[SOLVED] Transformation issues (MAP)
Yes, that’s correct and is based on a regular MAP file I normally use.
That’s my experience as well and I even tried it on other devices.
That DID the trick!
Thank you so much, Rich! :smiley:
I just copied this into the Options of this contact:
CLOSED=zu
Closed=zu
OPEN=offen
Open=offen
