I’ve installed openHab2 manual on a RPi 3. Runs perfect and a first set-up with a simple binding and switch a switch works perfect.
However, If I take a look at PaperUI menu Configurations -> Services -> UI I see only HABPanel. I would like to add HABmin and Basic. How can I do that?
I choose at first Paper UI. However, there was definitely only the existing Paper UI and HAB Panel available. Neither Basic UI now Classic UI, etc.
Thanks in advance and best regards
Andreas
Thank you for the hint.
I moved the .cfg file and restarted the service but unfortunately it doesn’t fix the issue
But the hint was very helpful
I found within the folder /var/lib/openhab2/config/org/openhab an additional addons.config.
