Hi
I’m struggling to get the metadata out of a MQTT message I’m subscribing to.
This works just fine:
Number ELT1_externalTemperature "ELT1_externalTemperature [%.1f]" <temperature> (gLoRa) {mqtt="<[ttn:starman/devices/a81758fffe034049/up/externalTemperature:state:default]"}
Number ELT1_humidity "ELT1_humidity [%.1f]" <humidity> (gLoRa) {mqtt="<[ttn:starman/devices/a81758fffe034049/up/humidity:state:default]"}
Number ELT1_pressure "ELT1_pressure [%.0f]" <pressure> (gLoRa) {mqtt="<[ttn:starman/devices/a81758fffe034049/up/pressure:state:default]"}
Number ELT1_temperature "ELT1_temperature [%.1f]" <temperature> (gLoRa) {mqtt="<[ttn:starman/devices/a81758fffe034049/up/temperature:state:default]"}
Number ELT1_vdd "ELT1_vdd [%.1f]" <battery> (gLoRa) {mqtt="<[ttn:starman/devices/a81758fffe034049/up/vdd:state:default]"}
But I want to catch the
“metadata” -> time, airtime
“metadata”-> “gateways” -> gtw_id, rssi, snr
From this message rawformat I get with MOSQITTO from bash:
mosquitto_sub -h eu.thethings.network -t 'starman/devices/a81758fffe034049/up' -u '465749' -P 'ttn-account-v2.1234' -v
{ "app_id":"starman",
"dev_id":"a81758fffe034049",
"hardware_serial":"A81758FFFE034049",
"port":5,
"counter":5,
"payload_raw":"AQD1AgwDAwQ9Bw3uDADnDQAUAA+k5g==",
"payload_fields":{
"digital":0,
"externalTemperature":23.1,
"humidity":12,
"pressure":1025.254,
"temperature":24.5,
"vdd":3566,
"x":3,
"y":4,
"z":61
"metadata":{
"time":"2018-03-27T13:28:44.857209839Z",
"frequency":867.1,
"modulation":"LORA",
"data_rate":"SF7BW125",
"airtime":77056000,
"coding_rate":"4/5",
"gateways":[{
"gtw_id":"eui-46584258c00001d0",
"timestamp":4163345947,
"time":"",
"channel":3,
"rssi":-37,
"snr":10.5,
"rf_chain":0}]
vzorglub
(Vincent Regaud)
March 27, 2018, 2:49pm
2
You need the JSONPATH transformation
Check it is installed
Then
For example, the first one:
Number ELT1_externalTemperature "ELT1_externalTemperature [%.1f]" <temperature> (gLoRa) {mqtt="<[ttn:starman/devices/a81758fffe034049/up:state:JSONPATH($.payload_fields.externalTemperature)]"}
Note the topic and the JSONPATH expression
And the same for the others, you just need to change the jsonpath expression
You can paste the json in http://jsonpath.com/ and play with the jsonpath expression to extract whatever value you need.
Good luck
Hi @vzorglub
I think you missed my comments, the first section works just fine as it is already!
This is what I have a hard time to access:
@vzorglub but I see your comments there with the JSON:
up:state:JSONPATH($.metadata.time)]"}
I will try this first thing tomorrow when I have access to the OpenHAB server again…
vzorglub
(Vincent Regaud)
March 27, 2018, 9:33pm
5
metadata time: $.metadata.time
metadata airtime: $metadata.airtime
metadata gateways gwt_id: $.metadata.gateways[0].gtw_id
metada gateways rssi: $.metadata.gateways[0].rssi
metada gateways snr: $.metadata.gateways[0].snr
Note the [0] at the end of gateways: gateways[0]
Good luck
@vzorglub
Bah, still struggeling.
The JSON parsing works fine on the webpage.
It’s the MQTT string that’s the issue…
I have installed the “JSONPath Transformation” from the PapperUI
OpenHAB don’t like this syntax…
String ELT1_meta_time "Metadata Time: %s]" {mqtt="<[ttn:starman/devices/a81758fffe034049/up/state:JSONPATH($.metadata.time)]"}
2018-03-28 10:11:16.647 [ERROR] [el.item.internal.GenericItemProvider] - Binding configuration of type 'mqtt' of item 'ELT1_meta_freq' could not be parsed correctly.
org.eclipse.smarthome.model.item.BindingConfigParseException: Configuration 'ttn:starman/devices/a81758fffe034049/up/state:JSONPATH($.metadata.frequency)' is not a valid inbound configuration: Configuration requires 4 or 5 parameters separated by ':'
Closer now
String ELT1_meta_time "Metadata Time: %s" {mqtt="<[ttn:starman/devices/a81758fffe034049/up:state:JSONPATH($.metadata.time)]"}
Gives me the output:
JSONPATH($.time)2018-03-28T08:19:39.726715
vzorglub
(Vincent Regaud)
March 28, 2018, 8:21am
8
@vzorglub May thanks!
Everything work as expected
String ELT1_meta_time "Metadata Time: [%s]" {mqtt="<[ttn:starman/devices/a81758fffe034049/up:state:JSONPATH($.metadata.time)]"}
String ELT1_meta_freq "Metadata Frequency: [%s]" {mqtt="<[ttn:starman/devices/a81758fffe034049/up:state:JSONPATH($.metadata.frequency)]"}
String ELT1_meta_datarate "Metadata DataRate: [%s]" {mqtt="<[ttn:starman/devices/a81758fffe034049/up:state:JSONPATH($.metadata.data_rate)]"}
vzorglub
(Vincent Regaud)
March 28, 2018, 8:30am
11
Could you mark the thread as solved, please?
Give me 10min, cleaning up the files to leave a full documentation for other users!
Items file & Sitemap for LoRaWAN sensor attached to TTN “The Things Network”
lora.items
//LoRaWAN Sensor Data
Number ELT1_externalTemperature "ELT1_External Temp [%.1f]" <temperature> (gLoRa) {mqtt="<[ttn:starman/devices/a81758fffe034049/up/externalTemperature:state:default]"}
Number ELT1_pos_x "ELT1_pos_x [%.1f]" <niveau> (gLoRa) {mqtt="<[ttn:starman/devices/a81758fffe034049/up/x:state:default]"}
Number ELT1_pos_y "ELT1_pos_y [%.1f]" <niveau> (gLoRa) {mqtt="<[ttn:starman/devices/a81758fffe034049/up/y:state:default]"}
Number ELT1_pos_z "ELT1_pos_z [%.1f]" <niveau> (gLoRa) {mqtt="<[ttn:starman/devices/a81758fffe034049/up/z:state:default]"}
//LoraWAN Meta Data
String ELT1_meta_time "Metadata Time: [%s]" <time> (gLoRa) {mqtt="<[ttn:starman/devices/a81758fffe034049/up:state:JSONPATH($.metadata.time)]"}
String ELT1_meta_freq "Metadata Frequency: [%s]" <settings> (gLoRa) {mqtt="<[ttn:starman/devices/a81758fffe034049/up:state:JSONPATH($.metadata.frequency)]"}
String ELT1_meta_datarate "Metadata DataRate: [%s]" <settings> (gLoRa) {mqtt="<[ttn:starman/devices/a81758fffe034049/up:state:JSONPATH($.metadata.data_rate)]"}
String ELT1_meta_airtime "Metadata AirTime: [%s]" <settings> (gLoRa) {mqtt="<[ttn:starman/devices/a81758fffe034049/up:state:JSONPATH($.metadata.airtime)]"}
String ELT1_meta_coding_rate "Metadata CodingRate: [%s]" <settings> (gLoRa) {mqtt="<[ttn:starman/devices/a81758fffe034049/up:state:JSONPATH($.metadata.coding_rate)]"}
//LoraWAN GW1 information
String ELT1_gw_id "GW ID: [%s]" <text> (gLoRa) {mqtt="<[ttn:starman/devices/a81758fffe034049/up:state:JSONPATH($.metadata.gateways[0].gtw_id)]"}
String ELT1_gw_channel "GW Channel: [%s]" <qualityofservice> (gLoRa) {mqtt="<[ttn:starman/devices/a81758fffe034049/up:state:JSONPATH($.metadata.gateways[0].channel)]"}
String ELT1_gw_rssi "GW RSSI: [%s]" <network> (gLoRa) {mqtt="<[ttn:starman/devices/a81758fffe034049/up:state:JSONPATH($.metadata.gateways[0].rssi)]"}
String ELT1_gw_snr "GW SNR: [%s]" <network> (gLoRa) {mqtt="<[ttn:starman/devices/a81758fffe034049/up:state:JSONPATH($.metadata.gateways[0].snr)]"}
String ELT1_gw_rf_chain "GW RF-Chain: [%s]" <qualityofservice> (gLoRa) {mqtt="<[ttn:starman/devices/a81758fffe034049/up:state:JSONPATH($.metadata.gateways[0].rf_chain)]"}
lora.sitemap
sitemap lora label="Lora" {
Frame {
Text label="Elsys ELT-2" icon="sensor" {
Frame label="Sensor Data" {
Default item=ELT1_temperature label="Temperature"
Default item=ELT1_humidity label="Humidity"
Default item=ELT1_pressure label="Pressure"
Default item=ELT1_externalTemperature label="External Temp"
Default item=ELT1_vdd label="VDD"
Default item=ELT1_pos_x label="Position-X"
Default item=ELT1_pos_y label="Position-Y"
Default item=ELT1_pos_z label="Position-Z"
Frame label="LoRaWAN MetaData" icon="network"{
Default item=ELT1_meta_time label="PacketTime"
Default item=ELT1_meta_freq label="Frequency"
Default item=ELT1_meta_datarate label="DataRate"
Default item=ELT1_meta_airtime label="AirTime"
Default item=ELT1_meta_coding_rate label="CodingRate"
Frame label="LoRaWAN GateWay information" icon="qualityofservice"{
Default item=ELT1_gw_id label="ID"
Default item=ELT1_gw_channel label="Channel"
Default item=ELT1_gw_rssi label="RSSI"
Default item=ELT1_gw_snr label="SNR"
Default item=ELT1_gw_rf_chain label="RF-Chain"
bernd_d
(Bernd)
November 20, 2019, 8:10pm
14
As of Nov 18th the separate “field” values have been disabled (for performance reasons) by TTN. Who knows when they will be reactivated…
You can now fetch each field data through the “payload_fields” field by using a JSONPATH transformation like for the metadata information.
