Stehof
(Stéphane Hofman)
January 21, 2022, 10:07am
1
Platform information:
Hardware: Raspberry Pi 3 Model B Plus Rev 1.3
OS: Raspbian GNU/Linux 9 (stretch)
Java Runtime Environment: Unknown, get an error on “java -version”
openHAB version: 3.2.0 - Release Build
Issue of the topic: please be detailed explaining your issue
Please post configurations (if applicable):
Items configuration related to the issue
Sitemap configuration related to the issue
Rules code related to the issue
Services configuration related to the issue
If logs where generated please post these here using code fences:
Till this morning, everything worked fine, I just wanted to update all the packages so I SSH’ed into the Pi and run: sudo openhabian-config
Alle updates went well, till the last one, Java. It showed this error:
There was an error or interruption during the execution of: │
│ “02 | Upgrade System”
I rebooted and the system starts, but nothin is working, can’t access the WebGUI and when I run “java -version” this is the output:
java: error while loading shared libraries: libjli.so: cannot open shared object file: No such file or directory
Which I guess is the cause of the problem, can’t seem to figure out how to fix this. I tried :
sudo rm /usr/bin/java
And run the update script again under “sudo openhabian-config” but still the same errors.
When I try:
sudo update-alternatives --config java
This is the output:
There is only one alternative in link group java (providing /usr/bin/java): /opt/jdk/zulu11.52.13-ca-jdk11.0.13-linux_aarch32sf/bin/java
Nothing to configure.
And below the output when the update under “sudo openhabian-config” fails:
**openhabian@openHABianPi**:**~ $** sudo openhabian-config
[sudo] password for openhabian:
2022-01-21_10:51:57_CET [openHABian] Checking for root privileges... OK
2022-01-21_10:51:58_CET [openHABian] Loading configuration file '/etc/openhabian.conf'... OK
2022-01-21_10:51:58_CET [openHABian] openHABian configuration tool version: [openHAB3]{2021-12-02T09:19:37-07:00}(bb960d8)
2022-01-21_10:51:58_CET [openHABian] Checking for changes in origin branch openHAB3... OK
2022-01-21_10:52:04_CET [openHABian] Switching to branch openHAB3... OK
2022-01-21_10:52:04_CET [openHABian] Adding slightly tuned bash configuration files to system... OK
2022-01-21_10:52:09_CET [openHABian] Updating Linux package information... OK
2022-01-21_10:52:10_CET [openHABian] Updating repositories and upgrading installed packages...
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
2022-01-21_10:52:12_CET [openHABian] Installing Java Zulu prerequisites (libc, libstdc++, zlib1g)... OK
2022-01-21_10:52:14_CET [openHABian] Downloading Java Zulu 11 32-Bit OpenJDK... OK
2022-01-21_10:53:31_CET [openHABian] Installing Java Zulu 11 32-Bit OpenJDK... OK
2022-01-21_10:53:42_CET [openHABian] Installing Java Zulu CEK to enable unlimited cipher strength... OK
FAILED
2022-01-21_10:55:20_CET [openHABian] Checking for default openHABian username:password combination... OK
2022-01-21_10:55:20_CET [openHABian] We hope you got what you came for! See you again soon ;)
I really don’t know how to fix this now, any suggestions?
Stehof
(Stéphane Hofman)
January 21, 2022, 10:25am
2
I just set the debug mode to maximum and run it again, this is the output:
+ java_install_or_update Zulu8-32
+ local branch
++ git -C /opt/openhabian rev-parse --abbrev-ref HEAD
+ branch=openHAB3
++ command -v java
+ [[ -x '' ]]
++ command -v java
+ [[ -x '' ]]
+ [[ Zulu11-32 == \Z\u\l\u\8\-\3\2 ]]
+ [[ Zulu8-32 == \A\d\o\p\t\1\1 ]]
+ [[ Zulu8-32 != \A\d\o\p\t\1\1 ]]
++ java -version
+ [[ /opt/openhabian/functions/java-jre.bash: line 24: java: command not found == *\A\d\o\p\t\O\p\e\n\J\D\K* ]]
+ [[ Zulu8-32 == \Z\u\l\u\1\1\-\6\4 ]]
+ cond_redirect java_zulu_update_available Zulu11-32
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ java_zulu_update_available Zulu11-32 \033[39;49;00m'
+ java_zulu_update_available Zulu11-32
++ command -v java
+ [[ -x '' ]]
+ return 0
+ return 0
+ java_zulu_prerequisite Zulu11-32
++ timestamp
++ date +%F_%T_%Z
+ echo -n '2022-01-21_11:19:27_CET [openHABian] Installing Java Zulu prerequisites (libc, libstdc++, zlib1g)... '
2022-01-21_11:19:27_CET [openHABian] Installing Java Zulu prerequisites (libc, libstdc++, zlib1g)... + [[ Zulu11-32 == \Z\u\l\u\1\1\-\6\4 ]]
+ is_arm
+ is_armv6l
+ [[ '' == \a\r\m\v\6\l ]]
+ case "$(uname -m)" in
++ uname -m
+ return 1
+ is_armv7l
+ [[ '' == \a\r\m\v\7\l ]]
++ uname -m
+ return 0
+ return 0
+ dpkg -s libc6:armhf libstdc++6:armhf zlib1g:armhf
+ echo OK
OK
+ return 0
+ [[ openHAB3 == \o\p\e\n\H\A\B\3 ]]
+ [[ -z '' ]]
+ java_zulu_stable Zulu11-32
+ local updateText
+ local consoleText
+ updateText='Updating Java may result in issues as it has not received extensive testing to verify compatibility.\n\nIf you wish to continue and encounter any errors please let us know so we can look into them to improve future compatibility.'
+ consoleText='[openHABian] WARNING: Untested Java Version, you may experience issues as this version of Java has not received extensive testing to verify compatibility.'
+ [[ -n 1 ]]
+ whiptail --defaultno --title 'Untested Version of Java' --no-button Back --yes-button Continue --yesno 'Updating Java may result in issues as it has not received extensive testing to verify compatibility.\n\nIf you wish to continue and encounter any errors please let us know so we can look into them to improve future compatibility.' 11 80
+ java_zulu_fetch Zulu11-32
+ local downloadLink
+ local jdkInstallLocation
+ local link
+ local temp
+ jdkInstallLocation=/opt/jdk
+ link='https://api.azul.com/zulu/download/community/v1.0/bundles/latest/binary/?os=linux&ext=tar.gz&javafx=false'
++ mktemp /tmp/openhabian.XXXXX
+ temp=/tmp/openhabian.noDLs
+ [[ Zulu11-32 == \Z\u\l\u\1\1\-\3\2 ]]
++ timestamp
++ date +%F_%T_%Z
+ echo -n '2022-01-21_11:19:30_CET [openHABian] Downloading Java Zulu 11 32-Bit OpenJDK... '
2022-01-21_11:19:30_CET [openHABian] Downloading Java Zulu 11 32-Bit OpenJDK... + is_arm
+ is_armv6l
++ uname -m
+ return 1
+ is_armv7l
++ uname -m
+ return 0
+ return 0
++ curl 'https://api.azul.com/zulu/download/community/v1.0/bundles/latest/binary/?os=linux&ext=tar.gz&javafx=false&jdk_version=11&arch=arm&hw_bitness=32&abi=hard_float' -s -L -I -o /dev/null -w '%{url_effective}'
+ downloadLink=https://cdn.azul.com/zulu-embedded/bin/zulu11.52.13-ca-jdk11.0.13-linux_aarch32sf.tar.gz
+ [[ -z https://cdn.azul.com/zulu-embedded/bin/zulu11.52.13-ca-jdk11.0.13-linux_aarch32sf.tar.gz ]]
+ mkdir -p /opt/jdk
+ cond_redirect wget -nv -O /tmp/openhabian.noDLs https://cdn.azul.com/zulu-embedded/bin/zulu11.52.13-ca-jdk11.0.13-linux_aarch32sf.tar.gz
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ wget -nv -O /tmp/openhabian.noDLs https://cdn.azul.com/zulu-embedded/bin/zulu11.52.13-ca-jdk11.0.13-linux_aarch32sf.tar.gz \033[39;49;00m'
+ wget -nv -O /tmp/openhabian.noDLs https://cdn.azul.com/zulu-embedded/bin/zulu11.52.13-ca-jdk11.0.13-linux_aarch32sf.tar.gz
2022-01-21 11:19:56 URL:https://cdn.azul.com/zulu-embedded/bin/zulu11.52.13-ca-jdk11.0.13-linux_aarch32sf.tar.gz [178706130/178706130] -> "/tmp/openhabian.noDLs" [1]
+ return 0
+ cond_redirect tar -xpzf /tmp/openhabian.noDLs -C /opt/jdk
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ tar -xpzf /tmp/openhabian.noDLs -C /opt/jdk \033[39;49;00m'
+ tar -xpzf /tmp/openhabian.noDLs -C /opt/jdk
+ return 0
++ basename https://cdn.azul.com/zulu-embedded/bin/zulu11.52.13-ca-jdk11.0.13-linux_aarch32sf.tar.gz
++ sed -e s/.tar.gz//
+ cond_redirect find /opt/jdk -mindepth 1 -maxdepth 1 -name zulu11.52.13-ca-jdk11.0.13-linux_aarch32sf -prune -o -exec rm -rf '{}' ';'
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ find /opt/jdk -mindepth 1 -maxdepth 1 -name zulu11.52.13-ca-jdk11.0.13-linux_aarch32sf -prune -o -exec rm -rf {} ; \033[39;49;00m'
+ find /opt/jdk -mindepth 1 -maxdepth 1 -name zulu11.52.13-ca-jdk11.0.13-linux_aarch32sf -prune -o -exec rm -rf '{}' ';'
+ return 0
+ rm -f /tmp/openhabian.noDLs
+ echo OK
OK
+ java_zulu_install Zulu11-32
+ local jdkBin
+ local jdkLib
++ find /opt/jdk/zulu11.52.13-ca-jdk11.0.13-linux_aarch32sf/bin ... -print -quit
+ jdkBin=/opt/jdk/zulu11.52.13-ca-jdk11.0.13-linux_aarch32sf/bin
++ find /opt/jdk/zulu11.52.13-ca-jdk11.0.13-linux_aarch32sf/lib ... -print -quit
+ jdkLib=/opt/jdk/zulu11.52.13-ca-jdk11.0.13-linux_aarch32sf/lib
++ timestamp
++ date +%F_%T_%Z
+ echo -n '2022-01-21_11:20:44_CET [openHABian] Installing Java Zulu 11 32-Bit OpenJDK... '
2022-01-21_11:20:44_CET [openHABian] Installing Java Zulu 11 32-Bit OpenJDK... + openhab_is_running
+ openhab_is_installed
+ openhab2_is_installed
++ dpkg -s openhab2
++ grep Status
++ cut '-d ' -f2
+ [[ deinstall == \i\n\s\t\a\l\l ]]
+ return 1
+ openhab3_is_installed
++ dpkg -s openhab
++ grep Status
++ cut '-d ' -f2
+ [[ install == \i\n\s\t\a\l\l ]]
+ return 0
+ return 0
++ systemctl is-active openhab
+ [[ activating == \a\c\t\i\v\e ]]
+ return 1
+ java_alternatives_reset
+ local jdkBin
+ cond_redirect find /opt/jdk/zulu11.52.13-ca-jdk11.0.13-linux_aarch32sf/bin -maxdepth 1 -perm -111 -type f -exec bash -c 'update-alternatives --quiet --remove-all $(basename {})' ';'
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ find /opt/jdk/zulu11.52.13-ca-jdk11.0.13-linux_aarch32sf/bin -maxdepth 1 -perm -111 -type f -exec bash -c update-alternatives --quiet --remove-all $(basename {}) ; \033[39;49;00m'
+ find /opt/jdk/zulu11.52.13-ca-jdk11.0.13-linux_aarch32sf/bin -maxdepth 1 -perm -111 -type f -exec bash -c 'update-alternatives --quiet --remove-all $(basename {})' ';'
+ return 0
+ cond_redirect find /opt/jdk/zulu11.52.13-ca-jdk11.0.13-linux_aarch32sf/bin -maxdepth 1 -perm -111 -type f -exec bash -c 'update-alternatives --install /usr/bin/$(basename {}) $(basename {}) {} 1000000' ';'
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ find /opt/jdk/zulu11.52.13-ca-jdk11.0.13-linux_aarch32sf/bin -maxdepth 1 -perm -111 -type f -exec bash -c update-alternatives --install /usr/bin/$(basename {}) $(basename {}) {} 1000000 ; \033[39;49;00m'
+ find /opt/jdk/zulu11.52.13-ca-jdk11.0.13-linux_aarch32sf/bin -maxdepth 1 -perm -111 -type f -exec bash -c 'update-alternatives --install /usr/bin/$(basename {}) $(basename {}) {} 1000000' ';'
update-alternatives: using /opt/jdk/zulu11.52.13-ca-jdk11.0.13-linux_aarch32sf/bin/jmap to provide /usr/bin/jmap (jmap) in auto mode
update-alternatives: using /opt/jdk/zulu11.52.13-ca-jdk11.0.13-linux_aarch32sf/bin/jps to provide /usr/bin/jps (jps) in auto mode
update-alternatives: using /opt/jdk/zulu11.52.13-ca-jdk11.0.13-linux_aarch32sf/bin/java to provide /usr/bin/java (java) in auto mode
update-alternatives: using /opt/jdk/zulu11.52.13-ca-jdk11.0.13-linux_aarch32sf/bin/jmod to provide /usr/bin/jmod (jmod) in auto mode
update-alternatives: using /opt/jdk/zulu11.52.13-ca-jdk11.0.13-linux_aarch32sf/bin/jstatd to provide /usr/bin/jstatd (jstatd) in auto mode
update-alternatives: using /opt/jdk/zulu11.52.13-ca-jdk11.0.13-linux_aarch32sf/bin/rmid to provide /usr/bin/rmid (rmid) in auto mode
update-alternatives: using /opt/jdk/zulu11.52.13-ca-jdk11.0.13-linux_aarch32sf/bin/jcmd to provide /usr/bin/jcmd (jcmd) in auto mode
update-alternatives: using /opt/jdk/zulu11.52.13-ca-jdk11.0.13-linux_aarch32sf/bin/serialver to provide /usr/bin/serialver (serialver) in auto mode
update-alternatives: using /opt/jdk/zulu11.52.13-ca-jdk11.0.13-linux_aarch32sf/bin/javadoc to provide /usr/bin/javadoc (javadoc) in auto mode
update-alternatives: using /opt/jdk/zulu11.52.13-ca-jdk11.0.13-linux_aarch32sf/bin/jshell to provide /usr/bin/jshell (jshell) in auto mode
update-alternatives: using /opt/jdk/zulu11.52.13-ca-jdk11.0.13-linux_aarch32sf/bin/pack200 to provide /usr/bin/pack200 (pack200) in auto mode
update-alternatives: using /opt/jdk/zulu11.52.13-ca-jdk11.0.13-linux_aarch32sf/bin/jstat to provide /usr/bin/jstat (jstat) in auto mode
update-alternatives: using /opt/jdk/zulu11.52.13-ca-jdk11.0.13-linux_aarch32sf/bin/jarsigner to provide /usr/bin/jarsigner (jarsigner) in auto mode
update-alternatives: using /opt/jdk/zulu11.52.13-ca-jdk11.0.13-linux_aarch32sf/bin/jdb to provide /usr/bin/jdb (jdb) in auto mode
update-alternatives: using /opt/jdk/zulu11.52.13-ca-jdk11.0.13-linux_aarch32sf/bin/jhsdb to provide /usr/bin/jhsdb (jhsdb) in auto mode
update-alternatives: using /opt/jdk/zulu11.52.13-ca-jdk11.0.13-linux_aarch32sf/bin/unpack200 to provide /usr/bin/unpack200 (unpack200) in auto mode
update-alternatives: using /opt/jdk/zulu11.52.13-ca-jdk11.0.13-linux_aarch32sf/bin/jdeprscan to provide /usr/bin/jdeprscan (jdeprscan) in auto mode
update-alternatives: using /opt/jdk/zulu11.52.13-ca-jdk11.0.13-linux_aarch32sf/bin/jjs to provide /usr/bin/jjs (jjs) in auto mode
update-alternatives: using /opt/jdk/zulu11.52.13-ca-jdk11.0.13-linux_aarch32sf/bin/jar to provide /usr/bin/jar (jar) in auto mode
update-alternatives: using /opt/jdk/zulu11.52.13-ca-jdk11.0.13-linux_aarch32sf/bin/jstack to provide /usr/bin/jstack (jstack) in auto mode
update-alternatives: using /opt/jdk/zulu11.52.13-ca-jdk11.0.13-linux_aarch32sf/bin/keytool to provide /usr/bin/keytool (keytool) in auto mode
update-alternatives: using /opt/jdk/zulu11.52.13-ca-jdk11.0.13-linux_aarch32sf/bin/jimage to provide /usr/bin/jimage (jimage) in auto mode
update-alternatives: using /opt/jdk/zulu11.52.13-ca-jdk11.0.13-linux_aarch32sf/bin/jconsole to provide /usr/bin/jconsole (jconsole) in auto mode
update-alternatives: using /opt/jdk/zulu11.52.13-ca-jdk11.0.13-linux_aarch32sf/bin/jrunscript to provide /usr/bin/jrunscript (jrunscript) in auto mode
update-alternatives: using /opt/jdk/zulu11.52.13-ca-jdk11.0.13-linux_aarch32sf/bin/jdeps to provide /usr/bin/jdeps (jdeps) in auto mode
update-alternatives: using /opt/jdk/zulu11.52.13-ca-jdk11.0.13-linux_aarch32sf/bin/jinfo to provide /usr/bin/jinfo (jinfo) in auto mode
update-alternatives: using /opt/jdk/zulu11.52.13-ca-jdk11.0.13-linux_aarch32sf/bin/rmiregistry to provide /usr/bin/rmiregistry (rmiregistry) in auto mode
update-alternatives: using /opt/jdk/zulu11.52.13-ca-jdk11.0.13-linux_aarch32sf/bin/jlink to provide /usr/bin/jlink (jlink) in auto mode
update-alternatives: using /opt/jdk/zulu11.52.13-ca-jdk11.0.13-linux_aarch32sf/bin/jfr to provide /usr/bin/jfr (jfr) in auto mode
update-alternatives: using /opt/jdk/zulu11.52.13-ca-jdk11.0.13-linux_aarch32sf/bin/javap to provide /usr/bin/javap (javap) in auto mode
update-alternatives: using /opt/jdk/zulu11.52.13-ca-jdk11.0.13-linux_aarch32sf/bin/javac to provide /usr/bin/javac (javac) in auto mode
update-alternatives: using /opt/jdk/zulu11.52.13-ca-jdk11.0.13-linux_aarch32sf/bin/rmic to provide /usr/bin/rmic (rmic) in auto mode
+ return 0
+ echo /opt/jdk/zulu11.52.13-ca-jdk11.0.13-linux_aarch32sf/lib
+ echo /opt/jdk/zulu11.52.13-ca-jdk11.0.13-linux_aarch32sf/lib/jli
+ echo /opt/jdk/zulu11.52.13-ca-jdk11.0.13-linux_aarch32sf/lib/client
+ ldconfig
+ echo OK
OK
+ java_zulu_install_crypto_extension
+ [[ -n '' ]]
+ local jdkSecurity
+ local policyTempLocation
++ realpath /usr/bin/java
++ sed 's|/java||'
+ jdkSecurity=/opt/jdk/zulu11.52.13-ca-jdk11.0.13-linux_aarch32sf/bin/../lib/security
++ mktemp -d /tmp/openhabian.XXXXX
+ policyTempLocation=/tmp/openhabian.wIpBf
++ timestamp
++ date +%F_%T_%Z
+ echo -n '2022-01-21_11:20:47_CET [openHABian] Installing Java Zulu CEK to enable unlimited cipher strength... '
2022-01-21_11:20:47_CET [openHABian] Installing Java Zulu CEK to enable unlimited cipher strength... + cond_redirect mkdir -p /opt/jdk/zulu11.52.13-ca-jdk11.0.13-linux_aarch32sf/bin/../lib/security
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ mkdir -p /opt/jdk/zulu11.52.13-ca-jdk11.0.13-linux_aarch32sf/bin/../lib/security \033[39;49;00m'
+ mkdir -p /opt/jdk/zulu11.52.13-ca-jdk11.0.13-linux_aarch32sf/bin/../lib/security
+ return 0
+ cond_redirect wget -qO /tmp/openhabian.wIpBf/crypto.zip https://cdn.azul.com/zcek/bin/ZuluJCEPolicies.zip
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ wget -qO /tmp/openhabian.wIpBf/crypto.zip https://cdn.azul.com/zcek/bin/ZuluJCEPolicies.zip \033[39;49;00m'
+ wget -qO /tmp/openhabian.wIpBf/crypto.zip https://cdn.azul.com/zcek/bin/ZuluJCEPolicies.zip
+ return 0
+ cond_redirect unzip /tmp/openhabian.wIpBf/crypto.zip -d /tmp/openhabian.wIpBf
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ unzip /tmp/openhabian.wIpBf/crypto.zip -d /tmp/openhabian.wIpBf \033[39;49;00m'
+ unzip /tmp/openhabian.wIpBf/crypto.zip -d /tmp/openhabian.wIpBf
Archive: /tmp/openhabian.wIpBf/crypto.zip
creating: /tmp/openhabian.wIpBf/ZuluJCEPolicies/
inflating: /tmp/openhabian.wIpBf/ZuluJCEPolicies/LICENSE
inflating: /tmp/openhabian.wIpBf/ZuluJCEPolicies/README.txt
inflating: /tmp/openhabian.wIpBf/ZuluJCEPolicies/DISCLAIMER
inflating: /tmp/openhabian.wIpBf/ZuluJCEPolicies/local_policy.jar
inflating: /tmp/openhabian.wIpBf/ZuluJCEPolicies/US_export_policy.jar
+ return 0
+ cond_redirect cp -u /tmp/openhabian.wIpBf/ZuluJCEPolicies/local_policy.jar /tmp/openhabian.wIpBf/ZuluJCEPolicies/US_export_policy.jar /opt/jdk/zulu11.52.13-ca-jdk11.0.13-linux_aarch32sf/bin/../lib/security
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ cp -u /tmp/openhabian.wIpBf/ZuluJCEPolicies/local_policy.jar /tmp/openhabian.wIpBf/ZuluJCEPolicies/US_export_policy.jar /opt/jdk/zulu11.52.13-ca-jdk11.0.13-linux_aarch32sf/bin/../lib/security \033[39;49;00m'
+ cp -u /tmp/openhabian.wIpBf/ZuluJCEPolicies/local_policy.jar /tmp/openhabian.wIpBf/ZuluJCEPolicies/US_export_policy.jar /opt/jdk/zulu11.52.13-ca-jdk11.0.13-linux_aarch32sf/bin/../lib/security
+ return 0
+ echo OK
OK
+ cond_redirect rm -rf /tmp/openhabian.wIpBf
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ rm -rf /tmp/openhabian.wIpBf \033[39;49;00m'
+ rm -rf /tmp/openhabian.wIpBf
+ return 0
++ dpkg -s openhab2
++ grep Status
++ cut '-d ' -f2
+ return 1
++ dpkg -s openhab
++ grep Status
++ cut '-d ' -f2
+ return 0
+ return 0
+ cond_redirect systemctl restart openhab.service
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ systemctl restart openhab.service \033[39;49;00m'
I don’t see why it is not installing…
Wolfgang_S
(Wolfgang_S)
January 21, 2022, 11:49am
3
according to debug output java is installed.
Do you still get the error message about shared library ?
Stehof
(Stéphane Hofman)
January 21, 2022, 11:52am
4
Thanks for the quick reply, and yes, stil get that error unfortunately…
Is it maybe because I’m still on Linux 9 and Java Zulu 11 isn’t supported?
Wolfgang_S
(Wolfgang_S)
January 21, 2022, 12:02pm
5
Java should be in /opt/jdk/zulu11.52.13-ca-jdk11.0.13-linux_aarch32sf/ right ?
What is the output of ls -ld /opt/jdk/zulu11.52.13-ca-jdk11.0.13-linux_aarch32sf/lib/jli/libjli*
In case libjli.so is in that directory run command ldd on that so file.
ldd /path-to/libjli.so
( path-to needs to be replaced )
What is the output ?
In case the executable was created for Buster then it might not run on Stretch.
The error message so far looks like the so file would not be there but it also could be that this is because of problems with dependencies to other libs. Above commands hopefully will give more insight.
Stehof
(Stéphane Hofman)
January 21, 2022, 12:19pm
6
Yes, /opt/jdk/zulu11.52.13-ca-jdk11.0.13-linux_aarch32sf/ seems to be the right place.
**openhabian@openHABianPi**:**~ $** ls -ld /opt/jdk/zulu11.52.13-ca-jdk11.0.13-linux_aarch32sf/lib/jli/libjli*
-rw-rw-r-- 1 grafana 122 110692 Oct 9 09:53 /opt/jdk/zulu11.52.13-ca-jdk11.0.13-linux_aarch32sf/lib/jli/libjli.so
This is the output, so I run:
sudo ldd /opt/jdk/zulu11.52.13-ca-jdk11.0.13-linux_aarch32sf/lib/jli/libjli.so
Output:
not a dynamic executable
Wolfgang_S
(Wolfgang_S)
January 21, 2022, 12:23pm
7
interesting here I get something different for an earlier version.
What do you get back in case you run the command “file” on the same libjli.so file ( instead of ldd ) ?
Stehof
(Stéphane Hofman)
January 21, 2022, 12:25pm
8
When I do that, I get:
/opt/jdk/zulu11.52.13-ca-jdk11.0.13-linux_aarch32sf/lib/jli/libjli.so: ELF 32-bit LSB shared object, ARM, EABI5 version 1 (SYSV), dynamically linked, not stripped
Wolfgang_S
(Wolfgang_S)
January 21, 2022, 12:30pm
9
Ok. It is a share library object as .so should be.
Strange that the ldd command does not show relations to other files like libc as it has to be.
Root cause is either that you are on stretch or that it is aarch32sf.
Please check here openhab doesn't start because Java · Issue #874 · openhab/openhabian · GitHub ( haven’t read the complete entry )
Wolfgang_S
(Wolfgang_S)
January 21, 2022, 1:11pm
10
Stehof
(Stéphane Hofman)
January 21, 2022, 1:49pm
11
I checked which version wants to install when I use “sudo openhabian-config” and select to upgrade/update, that is the exact same version.
Will a manual install make any difference you think?
Wolfgang_S
(Wolfgang_S)
January 21, 2022, 2:39pm
12
You mean the sf version ?
as long as the root cause is that sf instead of hf is being installed - yes.
In case the root cause is that your are still on stretch then - the test will show.
Stehof
(Stéphane Hofman)
January 21, 2022, 5:37pm
13
Yes.
I’m not that familiar with this kind of installations, can you gives some instructions how I could install this HF version?
Stehof
(Stéphane Hofman)
January 21, 2022, 8:24pm
15
Little side note, I had a RPi 4 laying around so I installed a fresh install of OH3 openhabian on that one and restored my config and moved everything over there, so every thing is up and running again.
But the trouble instance is also still running, so I tried your suggestion, but no luck:
**[21:18:17]** **root@openHABianPi**:**/home/openhabian**# cd /tmp
**[21:18:22]** **root@openHABianPi**:**/tmp**# wget https://cdn.azul.com/zulu-embedded/bin/zulu11.52.13-ca-jdk11.0.13-linux_aarch32hf.tar.gz
--2022-01-21 21:18:47-- https://cdn.azul.com/zulu-embedded/bin/zulu11.52.13-ca-jdk11.0.13-linux_aarch32hf.tar.gz
Resolving cdn.azul.com (cdn.azul.com)... 104.18.20.159, 104.18.21.159
Connecting to cdn.azul.com (cdn.azul.com)|104.18.20.159|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 178232271 (170M) [application/gzip]
Saving to: ‘zulu11.52.13-ca-jdk11.0.13-linux_aarch32hf.tar.gz’
zulu11.52.13-ca-jdk 100%[===================>] 169.97M 7.57MB/s in 18s
2022-01-21 21:19:05 (9.22 MB/s) - ‘zulu11.52.13-ca-jdk11.0.13-linux_aarch32hf.tar.gz’ saved [178232271/178232271]
**[21:19:05]** **root@openHABianPi**:**/tmp**# tar -xpzf /tmp/zulu11.52.13-ca-jdk11.0.13-linux_aarch32hf.tar.gz -C /opt/jdk
**[21:20:26]** **root@openHABianPi**:**/tmp**# cd /opt/jdk
**[21:20:40]** **root@openHABianPi**:**/opt/jdk**# java -version
Want to try to fix it to learn from it
Wolfgang_S
(Wolfgang_S)
January 21, 2022, 8:37pm
16
cd into /opt/jdk/zulu11.52.13-ca-jdk11.0.13-linux_aarch32hf/bin
there try ./java --version.
As update-alternatives was not called java --version is being called from the other directory via using the search path. This version is not yet in the search path so it was not found.
CDing into the directory and using ./ in front of the executable to be executed will find it.
Stehof
(Stéphane Hofman)
January 22, 2022, 9:19am
17
Ah ok, that seem to do the trick:
**openhabian@openHABianPi**:**/opt/jdk/zulu11.52.13-ca-jdk11.0.13-linux_aarch32hf/bin $** ./java -version
openjdk version "11.0.13" 2021-10-19 LTS
OpenJDK Runtime Environment Zulu11.52+13-CA (build 11.0.13+8-LTS)
OpenJDK Client VM Zulu11.52+13-CA (build 11.0.13+8-LTS, mixed mode)
Now Java is up and running again, I should expect everything was working again, but I can’t even open the webGUI
Stehof
(Stéphane Hofman)
January 22, 2022, 3:06pm
19
openhabian@openHABianPi:~ $ sudo systemctl status openhab
● openhab.service - openHAB - empowering the smart home
Loaded: loaded (/usr/lib/systemd/system/openhab.service; enabled; vendor preset: enabled)
Active: deactivating (stop) (Result: exit-code) since Sat 2022-01-22 16:01:15 CET; 84ms ago
Docs: https://www.openhab.org/docs/
https://community.openhab.org
Process: 5066 ExecStart=/usr/share/openhab/runtime/bin/karaf ${OPENHAB_STARTMODE} (code=exited, status=127)
Main PID: 5066 (code=exited, status=127); Control PID: 5137 (karaf)
Tasks: 4 (limit: 4915)
CGroup: /system.slice/openhab.service
└─control
├─5137 /bin/sh /usr/share/openhab/runtime/bin/karaf stop
├─5159 /bin/sh /usr/share/openhab/runtime/bin/karaf stop
├─5160 /bin/sh /usr/share/openhab/runtime/bin/karaf stop
├─5161 /bin/sh /usr/share/openhab/runtime/bin/karaf stop
└─5166 ls -ld /etc/alternatives/java
Jan 22 16:01:14 openHABianPi systemd[1]: Started openHAB - empowering the smart home.
Jan 22 16:01:14 openHABianPi karaf[5066]: /usr/share/openhab/runtime/bin/karaf: 247: [: Illegal number:
Jan 22 16:01:14 openHABianPi karaf[5066]: /usr/share/openhab/runtime/bin/karaf: 97: [: Illegal number:
Jan 22 16:01:14 openHABianPi karaf[5066]: /usr/share/openhab/runtime/bin/karaf: 300: [: Illegal number:
Jan 22 16:01:15 openHABianPi systemd[1]: openhab.service: Main process exited, code=exited, status=127/n/a
2022-01-21 13:52:23.051 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-persistence-mapdb, openhab-voice-voicerss, openhab-binding-tado, openhab-transformation-javascript, openhab-binding-network, openhab-persistence-influxdb, openhab-binding-sonos, openhab-transformation-regex, openhab-ui-habpanel, openhab-binding-dsmr, openhab-transformation-jsonpath, openhab-binding-zigbee, openhab-binding-zoneminder, openhab-automation-jythonscripting, openhab-binding-mqtt, openhab-ui-basic, openhab-binding-lgwebos, openhab-misc-homekit, openhab-binding-openweathermap, openhab-binding-astro, openhab-binding-telegram, openhab-binding-unifi, openhab-binding-gpstracker, openhab-binding-systeminfo': null
I restarted and checked the logging, it only loaded the rules and ended with the above error.
Nothing returned…
For now, it is not necessary yet
Root = Free: 20.05GB (71%), Used: 7.92GB (29%), Total: 29.19GB
Wolfgang_S
(Wolfgang_S)
January 22, 2022, 4:03pm
20
Because of problems during start procedure of karaf java stops to work and thus netstat does not return any line of content. As java does not run any longer there is no port opened that can be used to connect from a browser …
Does
sudo journalctl -u openhab -b
provide more information ?
