@mstormi Running zram for 17d, everything fine so far. Today i checked df- h
to find /dev/zram1
usage at 100%.
Is this to expected? I’m using zram for /var/log
and swap
only btw…
to find /dev/zram1
usage at 100%.
and swap
only btw…
You need to be more precise. What real-world filesystem does /dev/zram1 point to and how filled is that one ?
Use zramctl
to see how much RAM is really in use.
Thanks @mstormi
This is my /etc/ztab
# swap alg mem_limit disk_size swap_priority page-cluster swappiness
swap lz4 250M 750M 75 0 80
# log alg mem_limit disk_size target_dir bind_dir oldlog_dir
log lz4 50M 150M /var/log /log.bind /opt/zram/oldlog
swap usage was at 95M and /var/log
is:
% sudo du -sh /var/log
246M /var/log
Ah yes, should have done that. I’ve meanwhile rebooted and /dev/zram1
is back at 12%. I’ll have to check this next time…
Assuming /dev/zram0 was swap and zram1 was /var/log (validate this next time), you shouldn’t be surprised. You produced more logs than you provided space for.
I guess openHABian rotated some logs to the bind_dir directory ?
So decrease logfile size/number of kept logs in OH (and in whatever fills /var/log)
Content was the same as in /var/log
, so the size was probably too big to begin with? Most of it were OH logs (236M).
Easier said than done
I’ve added the following to /var/lib/openhab2/etc/org.ops4j.pax.logging.cfg
log4j2.appender.out.strategy.max = 2
log4j2.appender.event.strategy.max = 2
The result was that OH logging stopped completely
Also, I’ve never changed the logging configuration. So isn’t this a problem that will happen to all users sooner or later?
Regarding zramctl
: I just noticed that this is not even installed. I thought it’s part of the util-linux
package, which is already installed on my raspian system, but apparently it’s not. At least not on raspian.
Right file but wrong entry. I think the block for that already exists so don’t add lines but change those. Can’t lookup ATM but there’s threads on this and I think it’s even in the docs.
Just to those that chose a logsize of 150M like you did
(did you change that in ztab after installing or was that the default? I have increased it meanwhile bit I think the PR is still pending) .
did you originally install the openhabian image? Let me know which package you need so I can add it to openhabian.
Thanks, I’ll take another look.
It was the default.
No, I just cloned the repo for zram setup.
Nvm, it’s there. Just didn’t have /sbin
in my zsh path…
Zram is a great addition and definitely has its place, and you just need to get a ups in case of power outages. You could even get an inexpensive Pi UPS card, which can last about 9-11 hours or so, depending on the model. If you go with the USB booting to ssd, (Here’s an article how to set it up… https://www.raspberrypi.org/documentation/hardware/raspberrypi/bootmodes/msd.md) you will have a very stable platform that will survive for years and will only have to worry about the your frequency of database writes - if you have that setup, which is not too difficult. I believe the default value is to write changes immediately, but you can check that in the …/openhab2/persistence/jdbc.persist file. If you go that route. So, the default setup would generally be ok.
For reference:
This thread is marked Solved but the discussion is related to my problem. Perhaps it should me moved to a different/new thread.
After a reboot and a couple of days the logging to openhab.log and events.log stops. The frontail frontend is empty part from headers showing events.log and openhab.log, there is no actual content. I will remember to take a screenshot at the next occurence.
I’m using the zram-feature and as I havent seen this behavior before I’m suspecting that zram is out of memory. But the openhab logging documentation does not describe how to change the logging preferences like size and number of logs.
The configuration file org.ops4j.pax.logging.cfg does not mention any log4j2.appender.out.strategy.max options. Only a size option is configured, defauilt seems to be 16M. I have tried to change this to 8M but logging still stops.
I think the openhab docs should be updated to also descibe this logging adjustments in size and rotation.
Luckily only the logging related to /opt/zram/zram2/ seems to be affected. All my persistence data such as rrd4j is still complete and persistence resides in /opt/zram/zram1/ as I understand it.
I have logged the zram memory usage daily, please see below:
2020-04-23 08:42:45
NAME ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT
/dev/zram2 lzo 500M 95,6M 21,6M 23,1M 4 /opt/zram/zram2
/dev/zram1 lz4 600M 42,8M 9,2M 10,2M 4 /opt/zram/zram1
/dev/zram0 lz4 600M 16,6M 7,6M 8,6M 4 [SWAP]
2020-04-24 10:50:54
/dev/zram2 lzo 500M 277,8M 70M 73,7M 4 /opt/zram/zram2
/dev/zram1 lz4 600M 47,1M 10,5M 11,7M 4 /opt/zram/zram1
/dev/zram0 lz4 600M 32,6M 14,5M 15,6M 4 [SWAP]
2020-04-26 08:54:31
/dev/zram2 lzo 500M 453,9M 108,8M 113,6M 4 /opt/zram/zram2
/dev/zram1 lz4 600M 59,3M 13,7M 14,6M 4 /opt/zram/zram1
/dev/zram0 lz4 600M 213,1M 73,7M 77,6M 4 [SWAP]
2020-04-27 16:29:11
/dev/zram2 lzo 500M 453,9M 108,6M 113,4M 4 /opt/zram/zram2
/dev/zram1 lz4 600M 60M 14M 14,9M 4 /opt/zram/zram1
/dev/zram0 lz4 600M 204,7M 71,5M 75,8M 4 [SWAP]
2020-04-28 08:00:02
/dev/zram2 lzo 500M 453,9M 109,1M 114M 4 /opt/zram/zram2
/dev/zram0 lz4 600M 203,9M 71,4M 75,2M 4 [SWAP]
2020-04-28 08:51:23
/dev/zram2 lzo 500M 40,3M 6,6M 7,2M 4 /opt/zram/zram2
/dev/zram1 lz4 600M 22,8M 1,9M 2,4M 4 /opt/zram/zram1
/dev/zram0 lz4 600M 4K 76B 4K 4 [SWAP]
2020-04-29 08:00:01
/dev/zram2 lzo 500M 82,3M 19,1M 20,3M 4 /opt/zram/zram2
/dev/zram1 lz4 600M 41,3M 8,9M 9,8M 4 /opt/zram/zram1
/dev/zram0 lz4 600M 12,9M 5,8M 6,5M 4 [SWAP]
2020-04-30 08:00:01
/dev/zram2 lzo 500M 108,4M 26,2M 28M 4 /opt/zram/zram2
/dev/zram1 lz4 600M 51,7M 11,7M 12,6M 4 /opt/zram/zram1
/dev/zram0 lz4 600M 23,6M 10,6M 11,5M 4 [SWAP]
2020-05-01 08:00:01
/dev/zram2 lzo 500M 366,5M 91,5M 96M 4 /opt/zram/zram2
/dev/zram1 lz4 600M 55,8M 12,7M 13,7M 4 /opt/zram/zram1
/dev/zram0 lz4 600M 71,3M 29M 30,7M 4 [SWAP]
2020-05-02 08:00:02
/dev/zram2 lzo 500M 455,1M 112,2M 117,2M 4 /opt/zram/zram2
/dev/zram1 lz4 600M 57,8M 13,4M 14,2M 4 /opt/zram/zram1
/dev/zram0 lz4 600M 226M 79,4M 84,4M 4 [SWAP]
2020-05-03 08:00:01
/dev/zram1 lz4 600M 59,8M 14M 15M 4 /opt/zram/zram1
/dev/zram0 lz4 600M 198,5M 72M 76,4M 4 [SWAP]
2020-05-03 09:50:17
/dev/zram2 lzo 500M 44,1M 6,6M 7,3M 4 /opt/zram/zram2
/dev/zram1 lz4 600M 22M 1,9M 2,4M 4 /opt/zram/zram1
I did at reboot on the 28th of april and on the 3rd of may.
The data usage of zram2 is quite close to the available disksize but its not exceeding it. But is this the problem?
Some background:
Rapbian-buster
openhab install though apt-get (openHAB 2.5.3-1)
openhabian install through apt-get ([master]v1.5-552(869c2ea))
zram feature install though openhabian-config
Is there a need to do a periodic reboot or a zram-stop/start to write data to disc? Or should it work continuously if I set the logging size to something more appropriate?
Thanks!
Search the forum for pax.logging to find out how you can tune OH logging and separate that issue from ZRAM.
I don’t think so because while the uncompressed size is close, the relevant, compressed size (TOTAL
column, to be precise) is not.
No (although that should not hurt).
Are you sure logging just simply stops ?
Check if logrotate is in operation (see /etc/logrotate.d/zram-config
Also check if the rotate target dir has sufficient space to rotate there.
It’s on SD and not meant to provide space for hundreds of MBs. You should reduce your loglevel.
Is your ZRAM install up to date ? It does not get updated when openhabian-config updates.
Compare /usr/local/bin/zram-config with latest in repo
Eventually uninstall and reinstall ZRAM.
Will search for logging topics. But still, shouldn’t this information be a part of the documentation. Or perhaps useful topics could be added as reference links in the “zram status” thread.
Ok, see below. It seems to be in operation.
/usr/local/share/zram-config/log/zram-config.log
rotate 4
weekly
missingok
notifempty
compress
delaycompress
sharedscripts
Regarding sufficient space, I should be ok I guess. This is the summary after a reboot:
## Memory = Free: 0.04GB (4%), Used: 0.91GB (96%), Total: 0.95GB ## Swap = Free: 0.67GB (99%), Used: 0.00GB (1%), Total: 0.68GB ## Root = Free: 9.32GB (70%), Used: 3.99GB (30%), Total: 13.91GB
Yes noted. I´ve been thinking of doing this anyway. There is way to much activity in the events.log.
Hmm, how to get the version number/date… The local zram-config has a modification date saying 31th of march and the latest update on the git was done three days ago so, there has been adjustments, its not up-to-date.
Will update and come back with feedback weather or not the issue persists.
Thanks again!
Gather the information and make a PR on the official docs page on loggin if you think it is.
That a loglevel will not reduce.
Well actually changing the loglevel of smarthome.event.ItemStateChangedEvent to WARN from INFO made a huge difference. But I feel I lost a bit too much.
I will have to adjust the logging size and and rotation. Will need to do some reading.
I’m fetching a lot data from the Fronius solar inverter every 5 and 30 seconds so that’s why there is so much activity in the event log.
Edit:
A lightbulb appeared!
The discs adds up to 1.2 Gb, I’m using the Pi 3b with only 1 Gb of RAM. My earlier reply showed a 96 % usage of the memory and this was after a reboot.
I really thought that the openhabian and zram feature expected a 1 Gb memory Pi as the default choice of platforms. Is this the source of my problems? If that’s the case what disc sizes are recommended for the 1 Gb version?
Ok, an update to the issue.
As I reduced the logging enormously by going from INFO to WARN for the ItemStateChangedEvent-occurrences I expected a significant prolonged delay in when to expect a full zram disc. But now it seems to be full again.
Please see below some data from the last week.
2020-05-03 08:00:01
2020-05-03 09:50:17
2020-05-04 08:00:02
/dev/zram2 lzo 500M 60,6M 11,9M 12,8M 4 /opt/zram/zram2
/dev/zram1 lz4 600M 35,8M 7,3M 8,1M 4 /opt/zram/zram1
/dev/zram0 lz4 600M 9M 3,6M 4,2M 4 [SWAP]
2020-05-05 08:00:01
/dev/zram2 lzo 500M 77,1M 16,1M 17,2M 4 /opt/zram/zram2
/dev/zram1 lz4 600M 46,4M 10,2M 11M 4 /opt/zram/zram1
/dev/zram0 lz4 600M 16,4M 7,4M 8,2M 4 [SWAP]
2020-05-06 08:00:01
/dev/zram2 lzo 500M 86,8M 19,6M 20,9M 4 /opt/zram/zram2
/dev/zram1 lz4 600M 51M 11,4M 12,4M 4 /opt/zram/zram1
/dev/zram0 lz4 600M 36M 15,5M 16,6M 4 [SWAP]
2020-05-07 08:00:01
/dev/zram2 lzo 500M 262,3M 64,4M 67,9M 4 /opt/zram/zram2
/dev/zram1 lz4 600M 53M 11,9M 12,8M 4 /opt/zram/zram1
/dev/zram0 lz4 600M 126,3M 47,1M 49,7M 4 [SWAP]
2020-05-08 08:00:01
/dev/zram2 lzo 500M 341,4M 80,3M 85,6M 4 /opt/zram/zram2
/dev/zram1 lz4 600M 58,5M 13,4M 14,2M 4 /opt/zram/zram1
/dev/zram0 lz4 600M 158,7M 59,2M 62,4M 4 [SWAP]
2020-05-09 08:00:02
/dev/zram2 lzo 500M 469,2M 112,7M 118,9M 4 /opt/zram/zram2
/dev/zram1 lz4 600M 60,3M 13,9M 14,8M 4 /opt/zram/zram1
/dev/zram0 lz4 600M 186,6M 69,1M 73M 4 [SWAP]
2020-05-10 08:00:01
/dev/zram2 lzo 500M 469,2M 112,6M 117,7M 4 /opt/zram/zram2
/dev/zram1 lz4 600M 64,9M 15,1M 16M 4 /opt/zram/zram1
/dev/zram0 lz4 600M 227,3M 80,4M 84,9M 4 [SWAP]
Also a disk usage output for the zram2 disc:
[10:46:30] pi@myhabpi:/opt/zram$ sudo du zram2/ -lh
16K zram2/lost+found
4,0K zram2/workdir/work
8,0K zram2/workdir
32K zram2/upper/unattended-upgrades
68K zram2/upper/exim4
1,8M zram2/upper/openhab2
268K zram2/upper/amanda/amandad
8,0K zram2/upper/amanda/log.error
24K zram2/upper/amanda/server/myhabpi-complete
544K zram2/upper/amanda/server/openhab-dir
608K zram2/upper/amanda/server
88K zram2/upper/amanda/openhab-dir/oldlog
264K zram2/upper/amanda/openhab-dir
20K zram2/upper/amanda/client/myhabpi-complete
160K zram2/upper/amanda/client/openhab-dir
192K zram2/upper/amanda/client
1,4M zram2/upper/amanda
360M zram2/upper/journal/181de35982dd42109cd0a94f75909b10
36K zram2/upper/apt
84K zram2/upper/grafana
612K zram2/upper/samba
458M zram2/upper
458M zram2/
[10:46:36] pi@myhabpi:/opt/zram$
And a screenshot showing the Frontail web interface for the period where the logging stopped.
I have not yet changed the log rotation preferences from the default ones. I have only done the INFO to WARN change as stated.
Also, I did a reinstall of the zram feature on the 3rd of may as recommended.
Adjusting the logging settings will not be effective in dealing with this issue as I now believe. What’s filling up the /zram2/upper/journal directory?
I don’t understand your post. If you want to know what’s filling up a dir then just read what’s in there.
It doesn’t happen in the default config. So noone but you (who modified logging and God knows what else) can know on your box.
Note there’s an upcoming change to ZRAM default deployments that you can apply as well.
Change /var/lib/openhab2
in /etc/ztab
to /var/lib/openhab2/persistence
, that’ll consume a lot less memory so you could eventually increase the limit for /var/log
Ok, I might have been vague in my post.
The thing is I don’t now whats filling up the journal directory. But this is then perhaps not an openhab or zram question
There is only one subdirectory in the journal folder and in that one there is only one file, see below:
/journal/181de35982dd42109cd0a94f75909b10/user-1000.journal
As I mentioned it seems to me that the problem is not really related to openhab logging size but I’m not sure. From my earlier post it can be seen that most of the content resides in the journal directory and not in the openhab one.
I haven’t done that many changes to the vanilla buster release. In addition to following the install steps presented in the openhab docs the only addition I can think of is the PiJuice software which is needed for my UPS-hat.
But for now I’ll look into whats filling up the journal directory. The file is binary but I’ll do some reading.
That’s the systemd journal service.
Does that mean you do NOT use openHABian ? Why didn’t you tell ?
That’s misleading, horribly annoying and a major pain to people willing to support if you don’t tell these basicmost facts upfront.
Migrate to openHABian if you want support.
The journal issue is also fixed in there along with many others.
I mentioned that fact in my first post from 7 days ago.
If there has been a journal fix that sounds very relevant to my problem, perhaps.
Do I need to do a migration also if I did the install through the apt-get strategy? Are there additinal tweeks in the “openhabian-image”-release compared to whats achieved by adding the openhabian package to the buster-release?
