[SOLVED] Update to SNAPSHOT #1597 (and later) partially failed (AllPlay(=SOLVED), AmazonDashButton(=SOLVED), wrapper service(=SOLVED), Z-Wave(=SOLVED))
No, it doesn’t. I’ve tested all above mentioned versions. No success.
Btw, npcap version 0.0.5 is from 28 Nov 2015 !! And the other above mentioned versions are obsolete as well.
With the latest npcap I always get:
19:48:34.403 [WARN ] [org.pcap4j.util.PropertiesLoader     ] - [org/pcap4j/pcap4j.properties] Could not get value by org.pcap4j.af.inet, use default value: null
19:48:34.405 [WARN ] [org.pcap4j.util.PropertiesLoader     ] - [org/pcap4j/pcap4j.properties] Could not get value by org.pcap4j.af.inet6, use default value: null
19:48:34.406 [WARN ] [org.pcap4j.util.PropertiesLoader     ] - [org/pcap4j/pcap4j.properties] Could not get value by org.pcap4j.af.packet, use default value: null
19:48:34.407 [WARN ] [org.pcap4j.util.PropertiesLoader     ] - [org/pcap4j/pcap4j.properties] Could not get value by org.pcap4j.af.link, use default value: null
19:48:34.495 [WARN ] [org.pcap4j.util.PropertiesLoader     ] - [org/pcap4j/pcap4j.properties] Could not get value by org.pcap4j.dlt.raw, use default value: null
19:48:35.128 [WARN ] [pcap4j.packet.factory.PacketFactories] - java.lang.NoClassDefFoundError:org/pcap4j/packet/factory/PacketFactoryBinder
But it was running with all kind of versions, beginning from 0.80 until 0.9982 with snapshot 1486 AND before.
And it stops working, after ESH core was re-implemented into OH. But I don’t know when it stopped.
See also this topic, from Feb 07 2017.
There I used the latest available version (0.80) of npcap. And after 0.80 all kind of newer versions.
Important for me is: Raw 802.11 Packet Capture, because I use a Wifi adapter, only.
