I upgraded from 2.5.10 to 2.5.11 simply to be on the latest version of 2.5.
After the upgrade MQTT messages were no longer processed.
No changes were made to the config.
Since all controllers in my place run on MQTT, pretty much every thing is non-functional.
After unsuccessful attempts to troubleshoot the problem… I reverted back to 2.5.10… only to discover the problem persists.
I am at a loss on how to fix this.
The openhab.log does not give my any clues about mosquitto being loaded/started, but says Stopping broker connection 'mymosquitto' when stopping OH.
I really need some help. Thanks.
Steps undertaken so far:
initial upgrade to 2.5.11
restart; lots of errors
stop OH
clear cache
start OH; seemingly normal start
stop OH
→ still no MQTT processing
sudo apt install openhab2=2.5.10-1
clear cache
start OH
stop and start OH; seemingly normal start
Non-MQTT stuff is working.
However the mosquitto broker is installed and running and works for other things:
sudo service mosquitto status
â—Ź mosquitto.service - Mosquitto MQTT v3.1/v3.1.1 Broker
Loaded: loaded (/lib/systemd/system/mosquitto.service; enabled; vendor preset: enabled)
Active: active (running) since Thu 2020-10-26 14:04:07 AEST; 1 hour ago
Docs: man:mosquitto.conf(5)
man:mosquitto(8)
Main PID: 10530 (mosquitto)
Tasks: 1 (limit: 2184)
CGroup: /system.slice/mosquitto.service
└─10530 /usr/sbin/mosquitto -c /etc/mosquitto/mosquitto.conf
That’s not true: PaperUI will still show your Broker Thing, and whether it is connected (“ONLINE”) - you just can’t edit it. Should be somewhere like Configuration → Things
Please also show your configuration of your Broker Thing.
Well… it is a few minutes away, as the machine is booting and takes some 9 minutes.
… I was using the rPi to build a new 2.5 system, but on a different drive… the system upgrade just finished; hence, the swap of drives and rebooting the system.
I have to say that this GUI config business is doing my head in. I tried to config the MQTTv2 version, but it is so much work given that all my controllers talk MQTT.
OK, back in business…
… and yes, there is no MQTT broker in the PaperUI
There is a services/mqtt.cfg:
So you are using the version 1 MQTT binding, in this case nothing usefull will be shown on PaperUI and you don’t need to have or better won’t have any MQTT Thing.
If the broker is running as before and your items are created by the same file I’d would check with MQTTfx (or a similar program) whether mqtt messages are processed at all.
And for the sake of all the users trying to help, in the present situation ( MQTT version 2 being out 2 years AND OH3 ( to one with no version1 support) went public a week ago ) it would be a good idea to highlight the use of an deprecated binding.
Yes, as stated in the O.P.
Agree with what you’re saying.
However, the work involved to change will be significant.
… and I hope you’re not blaming me for having upgraded a minor and official release which broke the system.
mosquitto is up and running fine.
I can run commands, which are accepted by the controllers, but not processed by OH.
This is what puzzles the heck out of me. OH seems to connect, if I can assume that from the fact it states in the log that it it disconnecting from the mymosquitto broker.
… is what I get in openhab.log when shutting OH down.
When I try to change the clientId in mqtt.cfg, this is recorded in the openhab.log:
2020-12-26 19:37:40.458 [ERROR] [org.apache.felix.configadmin ] - Cannot use configuration org.openhab.mqtt for [org.openhab.io.transport.mqtt.MqttService, org.osgi.service.cm.ManagedService, id=381, bundle=237/mvn:org.openhab.io/org.openhab.io.transport.mqtt/1.14.0]: No visibility to configuration bound to mvn:org.openhab.action/org.openhab.action.mqtt/1.14.0
OK, you do use the binding and the action. I faintly remmber a problem with them, if I remember correctly the action needed to be loaded after the binding to solve the problem (will have to digg into old posts to verify).
and thanks for changing the title!
[all I did was upgrade 2.5.10 to 2.5.11, stop, start and it should have been fine; no config changes of any sort were made; and the timestamps of the config files are all before the upgrade]
Such problem could be resolved by loading the mqtt action manually after the mqtt binding was installed. I think unloading the action (which is set in the addons.cfg) won’t work for you, so try to remove it from the addons.cfg, restart and load the mqtt action afterwards manually (if you still need it).
I proactively moved the mqtt1 entry to the front (as you suggested earlier), and restarted, and…
… mqtt is working again.
Phew… the “Haussegen hing schief” given the 'most-of-the-day" outage.
I am not sure, whether the action is required (was always there from years ago).
… but considering I hadn’t made the change you then suggested to remove the mqtt action and reboot… I think we have a fix.
Thank you so much for hanging in there! Much appreciated.
