s make a small example to illustrate this function. If you have a sensor which returns you the number 0 for a closed window and 1 for an open window, you can transform these values into the words “open” or “closed”. Create a map file named window.map for example and add the desired keys and values.
0=closed
1=opened
UNDEFINED=unknown
-=unknown
What else do you need ?
I have the same issue, no idea how to do that
Translated into English. My response was too fast :wink:
Thanks this is helpful. So, can i assume that the map needs to be called the same as the item?
made i file called Rainsensor.map:
OFF=No Rain
ON=Rain
UNDEFINED=unknown
-=unknown
item:
String Rainsensor { knx=“<(60)3/7/9”}
Sitemap:
Text item=Rainsensor
My GUI displays “OFF” instead of No Rain
No, you can name the .map file to whatever you like, cause you specify the file to be used in your item mapping.
But for better readability, it makes sense to call it “rain.map” in your case.
Example for item file
Contact Window_EG_WZ_S "Wohnzimmer [MAP(en.map):%s]" <contact> (gEG_WZ, gContacts, gWindows)
This is great! Thank you Sir!
Fantastic! Thanks JohnnyX! This helped a lot!
@all, this configuration works:
Rainsensor.map:
OFF=No Rain
ON=Rain
UNDEFINED=unknown
-=unknown
item:
String Rainsensor “Rain [MAP(Regensensor.map):%s]” { knx=“<(60)3/7/9”}
sitemap:
