Hi Guys,
Need some help with a rule to estimate cost of energy used
Idea is to get Group KwH multiplied by cost per KwH (22 cents) to then update a virtual item.
I realise I have to change the Group:Number:AVG to Group:Number:SUM for accuracy, but at the moment just trying to work out the rule to get a value
Rule:
rule "Kw into $"
Group gkWh changed
val production = triggeringItem.state as Number
VI_Energy_Cost_Month_So_Far.postUpdate(production * 0.22)
Items
Group:Number:AVG gkWh "kWh" <energy> (Home) ["Energy"]
Number VI_Energy_Cost_Month_So_Far "Energy Cost So Far this Month"
Any help would be much appreciated
EDIT: Log File Output from rule
2019-12-23 10:21:31.682 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'energy_cost.rules' has errors, therefore ignoring it: [3,5]: no viable alternative at input 'Group'
Shouldn’t that be
VI_Energy_Cost_Month_So_Far.value.postUpdate(production * 0.22)
I will try that, but per my edit above, I seem to be getting stuck on line 3
Group gkWh changed
I’ve learned this stuff by copying, pasting from the community and then editting to suit my needs, so not too sure where i’m going wrong
It appears adding the When statement to look for the Group is the issue. Changing it to an Item cleared the output faults in VS Code and updated the Virtual Item:
rule "Kw into $"
Item gkWh changed
2019-12-23 12:49:22.510 [GroupItemStateChangedEvent] - gkWh changed from 772.422 to 772.438 through GF_Lounge_Rear_SS_kWh
2019-12-23 12:49:23.028 [vent.ItemStateChangedEvent] - VI_Energy_Cost_Month_So_Far changed from NULL to 169.93636
@Bruce_Osborne FYI when using
I got the error below
2019-12-23 12:38:22.816 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Kw into $': 'value' is not a member of 'org.eclipse.smarthome.core.library.items.NumberItem'; line 6, column 5, length 33
