I had openhabian 2.3 and now I made the upgrade to 2.5. I have restart like 4 o 5 times, but I get a lot off errors, nothing works, mqtt, network binding and so on…
I am frustrated I do not know how to step forward and setup properly the Openhab…
I thank you your assistance.
2020-02-22 18:36:00.599 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'vpn' for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2020-02-22 18:36:00.602 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2020-02-22 18:36:00.604 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'vpn' for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2020-02-22 18:36:00.607 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'vpn' for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2020-02-22 18:36:00.610 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'vpn' for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2020-02-22 18:36:00.612 [WARN ] [basic.internal.render.SwitchRenderer] - Cannot determine item type of 'trans'
org.eclipse.smarthome.core.items.ItemNotFoundException: Item 'trans' could not be found in the item registry
at org.eclipse.smarthome.core.internal.items.ItemRegistryImpl.getItem(ItemRegistryImpl.java:85) ~[?:?]
at org.eclipse.smarthome.ui.internal.items.ItemUIRegistryImpl.getItem(ItemUIRegistryImpl.java:837) ~[?:?]
at org.openhab.ui.basic.internal.render.SwitchRenderer.renderWidget(SwitchRenderer.java:85) [bundleFile:?]
at org.openhab.ui.basic.internal.render.PageRenderer.renderWidget(PageRenderer.java:194) [bundleFile:?]
at org.openhab.ui.basic.internal.render.PageRenderer.processChildren(PageRenderer.java:160) [bundleFile:?]
at org.openhab.ui.basic.internal.render.PageRenderer.processChildren(PageRenderer.java:181) [bundleFile:?]
at org.openhab.ui.basic.internal.render.PageRenderer.processPage(PageRenderer.java:124) [bundleFile:?]
at org.openhab.ui.basic.internal.servlet.WebAppServlet.service(WebAppServlet.java:189) [bundleFile:?]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790) [bundleFile:3.1.0]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:852) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:544) [bundleFile:9.4.20.v20190813]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) [bundleFile:?]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:536) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1581) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1307) [bundleFile:9.4.20.v20190813]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:293) [bundleFile:?]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:482) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1549) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1204) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) [bundleFile:9.4.20.v20190813]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) [bundleFile:?]
at org.eclipse.jetty.server.Server.handle(Server.java:494) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:374) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:268) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:103) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:117) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:336) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:313) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:171) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:129) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:367) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:782) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:918) [bundleFile:9.4.20.v20190813]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_152]
2020-02-22 18:36:00.627 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'trans' for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2020-02-22 18:36:00.629 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2020-02-22 18:36:00.700 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'trans' for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2020-02-22 18:36:00.702 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'trans' for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2020-02-22 18:36:00.705 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'trans' for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2020-02-22 18:36:00.707 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-02-22 18:36:00.709 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'ip_plex' for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-02-22 18:36:00.711 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'ip_plex' for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-02-22 18:36:00.714 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'ip_plex' for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-02-22 18:36:00.716 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-02-22 18:36:00.719 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'lo_plex' for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-02-22 18:36:00.721 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'lo_plex' for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-02-22 18:36:00.724 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'lo_plex' for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-02-22 18:36:00.726 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-02-22 18:36:00.729 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'ip_net' for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-02-22 18:36:00.731 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'ip_net' for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-02-22 18:36:00.734 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'ip_net' for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-02-22 18:36:19.436 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-misc-myopenhab'
2020-02-22 18:37:33.528 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-misc-myopenhab'
2020-02-22 18:38:19.423 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-misc-myopenhab'
2020-02-22 18:39:18.579 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-misc-myopenhab'```
Most of your errors are related due to rules files are loaded before items files.
Change the ending of your rules files to something different than .rules, restart openhab and check your log. When everything is up and running, rename your rules files back.
The system is restarting in loop, it does not stop…
2020-02-22 20:11:14.432 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Started HABmin servlet at /habmin
2020-02-22 20:11:14.723 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2020-02-22 20:11:14.824 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-misc-myopenhab'
2020-02-22 20:11:15.405 [WARN ] [org.apache.felix.fileinstall ] - Error while starting bundle: file:/usr/share/openhab2/addons/org.openhab.binding.network-2.3.0.jar
org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.network [90]
Unresolved requirement: Import-Package: org.apache.commons.net.util
at org.eclipse.osgi.container.Module.start(Module.java:444) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:383) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundle(DirectoryWatcher.java:1260) [bundleFile:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundles(DirectoryWatcher.java:1233) [bundleFile:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startAllBundles(DirectoryWatcher.java:1221) [bundleFile:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.doProcess(DirectoryWatcher.java:515) [bundleFile:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.process(DirectoryWatcher.java:365) [bundleFile:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.run(DirectoryWatcher.java:316) [bundleFile:3.6.4]
2020-02-22 20:11:15.418 [WARN ] [org.apache.felix.fileinstall ] - Error while starting bundle: file:/usr/share/openhab2/addons/org.openhab.binding.network-2.3.0.jar
2020-02-22 20:12:05.982 [INFO ] [io.openhabcloud.internal.CloudClient] - Shutting down openHAB Cloud service connection
2020-02-22 20:12:05.987 [INFO ] [io.openhabcloud.internal.CloudClient] - Disconnected from the openHAB Cloud service (UUID = 04, base URL = http://localhost:8080)
2020-02-22 20:12:06.248 [INFO ] [panel.internal.HABPanelDashboardTile] - Stopped HABPanel
2020-02-22 20:12:06.299 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Stopped HABmin servlet
2020-02-22 20:12:06.422 [INFO ] [basic.internal.servlet.WebAppServlet] - Stopped Basic UI
2020-02-22 20:12:12.389 [INFO ] [io.hueemulation.internal.ConfigStore] - Hue Emulation pairing disabled
2020-02-22 20:12:13.700 [WARN ] [ulation.internal.HueEmulationService] - The UPnP Server service has not been started!
2020-02-22 20:12:13.706 [INFO ] [ulation.internal.HueEmulationService] - Hue Emulation service available under /api
2020-02-22 20:12:13.916 [WARN ] [ueemulation.internal.upnp.UpnpServer] - Upnp server: Address test failed
java.util.concurrent.CompletionException: java.lang.LinkageError: ClassCastException: attempting to castbundleresource://35.fwk24009/javax/ws/rs/client/ClientBuilder.class to bundleresource://35.fwk24009/javax/ws/rs/client/ClientBuilder.class
at java.util.concurrent.CompletableFuture.encodeThrowable(CompletableFuture.java:273) ~[?:1.8.0_222]
at java.util.concurrent.CompletableFuture.completeThrowable(CompletableFuture.java:280) [?:1.8.0_222]
at java.util.concurrent.CompletableFuture.uniApply(CompletableFuture.java:604) [?:1.8.0_222]
at java.util.concurrent.CompletableFuture$UniApply.tryFire(CompletableFuture.java:577) [?:1.8.0_222]
at java.util.concurrent.CompletableFuture$Completion.exec(CompletableFuture.java:443) [?:1.8.0_222]
at java.util.concurrent.ForkJoinTask.doExec(ForkJoinTask.java:289) [?:1.8.0_222]
at java.util.concurrent.ForkJoinPool$WorkQueue.runTask(ForkJoinPool.java:1056) [?:1.8.0_222]
at java.util.concurrent.ForkJoinPool.runWorker(ForkJoinPool.java:1692) [?:1.8.0_222]
at java.util.concurrent.ForkJoinWorkerThread.run(ForkJoinWorkerThread.java:157) [?:1.8.0_222]
Caused by: java.lang.LinkageError: ClassCastException: attempting to castbundleresource://35.fwk24009/javax/ws/rs/client/ClientBuilder.class to bundleresource://35.fwk24009/javax/ws/rs/client/ClientBuilder.class
at javax.ws.rs.client.ClientBuilder.newBuilder(ClientBuilder.java:97) ~[?:?]
at javax.ws.rs.client.ClientBuilder.newClient(ClientBuilder.java:126) ~[?:?]
at org.openhab.io.hueemulation.internal.upnp.UpnpServer.performAddressTest(UpnpServer.java:240) ~[?:?]
at java.util.concurrent.CompletableFuture.uniApply(CompletableFuture.java:602) ~[?:1.8.0_222]
... 6 more
2020-02-22 20:12:14.741 [INFO ] [ulation.internal.HueEmulationService] - Hue Emulation service available under /api
2020-02-22 20:12:14.742 [WARN ] [ueemulation.internal.upnp.UpnpServer] - Upnp server: Address test failed
... 6 more
2020-02-22 20:12:14.997 [INFO ] [io.openhabcloud.internal.CloudClient] - Connected to the openHAB Cloud service (UUID = 047c, base URL = http://localhost:8080)
2020-02-22 20:12:15.435 [WARN ] [org.apache.felix.fileinstall ] - Error while starting bundle: file:/usr/share/openhab2/addons/org.openhab.binding.network-2.3.0.jar
2020-02-22 20:12:15.449 [WARN ] [org.apache.felix.fileinstall ] - Error while starting bundle: file:/usr/share/openhab2/addons/org.openhab.binding.network-2.3.0.jar
2020-02-22 20:12:15.939 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Started HABmin servlet at /habmin
2020-02-22 20:12:16.226 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2020-02-22 20:12:16.318 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-misc-myopenhab'```
Looks like it is failing at installing a bundle and as a result OH keeps ‘restarting’. Get rid of that old 2.3.0 bundle and your issue just might be resolved…
I still have 1 warning and 1 error. but I removed from addons the error from “openhab-misc-myopenhab”
I am confused, what should I have within services/addons.cfg and my addons.config file?
2020-02-22 20:49:13.500 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Started HABmin servlet at /habmin
2020-02-22 20:49:13.797 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2020-02-22 20:49:13.930 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-misc-myopenhab'
2020-02-22 20:49:41.092 [INFO ] [io.openhabcloud.internal.CloudClient] - Shutting down openHAB Cloud service connection
2020-02-22 20:49:41.098 [INFO ] [io.openhabcloud.internal.CloudClient] - Disconnected from the openHAB Cloud service (UUID = 047c1758-f747-4575-a39a-b085b495e12a, base URL = http://localhost:8080)
2020-02-22 20:49:41.350 [INFO ] [panel.internal.HABPanelDashboardTile] - Stopped HABPanel
2020-02-22 20:49:41.393 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Stopped HABmin servlet
2020-02-22 20:49:41.499 [INFO ] [basic.internal.servlet.WebAppServlet] - Stopped Basic UI
2020-02-22 20:49:46.258 [INFO ] [io.hueemulation.internal.ConfigStore] - Hue Emulation pairing disabled
2020-02-22 20:49:47.587 [WARN ] [ulation.internal.HueEmulationService] - The UPnP Server service has not been started!
2020-02-22 20:49:47.594 [INFO ] [ulation.internal.HueEmulationService] - Hue Emulation service available under /api
2020-02-22 20:49:47.807 [WARN ] [ueemulation.internal.upnp.UpnpServer] - Upnp server: Address test failed
java.util.concurrent.CompletionException: java.lang.LinkageError: ClassCastException: attempting to castbundleresource://35.fwk2429596/javax/ws/rs/client/ClientBuilder.class to bundleresource://35.fwk2429596/javax/ws/rs/client/ClientBuilder.class
Caused by: java.lang.LinkageError: ClassCastException: attempting to castbundleresource://35.fwk2429596/javax/ws/rs/client/ClientBuilder.class to bundleresource://35.fwk2429596/javax/ws/rs/client/ClientBuilder.class
... 6 more
2020-02-22 20:49:48.458 [WARN ] [ueemulation.internal.upnp.UpnpServer] - Upnp server: Address test failed
at java.util.concurrent.CompletableFuture.completeThrowable(CompletableFuture.java:280) ~[?:1.8.0_222]
at java.util.concurrent.CompletableFuture.uniApply(CompletableFuture.java:604) ~[?:1.8.0_222]
at java.util.concurrent.CompletableFuture$UniApply.tryFire(CompletableFuture.java:577) ~[?:1.8.0_222]
at java.util.concurrent.CompletableFuture$Completion.exec(CompletableFuture.java:443) ~[?:1.8.0_222]
at java.util.concurrent.ForkJoinTask.doExec(ForkJoinTask.java:289) ~[?:1.8.0_222]
at java.util.concurrent.ForkJoinPool$WorkQueue.runTask(ForkJoinPool.java:1056) ~[?:1.8.0_222]
at java.util.concurrent.ForkJoinPool.runWorker(ForkJoinPool.java:1692) ~[?:1.8.0_222]
at java.util.concurrent.ForkJoinWorkerThread.run(ForkJoinWorkerThread.java:157) ~[?:1.8.0_222]
... 6 more
2020-02-22 20:49:48.479 [INFO ] [ulation.internal.HueEmulationService] - Hue Emulation service available under /api
2020-02-22 20:49:48.722 [INFO ] [io.openhabcloud.internal.CloudClient] - Connected to the openHAB Cloud service (UUID = 047, base URL = http://localhost:8080)
2020-02-22 20:49:49.781 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Started HABmin servlet at /habmin
2020-02-22 20:49:50.103 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2020-02-22 20:49:50.186 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-misc-myopenhab'```
ok. I have removed the error from openhab-misc-myopenhab, but now show up the following errors regarding to the items, but files items were declarated properly in the item files…
2020-02-22 21:13:54.019 [temChannelLinkRemovedEvent] - Link 'phone2 => network:pingdevice:192_168_2_163:online' has been removed.
2020-02-22 21:13:54.026 [temChannelLinkRemovedEvent] - Link 'phone => network:pingdevice:192_168_2_160:online' has been removed.
2020-02-22 21:13:54.032 [temChannelLinkRemovedEvent] - Link 'Sunset_Time => astro:sun:home:set#start' has been removed.
2020-02-22 21:13:54.037 [temChannelLinkRemovedEvent] - Link 'Sunrise_Time => astro:sun:home:rise#start' has been removed.
2020-02-22 21:13:54.045 [temChannelLinkRemovedEvent] - Link 'Network_Mac => systeminfo:computer:work:network#mac' has been removed.
2020-02-22 21:13:54.053 [temChannelLinkRemovedEvent] - Link 'Network_IP => systeminfo:computer:work:network#ip' has been removed.
2020-02-22 21:16:18.696 [INFO ] [el.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model 'home.sitemap', using it anyway:
Sitemap should contain either only frames or none at all
2020-02-22 21:16:18.753 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'home.sitemap'
2020-02-22 21:16:18.853 [INFO ] [el.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model 'home_test.sitemap', using it anyway:
2020-02-22 21:16:18.868 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'home_test.sitemap'
2020-02-22 21:16:19.024 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'home.things'
2020-02-22 21:16:19.203 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'mapdb.persist'
2020-02-22 21:16:19.246 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'influxdb.persist'
2020-02-22 21:16:19.437 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'home.items'
2020-02-22 21:16:23.460 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Time zone set to 'Europe/Berlin'.
2020-02-22 21:16:23.478 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Locale set to 'es_DE'.
2020-02-22 21:16:28.030 [.ItemChannelLinkAddedEvent] - Link 'phone2-network:pingdevice:192_168_2_163:online' has been added.
2020-02-22 21:16:28.037 [.ItemChannelLinkAddedEvent] - Link 'phone-network:pingdevice:192_168_2_160:online' has been added.
2020-02-22 21:16:28.398 [.ItemChannelLinkAddedEvent] - Link 'Sunrise_Time-astro:sun:home:rise#start' has been added.
2020-02-22 21:16:28.401 [.ItemChannelLinkAddedEvent] - Link 'Sunset_Time-astro:sun:home:set#start' has been added.
2020-02-22 21:16:28.417 [.ItemChannelLinkAddedEvent] - Link 'Network_IP-systeminfo:computer:work:network#ip' has been added.
2020-02-22 21:16:28.420 [.ItemChannelLinkAddedEvent] - Link 'Network_Mac-systeminfo:computer:work:network#mac' has been added.
2020-02-22 21:16:29.007 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at http://192.168.2.123:8080
2020-02-22 21:16:29.011 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at https://192.168.2.123:8443
2020-02-22 21:16:31.432 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2020-02-22 21:17:08.022 [thome.event.ExtensionEvent] - Extension 'package-expert' has been installed.
2020-02-22 21:18:10.377 [INFO ] [egram.internal.TelegramActionService] - Bot Juan loaded from config file
2020-02-22 21:18:10.380 [INFO ] [egram.internal.TelegramActionService] - Bot Estela loaded from config file
2020-02-22 21:18:16.526 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Started HABmin servlet at /habmin
2020-02-22 21:18:16.806 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2020-02-22 21:18:19.208 [INFO ] [openhab.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2020-02-22 21:18:19.849 [thome.event.ExtensionEvent] - Extension 'persistence-mapdb' has been installed.
2020-02-22 21:18:19.859 [thome.event.ExtensionEvent] - Extension 'transformation-javascript' has been installed.
2020-02-22 21:18:19.862 [thome.event.ExtensionEvent] - Extension 'transformation-regex' has been installed.
2020-02-22 21:18:19.865 [thome.event.ExtensionEvent] - Extension 'ui-habpanel' has been installed.
2020-02-22 21:18:19.868 [thome.event.ExtensionEvent] - Extension 'transformation-jsonpath' has been installed.
2020-02-22 21:18:19.871 [thome.event.ExtensionEvent] - Extension 'action-telegram' has been installed.
2020-02-22 21:18:19.875 [thome.event.ExtensionEvent] - Extension 'transformation-xpath' has been installed.
2020-02-22 21:18:19.879 [thome.event.ExtensionEvent] - Extension 'ui-restdocs' has been installed.
2020-02-22 21:18:19.882 [thome.event.ExtensionEvent] - Extension 'transformation-map' has been installed.
2020-02-22 21:18:19.887 [thome.event.ExtensionEvent] - Extension 'ui-basic' has been installed.
2020-02-22 21:18:19.891 [thome.event.ExtensionEvent] - Extension 'ui-classic' has been installed.
2020-02-22 21:18:19.893 [thome.event.ExtensionEvent] - Extension 'ui-habmin' has been installed.
2020-02-22 21:18:19.897 [thome.event.ExtensionEvent] - Extension 'transformation-xslt' has been installed.
2020-02-22 21:18:19.899 [thome.event.ExtensionEvent] - Extension 'transformation-exec' has been installed.
2020-02-22 21:18:19.915 [thome.event.ExtensionEvent] - Extension 'ui-paper' has been installed.
2020-02-22 21:18:19.917 [thome.event.ExtensionEvent] - Extension 'transformation-scale' has been installed.
2020-02-22 21:18:27.466 [thome.event.ExtensionEvent] - Extension 'ui-dashboard' has been uninstalled.
2020-02-22 21:19:15.609 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-02-22 21:19:15.613 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'Sunrise_Time' for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-02-22 21:19:15.617 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'Sunrise_Time' for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-02-22 21:19:15.619 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'Sunrise_Time' for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-02-22 21:19:15.621 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-02-22 21:19:15.625 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'Sunset_Time' for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-02-22 21:19:15.627 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'Sunset_Time' for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-02-22 21:19:15.630 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'Sunset_Time' for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-02-22 21:19:15.658 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-02-22 21:19:15.662 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'sff_d1_puerta_timbre_2' for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-02-22 21:19:15.664 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'sff_d1_puerta_timbre_2' for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-02-22 21:19:15.667 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'sff_d1_puerta_timbre_2' for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-02-22 21:19:15.669 [WARN ] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve color item sff_d1_puerta_timbre_2 for widget
2020-02-22 21:19:15.676 [WARN ] [basic.internal.render.SwitchRenderer] - Cannot determine item type of 'autom'
org.eclipse.smarthome.core.items.ItemNotFoundException: Item 'autom' could not be found in the item registry
2020-02-22 22:11:25.678 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'home.sitemap'
2020-02-22 22:11:36.797 [WARN ] [basic.internal.render.SwitchRenderer] - Cannot determine item type of 'PLEX'
org.eclipse.smarthome.core.items.ItemNotFoundException: Item 'PLEX' could not be found in the item registry
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_222]
2020-02-22 22:11:36.851 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'PLEX' for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2020-02-22 22:11:36.854 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2020-02-22 22:11:36.860 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'PLEX' for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2020-02-22 22:11:36.866 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'PLEX' for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2020-02-22 22:11:36.869 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'PLEX' for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2020-02-22 22:11:36.872 [WARN ] [basic.internal.render.SwitchRenderer] - Cannot determine item type of 'vpn'
org.eclipse.smarthome.core.items.ItemNotFoundException: Item 'vpn' could not be found in the item registry
2020-02-22 22:11:36.886 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'vpn' for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2020-02-22 22:11:36.889 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2020-02-22 22:11:36.892 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'vpn' for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2020-02-22 22:11:36.895 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'vpn' for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2020-02-22 22:11:36.898 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'vpn' for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2020-02-22 22:11:36.901 [WARN ] [basic.internal.render.SwitchRenderer] - Cannot determine item type of 'trans'
2020-02-22 22:11:36.913 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'trans' for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2020-02-22 22:11:36.916 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2020-02-22 22:11:36.919 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'trans' for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2020-02-22 22:11:36.923 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'trans' for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2020-02-22 22:11:36.925 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'trans' for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2020-02-22 22:11:36.929 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-02-22 22:11:36.931 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'ip_plex' for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-02-22 22:11:36.934 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'ip_plex' for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-02-22 22:11:36.936 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'ip_plex' for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-02-22 22:11:36.939 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-02-22 22:11:36.941 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'lo_plex' for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-02-22 22:11:36.944 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'lo_plex' for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-02-22 22:11:36.946 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'lo_plex' for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-02-22 22:11:36.949 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-02-22 22:11:36.952 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'ip_net' for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-02-22 22:11:36.955 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'ip_net' for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-02-22 22:11:36.957 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'ip_net' for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-02-22 22:12:49.218 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'home.items'
2020-02-22 22:13:10.011 [WARN ] [basic.internal.render.SwitchRenderer] - Cannot determine item type of 'PLEX'
2020-02-22 22:13:10.037 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'PLEX' for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2020-02-22 22:13:10.041 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2020-02-22 22:13:10.044 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'PLEX' for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2020-02-22 22:13:10.047 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'PLEX' for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2020-02-22 22:13:10.049 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'PLEX' for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2020-02-22 22:13:10.051 [WARN ] [basic.internal.render.SwitchRenderer] - Cannot determine item type of 'vpn'
2020-02-22 22:13:10.068 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'vpn' for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2020-02-22 22:13:10.071 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2020-02-22 22:13:10.074 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'vpn' for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2020-02-22 22:13:10.077 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'vpn' for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2020-02-22 22:13:10.080 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'vpn' for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2020-02-22 22:13:10.082 [WARN ] [basic.internal.render.SwitchRenderer] - Cannot determine item type of 'trans'
2020-02-22 22:13:10.095 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'trans' for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2020-02-22 22:13:10.097 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2020-02-22 22:13:10.100 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'trans' for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2020-02-22 22:13:10.102 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'trans' for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2020-02-22 22:13:10.105 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'trans' for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2020-02-22 22:13:10.107 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-02-22 22:13:10.110 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'ip_plex' for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-02-22 22:13:10.112 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'ip_plex' for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-02-22 22:13:10.114 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'ip_plex' for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-02-22 22:13:10.117 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-02-22 22:13:10.119 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'lo_plex' for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-02-22 22:13:10.121 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'lo_plex' for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-02-22 22:13:10.124 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'lo_plex' for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-02-22 22:13:10.126 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-02-22 22:13:10.129 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'ip_net' for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-02-22 22:13:10.131 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'ip_net' for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
2020-02-22 22:13:10.133 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'ip_net' for widget org.eclipse.smarthome.model.sitemap.sitemap.Text
If these errors only occur at startup, you can ignore them. Because of timing of multiple threads OH can start rules before loading all items in the registry, or similar issues.
Or do they keep coming back in the logs?
