Update to SNAPSHOT #1597 partially failed (AllPlay(=SOLVED), AmazonDashButton, wrapper service, Z-Wave(=SOLVED))
Tags: #<Tag:0x00007f74537f2410> #<Tag:0x00007f74537f2348> #<Tag:0x00007f74537f2258>
  • Platform information:
    • Hardware: Intel Atom PC-Stick
    • OS: Win 10 Home, 32 bit
    • Java Runtime Environment: Oracle jdk1.8.0_161
    • openHAB version: Update from SNAPSHOT #1486 to SNAPSHOT #1597
  • Issue of the topic: update partially failed: AllPlay, AmazonDashButton, Z-Wave, wrapper service
Hello folks!
I’ve updated from SNAPSHOT #1486 to SNAPSHOT #1597
using exactly this manual (as many times before, with success): Link
Nearly everything is running again, but: AllPlay, AmazonDashButton, Z-Wave, wrapper service
Z-Wave(=SOLVED) See here:
Here are my steps:
Installed z-wave binding (thru addons.cfg)
Everything is running fine
Stopped OH-Service
Restarted OH Hardware
Started OH-Service
WARNING: No SerialPortProvider found for: COM4
ERROR: Controller is offline to OFFLINE (COMMUNICATION_ERROR): Serial Error: Port {0} does not exist
Changed (with HABmin) controller from serial port COM4 to COM3 and back to COM4
Controller is running again.
After restarting of OH-Hardware --> SAME ERROR AGAIN
2019-05-21 18:34:37.495 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Connecting to serial port 'COM4'
2019-05-21 18:34:37.611 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Serial port is initialized
2019-05-21 18:34:37.689 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
2019-05-21 18:34:37.689 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
2019-05-21 18:34:43.807 [thome.event.ExtensionEvent] - Extension 'binding-zwave' has been installed.
2019-05-21 18:34:53.125 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:f7e29c6d' changed from UNINITIALIZED to INITIALIZING
2019-05-21 18:34:53.163 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:f7e29c6d' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2019-05-21 18:34:53.211 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node7' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2019-05-21 18:34:53.239 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node8' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2019-05-21 18:34:53.288 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node9' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2019-05-21 18:34:53.316 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node13' changed from UNINITIALIZED to INITIALIZING
2019-05-21 18:34:53.354 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node12' changed from UNINITIALIZED to INITIALIZING
2019-05-21 18:34:53.413 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node12' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2019-05-21 18:34:53.447 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node9' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2019-05-21 18:34:53.497 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node8' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2019-05-21 18:34:53.528 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node7' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2019-05-21 18:34:53.570 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node13' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2019-05-21 18:34:53.610 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node5' changed from UNINITIALIZED to INITIALIZING
2019-05-21 18:34:53.652 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node6' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2019-05-21 18:34:53.772 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node2' changed from UNINITIALIZED to INITIALIZING
2019-05-21 18:34:53.812 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node3' changed from UNINITIALIZED to INITIALIZING
2019-05-21 18:34:53.850 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node3' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2019-05-21 18:34:53.891 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node5' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2019-05-21 18:34:53.937 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node6' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2019-05-21 18:34:53.984 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node2' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2019-05-21 18:35:04.947 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:f7e29c6d' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2019-05-21 18:35:05.011 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node12' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2019-05-21 18:35:05.094 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node9' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2019-05-21 18:35:05.160 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node7' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2019-05-21 18:35:05.223 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node8' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2019-05-21 18:35:05.486 [me.event.ThingUpdatedEvent] - Thing 'zwave:serial_zstick:f7e29c6d' has been updated.
2019-05-21 18:35:05.513 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node13' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2019-05-21 18:35:05.577 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node5' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2019-05-21 18:35:05.609 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node6' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2019-05-21 18:35:05.657 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node3' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2019-05-21 18:35:05.721 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node2' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2019-05-21 18:35:13.395 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node12' changed from ONLINE to ONLINE: Node initialising: REQUEST_NIF
2019-05-21 18:35:13.462 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node2' changed from ONLINE to ONLINE: Node initialising: REQUEST_NIF
2019-05-21 18:35:13.529 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node9' changed from ONLINE to ONLINE: Node initialising: REQUEST_NIF
2019-05-21 18:35:13.619 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node5' changed from ONLINE to ONLINE: Node initialising: REQUEST_NIF
2019-05-21 18:35:13.719 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node8' changed from ONLINE to ONLINE: Node initialising: REQUEST_NIF
2019-05-21 18:35:13.841 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node6' changed from ONLINE to ONLINE: Node initialising: REQUEST_NIF
2019-05-21 18:35:35.465 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node2' changed from ONLINE: Node initialising: REQUEST_NIF to ONLINE
2019-05-21 18:35:35.879 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node5' changed from ONLINE: Node initialising: REQUEST_NIF to ONLINE
2019-05-21 18:35:35.974 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node8' changed from ONLINE: Node initialising: REQUEST_NIF to ONLINE
2019-05-21 18:35:36.097 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node6' changed from ONLINE: Node initialising: REQUEST_NIF to ONLINE
2019-05-21 18:35:36.148 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node12' changed from ONLINE: Node initialising: REQUEST_NIF to ONLINE
SHUTDOWN OH-Service
2019-05-21 19:00:24.838 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node3' changed from ONLINE to UNINITIALIZED
2019-05-21 19:00:24.871 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node3' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2019-05-21 19:00:24.904 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node9' changed from ONLINE: Node initialising: REQUEST_NIF to UNINITIALIZED
2019-05-21 19:00:24.936 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node9' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2019-05-21 19:00:24.969 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node8' changed from ONLINE to UNINITIALIZED
2019-05-21 19:00:25.002 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node8' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2019-05-21 19:00:25.035 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node12' changed from ONLINE to UNINITIALIZED
2019-05-21 19:00:25.077 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node6' changed from ONLINE to UNINITIALIZED
2019-05-21 19:00:25.101 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node12' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2019-05-21 19:00:25.134 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node6' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2019-05-21 19:00:25.167 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node2' changed from ONLINE to UNINITIALIZED
2019-05-21 19:00:25.201 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node2' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2019-05-21 19:00:25.233 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node13' changed from ONLINE to UNINITIALIZED
2019-05-21 19:00:25.266 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node13' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2019-05-21 19:00:25.299 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node5' changed from ONLINE to UNINITIALIZED
2019-05-21 19:00:25.332 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node5' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2019-05-21 19:00:25.365 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node7' changed from ONLINE to UNINITIALIZED
2019-05-21 19:00:25.399 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node7' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2019-05-21 19:00:25.432 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:f7e29c6d' changed from ONLINE to UNINITIALIZED
2019-05-21 19:00:25.699 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Stopped ZWave serial handler
2019-05-21 19:00:25.739 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:f7e29c6d' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
RESTART OPENHAB HARDWARE
2019-05-21 19:07:14.496 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node8' changed from UNINITIALIZED to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2019-05-21 19:07:14.605 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node9' changed from UNINITIALIZED to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2019-05-21 19:07:14.637 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Connecting to serial port 'COM4'
2019-05-21 19:07:14.637 [WARN ] [erial.internal.SerialPortManagerImpl] - No SerialPortProvider found for: COM4
2019-05-21 19:07:14.762 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node6' changed from UNINITIALIZED to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2019-05-21 19:07:14.871 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node7' changed from UNINITIALIZED to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2019-05-21 19:07:17.449 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:f7e29c6d' changed from UNINITIALIZED to INITIALIZING
2019-05-21 19:07:17.496 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:f7e29c6d' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2019-05-21 19:07:17.574 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:f7e29c6d' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to OFFLINE (COMMUNICATION_ERROR): Serial Error: Port {0} does not exist
2019-05-21 19:07:17.636 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node13' changed from UNINITIALIZED to INITIALIZING
2019-05-21 19:07:17.715 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node13' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2019-05-21 19:07:17.761 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node5' changed from UNINITIALIZED to INITIALIZING
2019-05-21 19:07:17.808 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node5' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2019-05-21 19:07:19.621 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node2' changed from UNINITIALIZED to INITIALIZING
2019-05-21 19:07:19.621 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node2' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2019-05-21 19:07:19.636 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node3' changed from UNINITIALIZED to INITIALIZING
2019-05-21 19:07:19.761 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node3' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2019-05-21 19:07:19.761 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node12' changed from UNINITIALIZED to INITIALIZING
2019-05-21 19:07:19.871 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node12' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2019-05-21 19:07:19.871 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node9' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2019-05-21 19:07:19.871 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node8' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2019-05-21 19:07:19.871 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node6' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2019-05-21 19:07:19.871 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node7' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2019-05-21 19:07:19.886 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node9' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2019-05-21 19:07:19.902 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node8' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2019-05-21 19:07:19.902 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node6' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2019-05-21 19:07:19.902 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node7' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2019-05-21 19:13:21.111 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Stopped ZWave serial handler
2019-05-21 19:13:21.127 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Connecting to serial port 'COM3'
2019-05-21 19:13:21.127 [me.event.ThingUpdatedEvent] - Thing 'zwave:serial_zstick:f7e29c6d' has been updated.
2019-05-21 19:13:21.230 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:f7e29c6d' changed from OFFLINE (COMMUNICATION_ERROR): Serial Error: Port {0} does not exist to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2019-05-21 19:13:21.245 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Serial port is initialized
2019-05-21 19:13:21.339 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
2019-05-21 19:13:21.339 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
2019-05-21 19:14:20.749 [me.event.ThingUpdatedEvent] - Thing 'zwave:serial_zstick:f7e29c6d' has been updated.
2019-05-21 19:14:23.759 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Stopped ZWave serial handler
2019-05-21 19:14:23.776 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Connecting to serial port 'COM4'
2019-05-21 19:14:23.796 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Serial port is initialized
2019-05-21 19:14:23.801 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
2019-05-21 19:14:23.804 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
2019-05-21 19:14:28.158 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:f7e29c6d' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2019-05-21 19:14:28.236 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node13' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2019-05-21 19:14:28.280 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node9' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2019-05-21 19:14:28.353 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node12' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2019-05-21 19:14:28.393 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node7' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2019-05-21 19:14:28.443 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node8' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2019-05-21 19:14:28.462 [me.event.ThingUpdatedEvent] - Thing 'zwave:serial_zstick:f7e29c6d' has been updated.
2019-05-21 19:14:28.526 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node7' changed from ONLINE to ONLINE: Node initialising: REQUEST_NIF
2019-05-21 19:14:28.564 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node8' changed from ONLINE to ONLINE: Node initialising: REQUEST_NIF
2019-05-21 19:14:28.614 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node13' changed from ONLINE to ONLINE: Node initialising: REQUEST_NIF
2019-05-21 19:14:28.743 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node9' changed from ONLINE to ONLINE: Node initialising: REQUEST_NIF
2019-05-21 19:14:28.783 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node12' changed from ONLINE to ONLINE: Node initialising: PING
2019-05-21 19:14:28.845 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node5' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2019-05-21 19:14:28.882 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node3' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2019-05-21 19:14:28.932 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node6' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2019-05-21 19:14:28.985 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node2' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2019-05-21 19:15:01.862 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node7' changed from ONLINE: Node initialising: REQUEST_NIF to ONLINE
2019-05-21 19:15:03.277 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node8' changed from ONLINE: Node initialising: REQUEST_NIF to ONLINE
2019-05-21 19:15:13.891 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node12' changed from ONLINE: Node initialising: PING to ONLINE: Node initialising: REQUEST_NIF
2019-05-21 19:15:14.174 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node12' changed from ONLINE: Node initialising: REQUEST_NIF to ONLINE
2019-05-21 19:50:02.883 [me.event.ThingUpdatedEvent] - Thing 'zwave:device:f7e29c6d:node9' has been updated.
2019-05-21 19:50:03.502 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node9' changed from ONLINE: Node initialising: REQUEST_NIF to ONLINE
2019-05-21 20:03:56.163 [hingStatusInfoChangedEvent] - 'zwave:device:f7e29c6d:node13' changed from ONLINE: Node initialising: REQUEST_NIF to UNINITIALIZED
2019-05-21 20:03:56.611 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Stopped ZWave serial handler
AllPlay:
After installing allplay (thru addons.cfg):
Error: Could not initialize class de.kaizencode.tchaikovsky.AllPlay
bundle:list --> Status of binding: waiting
Uninstalled binding and re-installed binding, same errors!
2019-05-21 18:34:43.709 [thome.event.ExtensionEvent] - Extension 'binding-allplay' has been installed.
2019-05-21 18:43:02.333 [ERROR] [org.openhab.binding.allplay         ] - bundle org.openhab.binding.allplay:2.5.0.201905191752 (227)[org.openhab.binding.allplay.internal.AllPlayHandlerFactory(323)] : The activate method has thrown an exception
java.lang.NoClassDefFoundError: Could not initialize class de.kaizencode.tchaikovsky.AllPlay
	at org.openhab.binding.allplay.internal.AllPlayHandlerFactory.activate(AllPlayHandlerFactory.java:109) ~[?:?]
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
	at org.apache.felix.scr.impl.inject.methods.BaseMethod.invokeMethod(BaseMethod.java:228) ~[44:org.apache.felix.scr:2.1.16]
	at org.apache.felix.scr.impl.inject.methods.BaseMethod.access$500(BaseMethod.java:41) ~[44:org.apache.felix.scr:2.1.16]
	at org.apache.felix.scr.impl.inject.methods.BaseMethod$Resolved.invoke(BaseMethod.java:664) ~[44:org.apache.felix.scr:2.1.16]
	at org.apache.felix.scr.impl.inject.methods.BaseMethod.invoke(BaseMethod.java:510) [44:org.apache.felix.scr:2.1.16]
	at org.apache.felix.scr.impl.inject.methods.ActivateMethod.invoke(ActivateMethod.java:317) [44:org.apache.felix.scr:2.1.16]
	at org.apache.felix.scr.impl.inject.methods.ActivateMethod.invoke(ActivateMethod.java:307) [44:org.apache.felix.scr:2.1.16]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(SingleComponentManager.java:340) [44:org.apache.felix.scr:2.1.16]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.createComponent(SingleComponentManager.java:114) [44:org.apache.felix.scr:2.1.16]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:982) [44:org.apache.felix.scr:2.1.16]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:955) [44:org.apache.felix.scr:2.1.16]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:900) [44:org.apache.felix.scr:2.1.16]
	at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$1.run(ServiceFactoryUse.java:212) [?:?]
	at java.security.AccessController.doPrivileged(Native Method) ~[?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:210) [?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:111) [?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:45) [?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:508) [?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:461) [?:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:624) [?:?]
	at org.apache.felix.scr.impl.manager.SingleRefPair.getServiceObject(SingleRefPair.java:86) [44:org.apache.felix.scr:2.1.16]
	at org.apache.felix.scr.impl.inject.BindParameters.getServiceObject(BindParameters.java:47) [44:org.apache.felix.scr:2.1.16]
	at org.apache.felix.scr.impl.inject.methods.BindMethod.getServiceObject(BindMethod.java:664) [44:org.apache.felix.scr:2.1.16]
	at org.apache.felix.scr.impl.manager.DependencyManager.getServiceObject(DependencyManager.java:2308) [44:org.apache.felix.scr:2.1.16]
	at org.apache.felix.scr.impl.manager.DependencyManager.invokeUnbindMethod(DependencyManager.java:1919) [44:org.apache.felix.scr:2.1.16]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.invokeUnbindMethod(SingleComponentManager.java:458) [44:org.apache.felix.scr:2.1.16]
	at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.removedService(DependencyManager.java:382) [44:org.apache.felix.scr:2.1.16]
	at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.removedService(DependencyManager.java:294) [44:org.apache.felix.scr:2.1.16]
	at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerRemoved(ServiceTracker.java:1242) [44:org.apache.felix.scr:2.1.16]
	at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerRemoved(ServiceTracker.java:1137) [44:org.apache.felix.scr:2.1.16]
	at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.untrack(ServiceTracker.java:997) [44:org.apache.felix.scr:2.1.16]
	at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1176) [44:org.apache.felix.scr:2.1.16]
	at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:125) [44:org.apache.felix.scr:2.1.16]
	at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109) [?:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:920) [?:?]
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [?:?]
	at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) [?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862) [?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801) [?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.unregister(ServiceRegistrationImpl.java:222) [?:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.unregister(AbstractComponentManager.java:927) [44:org.apache.felix.scr:2.1.16]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.unregister(AbstractComponentManager.java:892) [44:org.apache.felix.scr:2.1.16]
	at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:135) [44:org.apache.felix.scr:2.1.16]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.unregisterService(AbstractComponentManager.java:969) [44:org.apache.felix.scr:2.1.16]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.doDeactivate(AbstractComponentManager.java:823) [44:org.apache.felix.scr:2.1.16]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.deactivateInternal(AbstractComponentManager.java:805) [44:org.apache.felix.scr:2.1.16]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.dispose(AbstractComponentManager.java:584) [44:org.apache.felix.scr:2.1.16]
	at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.disposeComponents(ConfigurableComponentHolder.java:716) [44:org.apache.felix.scr:2.1.16]
	at org.apache.felix.scr.impl.BundleComponentActivator.dispose(BundleComponentActivator.java:510) [44:org.apache.felix.scr:2.1.16]
	at org.apache.felix.scr.impl.Activator.disposeComponents(Activator.java:429) [44:org.apache.felix.scr:2.1.16]
	at org.apache.felix.scr.impl.Activator.access$300(Activator.java:49) [44:org.apache.felix.scr:2.1.16]
	at org.apache.felix.scr.impl.Activator$ScrExtension.destroy(Activator.java:292) [44:org.apache.felix.scr:2.1.16]
	at org.apache.felix.scr.impl.AbstractExtender$1.run(AbstractExtender.java:216) [44:org.apache.felix.scr:2.1.16]
	at org.apache.felix.scr.impl.AbstractExtender.destroyExtension(AbstractExtender.java:238) [44:org.apache.felix.scr:2.1.16]
	at org.apache.felix.scr.impl.AbstractExtender.bundleChanged(AbstractExtender.java:132) [44:org.apache.felix.scr:2.1.16]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:908) [?:?]
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213) [?:?]
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120) [?:?]
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112) [?:?]
	at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:168) [?:?]
	at org.eclipse.osgi.container.Module.publishEvent(Module.java:476) [?:?]
	at org.eclipse.osgi.container.Module.doStop(Module.java:634) [?:?]
	at org.eclipse.osgi.container.Module.stop(Module.java:498) [?:?]
	at org.eclipse.osgi.internal.framework.EquinoxBundle.stop(EquinoxBundle.java:410) [?:?]
	at org.apache.karaf.bundle.command.Stop.executeOnBundle(Stop.java:38) [47:org.apache.karaf.bundle.core:4.2.4]
	at org.apache.karaf.bundle.command.BundlesCommand.doExecute(BundlesCommand.java:65) [47:org.apache.karaf.bundle.core:4.2.4]
	at org.apache.karaf.bundle.command.BundlesCommand.execute(BundlesCommand.java:55) [47:org.apache.karaf.bundle.core:4.2.4]
	at org.apache.karaf.shell.impl.action.command.ActionCommand.execute(ActionCommand.java:84) [16:org.apache.karaf.shell.core:4.2.4]
	at org.apache.karaf.shell.impl.console.osgi.secured.SecuredCommand.execute(SecuredCommand.java:68) [16:org.apache.karaf.shell.core:4.2.4]
	at org.apache.karaf.shell.impl.console.osgi.secured.SecuredCommand.execute(SecuredCommand.java:86) [16:org.apache.karaf.shell.core:4.2.4]
	at org.apache.felix.gogo.runtime.Closure.executeCmd(Closure.java:599) [16:org.apache.karaf.shell.core:4.2.4]
	at org.apache.felix.gogo.runtime.Closure.executeStatement(Closure.java:526) [16:org.apache.karaf.shell.core:4.2.4]
	at org.apache.felix.gogo.runtime.Closure.execute(Closure.java:415) [16:org.apache.karaf.shell.core:4.2.4]
	at org.apache.felix.gogo.runtime.Pipe.doCall(Pipe.java:416) [16:org.apache.karaf.shell.core:4.2.4]
	at org.apache.felix.gogo.runtime.Pipe.call(Pipe.java:229) [16:org.apache.karaf.shell.core:4.2.4]
	at org.apache.felix.gogo.runtime.Pipe.call(Pipe.java:59) [16:org.apache.karaf.shell.core:4.2.4]
2019-05-21 18:43:02.356 [WARN ] [org.openhab.binding.allplay         ] - FrameworkEvent WARNING - org.openhab.binding.allplay
org.osgi.framework.ServiceException: org.apache.felix.scr.impl.manager.SingleComponentManager.getService() returned a null service object
	at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:232) ~[?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:111) ~[?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:45) ~[?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:508) ~[?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:461) ~[?:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:624) ~[?:?]
	at org.apache.felix.scr.impl.manager.SingleRefPair.getServiceObject(SingleRefPair.java:86) ~[?:?]
	at org.apache.felix.scr.impl.inject.BindParameters.getServiceObject(BindParameters.java:47) ~[?:?]
	at org.apache.felix.scr.impl.inject.methods.BindMethod.getServiceObject(BindMethod.java:664) ~[?:?]
	at org.apache.felix.scr.impl.manager.DependencyManager.getServiceObject(DependencyManager.java:2308) ~[?:?]
	at org.apache.felix.scr.impl.manager.DependencyManager.invokeUnbindMethod(DependencyManager.java:1919) ~[?:?]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.invokeUnbindMethod(SingleComponentManager.java:458) ~[?:?]
	at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.removedService(DependencyManager.java:382) ~[?:?]
	at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.removedService(DependencyManager.java:294) ~[?:?]
	at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerRemoved(ServiceTracker.java:1242) ~[?:?]
	at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerRemoved(ServiceTracker.java:1137) ~[?:?]
	at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.untrack(ServiceTracker.java:997) ~[?:?]
	at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1176) ~[?:?]
	at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:125) ~[?:?]
	at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109) ~[?:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:920) ~[?:?]
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) ~[?:?]
	at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) ~[?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862) ~[?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801) ~[?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.unregister(ServiceRegistrationImpl.java:222) ~[?:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.unregister(AbstractComponentManager.java:927) ~[?:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.unregister(AbstractComponentManager.java:892) ~[?:?]
	at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:135) ~[?:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.unregisterService(AbstractComponentManager.java:969) ~[?:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.doDeactivate(AbstractComponentManager.java:823) ~[?:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.deactivateInternal(AbstractComponentManager.java:805) ~[?:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.dispose(AbstractComponentManager.java:584) ~[?:?]
	at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.disposeComponents(ConfigurableComponentHolder.java:716) ~[?:?]
	at org.apache.felix.scr.impl.BundleComponentActivator.dispose(BundleComponentActivator.java:510) ~[?:?]
	at org.apache.felix.scr.impl.Activator.disposeComponents(Activator.java:429) ~[?:?]
	at org.apache.felix.scr.impl.Activator.access$300(Activator.java:49) ~[?:?]
	at org.apache.felix.scr.impl.Activator$ScrExtension.destroy(Activator.java:292) ~[?:?]
	at org.apache.felix.scr.impl.AbstractExtender$1.run(AbstractExtender.java:216) ~[?:?]
	at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) ~[?:?]
	at java.util.concurrent.FutureTask.run(FutureTask.java:266) ~[?:?]
	at org.apache.felix.scr.impl.AbstractExtender.destroyExtension(AbstractExtender.java:238) ~[?:?]
	at org.apache.felix.scr.impl.AbstractExtender.bundleChanged(AbstractExtender.java:132) ~[?:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:908) ~[?:?]
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213) ~[?:?]
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120) ~[?:?]
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112) ~[?:?]
	at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:168) ~[?:?]
	at org.eclipse.osgi.container.Module.publishEvent(Module.java:476) ~[?:?]
	at org.eclipse.osgi.container.Module.doStop(Module.java:634) ~[?:?]
	at org.eclipse.osgi.container.Module.stop(Module.java:498) ~[?:?]
	at org.eclipse.osgi.internal.framework.EquinoxBundle.stop(EquinoxBundle.java:410) ~[?:?]
	at org.apache.karaf.bundle.command.Stop.executeOnBundle(Stop.java:38) ~[?:?]
	at org.apache.karaf.bundle.command.BundlesCommand.doExecute(BundlesCommand.java:65) ~[?:?]
	at org.apache.karaf.bundle.command.BundlesCommand.execute(BundlesCommand.java:55) ~[?:?]
	at org.apache.karaf.shell.impl.action.command.ActionCommand.execute(ActionCommand.java:84) ~[?:?]
	at org.apache.karaf.shell.impl.console.osgi.secured.SecuredCommand.execute(SecuredCommand.java:68) ~[?:?]
	at org.apache.karaf.shell.impl.console.osgi.secured.SecuredCommand.execute(SecuredCommand.java:86) ~[?:?]
	at org.apache.felix.gogo.runtime.Closure.executeCmd(Closure.java:599) ~[?:?]
	at org.apache.felix.gogo.runtime.Closure.executeStatement(Closure.java:526) ~[?:?]
	at org.apache.felix.gogo.runtime.Closure.execute(Closure.java:415) ~[?:?]
	at org.apache.felix.gogo.runtime.Pipe.doCall(Pipe.java:416) ~[?:?]
	at org.apache.felix.gogo.runtime.Pipe.call(Pipe.java:229) ~[?:?]
	at org.apache.felix.gogo.runtime.Pipe.call(Pipe.java:59) ~[?:?]
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) ~[?:?]
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) ~[?:?]
	at java.lang.Thread.run(Thread.java:748) ~[?:?]
2019-05-21 18:51:19.420 [thome.event.ExtensionEvent] - Extension 'binding-allplay' has been uninstalled.
2019-05-21 18:57:03.889 [thome.event.ExtensionEvent] - Extension 'binding-allplay' has been installed.
AmazonDashButton:
After installation all DashButtons went ONLINE.
But when I press a button nothings happens. E.g. the event trigger has changed??
Should change my .rules file?
But when I remove the thing (with PaperUI) of one button and try to add it again, nothing is detected!
Only an error message in log file:
Here the logs
2019-05-21 18:34:43.732 [thome.event.ExtensionEvent] - Extension 'binding-amazondashbutton' has been installed.
2019-05-21 18:34:45.939 [hingStatusInfoChangedEvent] - 'amazondashbutton:dashbutton:xx-xx-xx-xx-xx-xx' changed from INITIALIZING to ONLINE
2019-05-21 18:34:46.629 [hingStatusInfoChangedEvent] - 'amazondashbutton:dashbutton:xx-xx-xx-xx-xx-xx' changed from INITIALIZING to ONLINE
2019-05-21 18:34:54.027 [hingStatusInfoChangedEvent] - 'amazondashbutton:dashbutton:xx-xx-xx-xx-xx-xx' changed from INITIALIZING to ONLINE
2019-05-21 18:34:54.071 [hingStatusInfoChangedEvent] - 'amazondashbutton:dashbutton:xx-xx-xx-xx-xx-xx' changed from INITIALIZING to ONLINE
2019-05-21 18:34:54.114 [hingStatusInfoChangedEvent] - 'amazondashbutton:dashbutton:xx-xx-xx-xx-xx-xx' changed from INITIALIZING to ONLINE
2019-05-21 18:34:54.156 [hingStatusInfoChangedEvent] - 'amazondashbutton:dashbutton:xx-xx-xx-xx-xx-xx' changed from INITIALIZING to ONLINE
2019-05-21 18:34:54.849 [hingStatusInfoChangedEvent] - 'amazondashbutton:dashbutton:xx-xx-xx-xx-xx-xx' changed from INITIALIZING to ONLINE
2019-05-21 18:34:55.381 [hingStatusInfoChangedEvent] - 'amazondashbutton:dashbutton:xx-xx-xx-xx-xx-xx' changed from INITIALIZING to ONLINE
2019-05-21 18:34:55.431 [hingStatusInfoChangedEvent] - 'amazondashbutton:dashbutton:xx-xx-xx-xx-xx-xx' changed from INITIALIZING to ONLINE
2019-05-21 18:34:55.473 [hingStatusInfoChangedEvent] - 'amazondashbutton:dashbutton:xx-xx-xx-xx-xx-xx' changed from INITIALIZING to ONLINE
2019-05-21 18:34:55.517 [hingStatusInfoChangedEvent] - 'amazondashbutton:dashbutton:xx-xx-xx-xx-xx-xx' changed from INITIALIZING to ONLINE
2019-05-21 20:00:56.834 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
java.lang.RuntimeException: org.pcap4j.core.PcapNativeException: Return code: -1, Message: PacketGetAdapterNames: The data area passed to a system call is too small. (122)
	at org.openhab.binding.amazondashbutton.internal.pcap.PcapUtil.getNetworkInterfaceByName(PcapUtil.java:58) ~[?:?]
	at org.openhab.binding.amazondashbutton.internal.handler.AmazonDashButtonHandler.lambda$0(AmazonDashButtonHandler.java:62) ~[?:?]
	at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) ~[?:?]
	at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) ~[?:?]
Caused by: org.pcap4j.core.PcapNativeException: Return code: -1, Message: PacketGetAdapterNames: The data area passed to a system call is too small. (122)
	at org.pcap4j.core.Pcaps.findAllDevs(Pcaps.java:58) ~[?:?]
	at org.pcap4j.core.Pcaps.getDevByName(Pcaps.java:125) ~[?:?]
	at org.openhab.binding.amazondashbutton.internal.pcap.PcapUtil.getNetworkInterfaceByName(PcapUtil.java:56) ~[?:?]
	... 8 more
2019-05-21 20:00:57.368 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
	at org.openhab.binding.amazondashbutton.internal.pcap.PcapUtil.getAllNetworkInterfaces(PcapUtil.java:43) ~[?:?]
	at org.openhab.binding.amazondashbutton.internal.pcap.PcapNetworkInterfaceService.determineBoundNetworkInterfaces(PcapNetworkInterfaceService.java:168) ~[?:?]
	at org.openhab.binding.amazondashbutton.internal.pcap.PcapNetworkInterfaceService.lambda$0(PcapNetworkInterfaceService.java:56) ~[?:?]
	at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) ~[?:?]
	at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) ~[?:?]
	at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) ~[?:?]
	at org.openhab.binding.amazondashbutton.internal.pcap.PcapUtil.getAllNetworkInterfaces(PcapUtil.java:40) ~[?:?]
	... 9 more
EDIT:
Also wrapper service has errors:
SLF4J: Failed to load class "org.slf4j.impl.StaticLoggerBinder"
INFO   | jvm 1    | 2019/05/21 18:34:26 | SLF4J: Failed to load class "org.slf4j.impl.StaticLoggerBinder".
INFO   | jvm 1    | 2019/05/21 18:34:26 | SLF4J: Defaulting to no-operation (NOP) logger implementation
INFO   | jvm 1    | 2019/05/21 18:34:26 | SLF4J: See http://www.slf4j.org/codes.html#StaticLoggerBinder for further details.
This is the explanation of the error:
Failed to load class org.slf4j.impl.StaticLoggerBinder
This warning message is reported when the org.slf4j.impl.StaticLoggerBinder class could not be loaded into memory. This happens when no appropriate SLF4J binding could be found on the class path. Placing one (and only one) of slf4j-nop.jar slf4j-simple.jar , slf4j-log4j12.jar , slf4j-jdk14.jar or logback-classic.jar on the class path should solve the problem.
SINCE 1.6.0 As of SLF4J version 1.6, in the absence of a binding, SLF4J will default to a no-operation (NOP) logger implementation.
If you are responsible for packaging an application and do not care about logging, then placing slf4j-nop.jar on the class path of your application will get rid of this warning message. Note that embedded components such as libraries or frameworks should not declare a dependency on any SLF4J binding but only depend on slf4j-api. When a library declares a compile-time dependency on a SLF4J binding, it imposes that binding on the end-user, thus negating SLF4J’s purpose.
Any help appreciated! Thanks a lot :slight_smile:
Add your ports to EXTRA_JAVA_OPTS, even if they have standard names…
I don’t use the other bindings/ I use a manual install and a custom update script, which looks a little more aggressive. Maybe test a clean install to see if those update instructions are out of date?
@5iver
Do you mean this?
SET EXTRA_JAVA_OPTS="-Dgnu.io.rxtx.SerialPorts=COM3:COM4"
That looks right (I use Fedora), but you might just want to put it in the start.bat.
@5iver
No, I don’t. I will do it either as a system variable or in the setenv.bat
I’m going to try this this evening. (I’m at work… :wink: )
Maybe it’s better to split this TOPIC into three or four?
  • Z-Wave
  • AllPlay
  • AmazonDashButton
  • Wrapper Service
For both of these bindings a simple
bundle:restart xxx
through Karaf solves the problem for me after a reboot.
@sihui
Ok. And after the next reboot the same procedure?
@5iver
@sihui
Unfortunately today, I can not test your suggestions.
My father (77) got a new laptop… :wink:
I use an unofficial binding (upnpcontrol) that has had issues at startup since post 2.5M1 (maybe before, I don’t recall). I just use a rule triggered at startup to restart the binding…
executeCommandLine("/bin/sh@@-c@@ssh -p 8101 -l openhab localhost \"bundle:restart org.openhab.binding.upnpcontrol;\"", 5000)
@5iver
I’ve added a system variable:
Z-Wave binding is running now, also after reboot.
Thanks a lot! :slight_smile:
@sihui
AmazonDashButton does still not run!
EDIT: I’ve now installed OH2 (#1597) from the scratch. And at first AmazonDashButton:
I get the following errors:
19:24:00.021 [WARN ] [org.pcap4j.util.PropertiesLoader     ] - [org/pcap4j/pcap4j.properties] Could not get value by org.pcap4j.af.inet, use default value: null
19:24:00.036 [WARN ] [org.pcap4j.util.PropertiesLoader     ] - [org/pcap4j/pcap4j.properties] Could not get value by org.pcap4j.af.inet6, use default value: null
19:24:00.036 [WARN ] [org.pcap4j.util.PropertiesLoader     ] - [org/pcap4j/pcap4j.properties] Could not get value by org.pcap4j.af.packet, use default value: null
19:24:00.036 [WARN ] [org.pcap4j.util.PropertiesLoader     ] - [org/pcap4j/pcap4j.properties] Could not get value by org.pcap4j.af.link, use default value: null
19:24:00.114 [WARN ] [org.pcap4j.util.PropertiesLoader     ] - [org/pcap4j/pcap4j.properties] Could not get value by org.pcap4j.dlt.raw, use default value: null
19:24:03.271 [WARN ] [pcap4j.packet.factory.PacketFactories] - java.lang.NoClassDefFoundError:org/pcap4j/packet/factory/PacketFactoryBinder
The first messages are a known issue.
The last line is different from here:
sudo setcap cap_net_raw,cap_net_admin=eip `realpath /usr/bin/java`
Then I’ve installed AllPlay binding:
Got these errors:
19:32:48.016 [ERROR] [org.openhab.binding.allplay          ] - bundle org.openhab.binding.allplay:2.5.0.201905191752 (222)[org.openhab.binding.allplay.internal.AllPlayHandlerFactory(253)] : The activate method has thrown an exception
java.lang.UnsatisfiedLinkError: no alljoyn_java in java.library.path
        at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1867) ~[?:?]
        at java.lang.Runtime.loadLibrary0(Runtime.java:870) ~[?:?]
        at java.lang.System.loadLibrary(System.java:1122) ~[?:?]
        at de.kaizencode.tchaikovsky.AllPlay.<clinit>(AllPlay.java:44) ~[?:?]
        at org.apache.felix.scr.impl.inject.methods.BaseMethod.invokeMethod(BaseMethod.java:228) ~[?:?]
        at org.apache.felix.scr.impl.inject.methods.BaseMethod.access$500(BaseMethod.java:41) ~[?:?]
        at org.apache.felix.scr.impl.inject.methods.BaseMethod$Resolved.invoke(BaseMethod.java:664) ~[?:?]
        at org.apache.felix.scr.impl.inject.methods.BaseMethod.invoke(BaseMethod.java:510) ~[?:?]
        at org.apache.felix.scr.impl.inject.methods.ActivateMethod.invoke(ActivateMethod.java:317) ~[?:?]
        at org.apache.felix.scr.impl.inject.methods.ActivateMethod.invoke(ActivateMethod.java:307) ~[?:?]
        at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(SingleComponentManager.java:340) ~[?:?]
        at org.apache.felix.scr.impl.manager.SingleComponentManager.createComponent(SingleComponentManager.java:114) ~[?:?]
        at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:982) ~[?:?]
        at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:955) ~[?:?]
        at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:900) ~[?:?]
        at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$1.run(ServiceFactoryUse.java:212) ~[?:?]
        at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:210) ~[?:?]
        at org.apache.felix.scr.impl.manager.DependencyManager.doInvokeBindMethod(DependencyManager.java:1805) ~[?:?]
        at org.apache.felix.scr.impl.manager.DependencyManager.invokeBindMethod(DependencyManager.java:1788) ~[?:?]
        at org.apache.felix.scr.impl.manager.SingleComponentManager.invokeBindMethod(SingleComponentManager.java:435) ~[?:?]
        at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:325) ~[?:?]
        at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:294) ~[?:?]
        at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1216) ~[?:?]
        at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1137) ~[?:?]
        at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:944) ~[?:?]
        at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:880) ~[?:?]
        at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1168) ~[?:?]
        at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127) ~[?:?]
        at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225) ~[?:?]
        at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:469) ~[?:?]
        at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:906) ~[?:?]
        at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:892) ~[?:?]
        at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:128) ~[?:?]
        at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:959) ~[?:?]
        at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:732) ~[?:?]
        at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:666) ~[?:?]
        at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:432) ~[?:?]
        at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:665) ~[?:?]
        at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:338) ~[?:?]
        at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:382) ~[?:?]
        at org.apache.felix.scr.impl.Activator.access$200(Activator.java:49) ~[?:?]
        at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:264) ~[?:?]
        at org.apache.felix.scr.impl.AbstractExtender.createExtension(AbstractExtender.java:196) ~[?:?]
        at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:169) ~[?:?]
        at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:49) ~[?:?]
        at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:482) ~[?:?]
        at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:415) ~[?:?]
        at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) ~[?:?]
        at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444) ~[?:?]
        at org.eclipse.osgi.container.Module.start(Module.java:467) ~[?:?]
        at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:383) ~[?:?]
        at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:402) ~[?:?]
        at org.apache.karaf.features.internal.service.BundleInstallSupportImpl.startBundle(BundleInstallSupportImpl.java:161) ~[?:?]
        at org.apache.karaf.features.internal.service.FeaturesServiceImpl.startBundle(FeaturesServiceImpl.java:1149) ~[?:?]
        at org.apache.karaf.features.internal.service.Deployer.deploy(Deployer.java:997) ~[?:?]
        at org.apache.karaf.features.internal.service.FeaturesServiceImpl.doProvision(FeaturesServiceImpl.java:1058) ~[?:?]
        at org.apache.karaf.features.internal.service.FeaturesServiceImpl.lambda$doProvisionInThread$13(FeaturesServiceImpl.java:994) ~[?:?]
19:32:48.329 [WARN ] [org.openhab.binding.allplay          ] - FrameworkEvent WARNING - org.openhab.binding.allplay
I’m on Windows! :wink:
Upps :heart_eyes:
@sihui
Maybe I should try to install the latest npcap or reinstall npcap again?
But this never was neccessary during update procedure before!!!
Yes, I use npcap because pcap does not support wifi!
But I can not test this today, because of very low WAF. :wink:
Sound like a good idea. Unfortunately I have no experience with openHAB on Windows …
Installed Snapshots #1593, #1596 and #1597 (from scratch) and then AmazonDashButton on a different Windows System, and installed npacp version 0.995 (=the newest!!) before.
Same errors:
12:31:59.177 [WARN ] [org.pcap4j.util.PropertiesLoader     ] - [org/pcap4j/pcap4j.properties] Could not get value by org.pcap4j.af.inet, use default value: null
12:31:59.179 [WARN ] [org.pcap4j.util.PropertiesLoader     ] - [org/pcap4j/pcap4j.properties] Could not get value by org.pcap4j.af.inet6, use default value: null
12:31:59.180 [WARN ] [org.pcap4j.util.PropertiesLoader     ] - [org/pcap4j/pcap4j.properties] Could not get value by org.pcap4j.af.packet, use default value: null
12:31:59.180 [WARN ] [org.pcap4j.util.PropertiesLoader     ] - [org/pcap4j/pcap4j.properties] Could not get value by org.pcap4j.af.link, use default value: null
12:31:59.230 [WARN ] [org.pcap4j.util.PropertiesLoader     ] - [org/pcap4j/pcap4j.properties] Could not get value by org.pcap4j.dlt.raw, use default value: null
12:31:59.532 [WARN ] [pcap4j.packet.factory.PacketFactories] - java.lang.NoClassDefFoundError:org/pcap4j/packet/factory/PacketFactoryBinder
Installed Snapshots #1593, #1596 and #1597 (from scratch) and then AllPlay Binding on a different Windows System. And I’ve reinstalled also Visual C++ Redistributable für Visual Studio 2015!
Same errors:
12:47:57.797 [ERROR] [org.openhab.binding.allplay          ] - bundle org.openhab.binding.allplay:2.5.0.201905191752 (212)[org.openhab.binding.allplay.internal.discovery.AllPlaySpeakerDiscoveryService(213)] : The activate method has thrown an exception
        at org.openhab.binding.allplay.internal.discovery.AllPlaySpeakerDiscoveryService.startScan(AllPlaySpeakerDiscoveryService.java:60) ~[?:?]
        at org.openhab.binding.allplay.internal.discovery.AllPlaySpeakerDiscoveryService.startBackgroundDiscovery(AllPlaySpeakerDiscoveryService.java:83) ~[?:?]
        at org.eclipse.smarthome.config.discovery.AbstractDiscoveryService.activate(AbstractDiscoveryService.java:386) ~[?:?]
12:47:57.883 [WARN ] [org.openhab.binding.allplay          ] - FrameworkEvent WARNING - org.openhab.binding.allplay
