Still trying to understand rules. For this I’m writing small parts of code without a real purpose exept understanding what is happening. There is something I don’t get about the following code
var Timer sireneTimer = null
var Number timesthrough = 0
var Number timesthroughElse = 0
var Integer SireneOnTime = 3000
rule "Deur_open"
Member of gDoors changed
logInfo("deur", "Member of gDoors:" + triggeringItem.label + " changed from " + previousState.toString + "to:" + triggeringItem.state )
sireneTimer = createTimer(now, [
if(triggeringItem.state == OPEN) {
timesthrough = timesthrough + 1
SireneOnTime = SireneOnTime + 1000
timesthroughElse = timesthroughElse - 1
logInfo("deur", "This is " + timesthrough + " time through the timer")
sireneTimer.reschedule(now.plusMillis(SireneOnTime))
else {
logInfo("deur", "into else statement with timesthroughElse =" + timesthroughElse)
sireneTimer = null
When i open a doorsensor I get the following log:
2019-04-27 16:16:17.086 [INFO ] [.eclipse.smarthome.model.script.deur] - Member of gDoors:Door Sensor changed from CLOSEDto:OPEN
2019-04-27 16:16:17.131 [INFO ] [.eclipse.smarthome.model.script.deur] - This is 1 time through the timer
2019-04-27 16:16:21.165 [INFO ] [.eclipse.smarthome.model.script.deur] - This is 2 time through the timer
2019-04-27 16:16:22.175 [INFO ] [.eclipse.smarthome.model.script.deur] - Member of gDoors:Door Sensor changed from OPENto:CLOSED
2019-04-27 16:16:22.202 [INFO ] [.eclipse.smarthome.model.script.deur] - into else statement with timesthroughElse =-2
2019-04-27 16:16:26.188 [INFO ] [.eclipse.smarthome.model.script.deur] - into else statement with timesthroughElse =-2
It is the two last logs, when the script goes in the “else”-block, that I have questions about.
I think I undertsand why there are two logs but I would feel confident if the community confirms my thoughts.
I think that one of the lines is comming form the first thread of the rule triggered by opening the door while the other one is from the second thread triggered by closing the door. Is that correct?
What I don’t get is why the “timesthroughElse” is, at least for one of the loglines, not zero. I would of thought that a new thread of that rule, triggered by closing the door would use a new instance of the variable timesthroughElse with 0 as result.
Regards,
Mario
