OS: Openhabian just ported on USB (14,4Gb)
Release = Raspbian GNU/Linux 8 (jessie)
Kernel = Linux 4.9.35-v7+
Platform = Raspberry Pi 3 Model B Rev 1.2
Uptime = 0 day(s). 0:2:56
CPU Usage = 41.16 % avg over 4 cpu(s) (4 core(s) x 1 socket(s))
CPU Load = 1m: 6.18, 5m: 3.52, 15m: 1.41
Memory = Free: 0.72GB (77%), Used: 0.22GB (23%), Total: 0.94GB
Swap = Free: 0.09GB (100%), Used: 0.00GB (0%), Total: 0.09GB
Root = Free: 1.86GB (13%), Used: 11.53GB (87%), Total: 14.12GB
Updates = 0 apt-get updates available.
Sessions = 1 sessions
Processes = 147 running processes of 32768 maximum processes
Apache = Version: 2.4.10
Nginx = Version: 1.6.2
PHP = Version: 5.6.33, Memory Limit:
Version: openHAB 2.3.0~20180121190142-1 (Build #1193)
Issue of the topic: unable to upgrade the system (same behaviour with system on SD)
If logs where generated please post these here using code fences:
[12:44:15] openhabian@pi:~$ sudo openhabian-config
[sudo] password for openhabian:
2018-05-26_12:44:34_CEST [openHABian] Checking for root privileges... OK
2018-05-26_12:44:35_CEST [openHABian] Loading configuration file '/etc/openhabia n.conf'... OK
2018-05-26_12:44:43_CEST [openHABian] openHABian configuration tool version: [master]v1.4.1-399(47771f8)
2018-05-26_12:45:06_CEST [openHABian] Checking for changes in origin... OK
2018-05-26_12:50:23_CEST [openHABian] Updating myself... OK - No remote changes detected. You are up to date!
2018-05-26_12:50:42_CEST [openHABian] Updating repositories and upgrading installed packages...
$ apt update
E: Malformed line 1 in source list /etc/apt/sources.list (dist)
E: The list of sources could not be read.
$ apt --yes upgrade
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
OK
2018-05-26_12:50:49_CEST [openHABian] Checking for default openHABian username:password combination... OK
2018-05-26_12:50:49_CEST [openHABian] We hope you got what you came for! See you again soon ;)
[12:50:49] openhabian@pi:~$
Hi Vincent
This is the sources.list content (the uploader of the editor refuses the extension .list),The previous upgrade were done without problems. Thanks
deb http://raspbian.mirror.garr.it/mirrors/raspbian/raspbian
#deb http://mirrordirector.raspbian.org/raspbian/ jessie main contrib non-free rpi
# Uncomment line below then 'apt-get update' to enable 'apt-get source'
#deb-src http://archive.raspbian.org/raspbian/ jessie main contrib non-free rpi```
[16:39:58] root@pi:/home/openhabian# openhabian-config
2018-05-26_16:40:17_CEST [openHABian] Checking for root privileges... OK
2018-05-26_16:40:17_CEST [openHABian] Loading configuration file '/etc/openhabian.conf'... OK
2018-05-26_16:40:17_CEST [openHABian] openHABian configuration tool version: [master]v1.4.1-399(47771f8)
2018-05-26_16:40:17_CEST [openHABian] Checking for changes in origin... OK
2018-05-26_16:40:24_CEST [openHABian] Updating repositories and upgrading installed packages...
$ apt update
$ apt --yes upgrade
Reading package lists... Error!
E: The package lists or status file could not be parsed or opened.
FAILED
I had forgotten to reboot the system however the result is the same
[16:53:33] openhabian@pi:~$ sudo openhabian-config
2018-05-26_16:54:07_CEST [openHABian] Checking for root privileges... OK
2018-05-26_16:54:07_CEST [openHABian] Loading configuration file '/etc/openhabia n.conf'... OK
2018-05-26_16:54:14_CEST [openHABian] openHABian configuration tool version: [master]v1.4.1-399(47771f8)
2018-05-26_16:54:14_CEST [openHABian] Checking for changes in origin... Updates available...
2018-05-26_16:54:30_CEST [openHABian] Updating myself... OK - Commit history (oldest to newest):
6f3eccf - Update documentation links (16 hours ago) <Wouter Born> N
README.md | 6 +++---
docs/openhabian.md | 24 ++++++++++++------------
functions/menu.sh | 2 +-
functions/openhab.sh | 2 +-
functions/packages.sh | 4 ++--
includes/bash_profile | 2 +-
includes/dashboard-imagedata.sh | 2 +-
includes/srv_readme.txt | 12 ++++++------
openhabian-setup.sh | 4 ++--
9 files changed, 29 insertions(+), 29 deletions(-)
openHABian configuration tool successfully updated.
Visit the development repository for more details: https://github.com/openhab/openhabian
The tool will now restart to load the updates...
2018-05-26_16:54:39_CEST [openHABian] Checking for root privileges... OK
2018-05-26_16:54:39_CEST [openHABian] Loading configuration file '/etc/openhabian.conf'... OK
2018-05-26_16:54:39_CEST [openHABian] openHABian configuration tool version: [master]v1.4.1-400(6f3eccf)
2018-05-26_16:54:39_CEST [openHABian] Checking for changes in origin... OK
2018-05-26_16:54:53_CEST [openHABian] Updating repositories and upgrading installed packages...
$ apt update
$ apt --yes upgrade
OK
2018-05-26_16:56:04_CEST [openHABian] Checking for default openHABian username:password combination... OK
2018-05-26_16:56:04_CEST [openHABian] We hope you got what you came for! See you again soon ;)
[16:56:04] openhabian@pi:~$
