Good evening.
I’m running into a few issues, most likely because I’m terrible at Regex.
Here’s the issue, I have a switch that can report 5 different things, the payload from Zigbee2MQTT looks like this:
{"battery":100,"voltage":3005,"linkquality":99,"action":"shake"}'
{"battery":100,"voltage":3005,"linkquality":102,"click":"double"}'
{"battery":100,"voltage":3005,"linkquality":105,"click":"single"}'
{"battery":91,"voltage":2985,"linkquality":123,"action":"hold"}'
{"battery":91,"voltage":2985,"linkquality":139,"action":"release"}'
Generally I would use jsonpath to find the action, however the button switching between “click” and “action” in the payload makes this approach throw errors. Instead I wanted to use regex to just parse the entire payload and extract the relevant bit.
Here, my approach works: regexr.com/4p28c
But in openhab, this always returns null:
var action = "Placeholder"
rule "Wireless button press"
Item WirelessSwitch_WirelessSwitchButton received update
var action = transform("REGEX", "\bshake\b|\bdouble\b|\bsingle\b|\bhold\b|\brelease\b", WirelessSwitch_WirelessSwitchButton.state.toString)
logInfo("debug", action)
switch action{
case action = "single":
if( KontorLys_.state == ON ) {
KontorLys_.sendCommand(OFF)
else
KontorLys_.sendCommand(ON)
Where am I going wrong?
