- Platform information:
- Hardware: manjaro linux
- Java Runtime Environment: 8
- openHAB version: 2.5
On a fresh install of openhab my log shows the following error:
/var/log/openhab2/
java.io.IOException: Failed to bind to /0.0.0.0:8080
Caused by: java.net.BindException: Address already in use
With some java errors in between… I assume this is because the network on my server is using a bridged ethernet connection as it is my router/switch.
Is there a way to force openhab to a set ip address?
