Lastnormal
(Максим Павлик)
1
I use astro binding for outdoor lights. I set offset +20 after sunset -20 min before sunrise. And Item datetime items have right time (with offset)
DateTime Sunrise_Time_local “Sunrise [%1$tH:%1$tM]” { channel=“astro:sun:local:rise#start”, knx=“10.001:3/2/3” }
DateTime Sunset_Time_local “Sunset [%1$tH:%1$tM]” { channel=“astro:sun:local:set#start”, knx=“10.001:3/2/4”}
But trigger
rule “Sunrise rule”
Channel ‘astro:sun:local:rise#event’ triggered START
logInfo(“Sunrise”, “Sunrise rule trigerred!”)
and sunset trigger works without offsets.
What do I wrong?? OH2.1
Did you setup the offset even for the Event?
- Hint: There are two different channels for each incident, the datetime information and the event. Astro events are not linked to items.
Lastnormal
(Максим Павлик)
3
Thanks. add offset for range event. And check tomorrow.
No, that’s only the DateTime channel, you have to setup additionally
Lastnormal
(Максим Павлик)
5
Yes. All is ok. After add offset for Range event, trigger work at time. Thank for help.
Please don’t forget to mark the Solution
