muere
(Reinhard Müller)
October 21, 2018, 3:22pm
1
Raspi 3B
Installation: Openhabian
openHAB 2.4.0 Build # 1381
Aeotec Z-Stick Gen5 Platform information:
Ask for help, I have read a lot and tried, but I can not get further:
var Number soll1EinWZ
soll1EinWZ = (Uhr1_H_Ein_WZ.state as Number) * 60 + (Uhr1_M_Ein_WZ.state as Number)
it does not work
logInfo("time1_Ein_WZ","Einschaltzeit 1 {}",now.withTimeAtStartOfDay.plusMinutes(soll1EinWZ).getAsText)
is working
logInfo("time1_Ein_WZ","Einschaltzeit 1 {}",now.withTimeAtStartOfDay.plusMinutes(5).getAsText)
how can I convert that?
H102
(CM6.5 H102)
October 21, 2018, 3:38pm
2
Try with this
var Number soll1EinWZ = (Uhr1_H_Ein_WZ.state as Number) * 60 + (Uhr1_M_Ein_WZ.state as Number)
rossko57
(Rossko57)
October 21, 2018, 4:02pm
3
The plusMinutes() etc. methods are unusual in wanting an integer value, xxx.plusMinutes( soll1EinWZ.intValue )
muere
(Reinhard Müller)
October 21, 2018, 4:21pm
4
error message:
"resource": "/etc/openhab2/rules/Thermostat.rules",
"owner": "_generated_diagnostic_collection_name_#0",
"code": "org.eclipse.xtext.xbase.validation.IssueCodes.incompatible_types",
"severity": 8,
"message": "Type mismatch: cannot convert from Number to int",
"startLineNumber": 181,
"startColumn": 83,
"endLineNumber": 181,
"endColumn": 93
muere
(Reinhard Müller)
October 21, 2018, 4:40pm
6
H102:
Val Integer soll1EinWZ
val int soll1EinWZ = (Uhr1_H_Ein_WZ.state as Number) * 60 + (Uhr1_M_Ein_WZ.state as Number)
"severity": 8,
"message": "Type mismatch: cannot convert from BigDecimal to Integer",
"startLineNumber": 178,
"startColumn": 27,
"endLineNumber": 178,
"endColumn": 97
H102
(CM6.5 H102)
October 21, 2018, 4:47pm
7
var temp1 = Uhr1_H_Ein_WZ.state as Number
var temp2 = Uhr1_M_Ein_WZ.state as Number
var soll1EinWZ = ((temp1) * 60) + (temp2)
muere
(Reinhard Müller)
October 21, 2018, 4:51pm
8
No, I want the time from the item Uhr1_H_Ein_WZ (hour) und Uhr1_M_Ein_WZ (minutes * 60)
with
report
H102
(CM6.5 H102)
October 21, 2018, 5:00pm
9
For some reason I was thinking temp.
You just want the number to plugin, if you move the brackets for the math does it work?
H102:
var time1 = Uhr1_H_Ein_WZ.state as Number
var time2 = Uhr1_M_Ein_WZ.state as Number
var soll1EinWZ = ((time2) *60) + (time1)
muere
(Reinhard Müller)
October 21, 2018, 5:11pm
10
I’ve already tried that
I test since yesterday, but always the error is always similar
"severity": 8,
"message": "Type mismatch: cannot convert from BigDecimal to int",
"startLineNumber": 183,
"startColumn": 83,
"endLineNumber": 183,
"endColumn": 93
"code": "org.eclipse.xtext.diagnostics.Diagnostic.Linking",
"severity": 8,
"message": "The method or field getAsText is undefined for the type DateTime",
"startColumn": 95,
"endColumn": 104
muere
(Reinhard Müller)
October 21, 2018, 5:23pm
11
I do not understand that it works with “5” but not with the var number.
logInfo("time1_Ein_WZ","Einschaltzeit 1 {}",now.withTimeAtStartOfDay.plusMinutes(5).getAsText)``
H102
(CM6.5 H102)
October 21, 2018, 5:30pm
12
I’m not at my OH server so hard to test but using val integer soll1EinWZ = Uhr1_H_Ein_WZ.state as Number should cast this into an integer. Try changing the var to val on time1 and time2 and add logging after each to see if the val is being created and what it is.
muere
(Reinhard Müller)
October 21, 2018, 5:31pm
13
The mistake comes here too:
time1_Ein_WZ = createTimer(now.withTimeAtStartOfDay.plusMinutes(soll1EinWZ)
"severity": 8,
"startLineNumber": 210,
"startColumn": 69,
"endLineNumber": 210,
"endColumn": 79
muere
(Reinhard Müller)
October 21, 2018, 6:32pm
15
Thanks, that’s it! Do you get that in a line?
I have 36 times to work.
similar:
val int soll1EinWZ = (Uhr1_H_Ein_WZ.state as DecimalTyp) * 60 + (Uhr1_M_Ein_WZ.state as DecimalType)
H102
(CM6.5 H102)
October 21, 2018, 8:03pm
16
Are you asking if this can be on a single line?
If so, try this:
val interger soll1EinWZ = ((Uhr1_M_Ein_WZ.state as DecimalType).intValue * 60) + (Uhr1_H_Ein_WZ.state as DecimalType).intValue
