The purpose is to set the value ot vDauer which I’ll use in a rule:
rule "Sleep Test"
Item test_button changed to ON
if (test_button.state==ON) {
var Number vDauerms = vDauer.state as Number
logInfo("RULE", "--> Sleep Test an: " + vDauerms)
Thread::sleep(vDauerms)
logInfo("RULE", "--> Sleep Test aus")
sendCommand(test_button, OFF)
Unfortunately I got an error message:
Log:
[INFO ] [.eclipse.smarthome.model.script.RULE] - --> Sleep Test an: 5
[ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule ‘Sleep Test’: An error occurred during the script execution: Could not invoke method: java.lang.Thread.sleep(long) on instance: null
VScode Editor:
Type mismatch: cannot convert from Number to long
logInfo(“RULE”, "–> Sleep Test an: " + vDauerms) outputs the correct value but it obviously doesn’t in Thread:sleep
If you intend to have a delay of several minutes you should use a timer
Using Threa::sleep is OK but only for short delays up to 1s or so
The reasons is that openHAB only have 5 threads to play with and if one of your rules keep a thread opened for a long time then openHAB will have one less. If your have several similar rules you system will quickly come to a halt. A timer avoid that problem.
Please note that I also changed sendCommand(test_button, OFF) to test_button.sendCommand(OFF). It is better to use the method instead of the action when the item is already known. See:
var Timer timer = null
rule "Sleep Test"
if (timer === null) {
timer = createTimer(now.plusMinutes(vDauerms.intValue, [ | // Sets timer to x minutes
timer = null //reset timer
While I agree that it’s a best practice to not use sleep for long periods, also note that it’s possible to change the number of threads allocated to rule execution. I’m currently running 30 threads.
In conf/services/runtime.cfg, you can set the number of rule engine threads using this config parameter. Note that a restart is not required for the change to take effect.
org.eclipse.smarthome.threadpool:RuleEngine=NN
where NN is the number of threads.
On a low end processor, it might not be advisable to set this number too high.
rule "Sleep Test"
timer = createTimer(now.plusMinutes(vDauerm.intValue), [ | // Sets timer to x minutes
Does the number of rule engine thread refer to the number of rules that can concurrently fire or stay active?
I am running OH2.5.12 on a Raspberry Pi 3 B+. What is the maximum number I can use to set the number of rule engine thread? Could you please also explain how you determine this?
