[SOLVED] Trying to implement ThingActions into binding
(David Masshardt) #1
I’am trying to implement ThingActions into the Onkyo binding, but I’m always getting an error that the action is not found:
Rule ‘Test Switch’: ‘sendRawCommand’ is not a member of ‘org.eclipse.smarthome.core.thing.binding.ThingActions’; line 6, column 9, length 35
Here is the code of my implementation:
 * Copyright (c) 2010-2019 Contributors to the openHAB project
 * See the NOTICE file(s) distributed with this work for additional
 * information.
 * This program and the accompanying materials are made available under the
 * terms of the Eclipse Public License 2.0 which is available at
 * http://www.eclipse.org/legal/epl-2.0
 * SPDX-License-Identifier: EPL-2.0
package org.openhab.binding.onkyo.internal.automation.modules;
import org.eclipse.jdt.annotation.NonNullByDefault;
import org.eclipse.jdt.annotation.Nullable;
import org.eclipse.smarthome.core.thing.binding.ThingActions;
import org.eclipse.smarthome.core.thing.binding.ThingActionsScope;
import org.eclipse.smarthome.core.thing.binding.ThingHandler;
import org.openhab.binding.onkyo.internal.eiscp.EiscpCommand;
import org.openhab.binding.onkyo.internal.handler.OnkyoHandler;
import org.openhab.core.automation.annotation.ActionInput;
import org.openhab.core.automation.annotation.RuleAction;
import org.slf4j.Logger;
import org.slf4j.LoggerFactory;
 * Some automation actions to be used with a {@link OnkyoThingActionsService}
 * @author David Masshardt - initial contribution
@ThingActionsScope(name = "onkyo")
@NonNullByDefault
public class OnkyoThingActionsService implements ThingActions {
    private final Logger logger = LoggerFactory.getLogger(OnkyoThingActionsService.class);
    private @Nullable OnkyoHandler handler;
    @RuleAction(label = "Onkyo sendRawCommand", description = "Action that sends raw command to the receiver")
    public void sendRawCommand(@ActionInput(name = "rawCommand") @Nullable String rawCommand) {
        logger.debug("sendRawCommand called with raw command: {}", rawCommand);
    @Override
    public void setThingHandler(@Nullable ThingHandler handler) {
        if (handler instanceof OnkyoHandler) {
            this.handler = (OnkyoHandler) handler;
    @Override
    public @Nullable ThingHandler getThingHandler() {
        return this.handler;
I’ve also added the getServices method to the binding handler:
@Override
    public Collection<Class<? extends ThingHandlerService>> getServices() {
        return Collections.singletonList(OnkyoThingActionsService.class);
And this is my test rule:
rule "Test Switch"
        Item SW_Test changed
        val onkyoActions = getActions("onkyo","onkyo:TX-NR818:93b02aca-832a-cab9-6a23-ca0983b98a33")
        onkyoActions.sendRawCommand("Test")
What am I doing wrong? I copied most of the code from the MQTT binding and there the method call works.
(Hilbrand Bouwkamp) #2
(David Masshardt) #3
Thanks for the quick help, it is working now!
(David Graeff) #4
It’s so cool that more and more bindings are picking this up. As soon as we officially release the new rule engine, there will be plenty of actions it looks like.
