I got a little problem, when I upgrade from mqtt 1 to mqtt 2:
After upgrade to mqtt 2 I see on basic ui for every item with relationship to mqtt channels the textual / numerical state, but I don’t want to see this (see example below):
Please show the definition lines for the items and the related lines of the sitemap. I deliberately wanted to see such values and have added [%s] to the sitemap label.
Can’t find the related threads for this one (not a MQTT problem!), please try to add empty squared brackets [] to the label. I have defined at the sitemap line!
additional Information:
when I integrate a roller shutter item, that have no relationship to a mqtt channel in items list (it only triggers e.g. a rule), I see no textual / numerical state in Basic UI ! Same with switches.
