Hello everyone, in sitemap it would be possible to use valuecolor with the status of an Item, example I have an Item temperature_set that can have values between 20 and 23, then I have an Item temperature_min with value temperature_set - 1.5 and temperature_max that is worth temperature_set + 1.5, my intent would be this,
Number temperature_min "min[%.1f]"
Number temperature_max "max[%.1f]"
Number temperature_vasca "vasca[%.1f]"
Number vc "vc[%s]"
Number dif "dif[%.1f]"
rule "tmp"
System started
temperature_min.postUpdate(18.5)
temperature_max.postUpdate(21.5)
temperature_vasca.postUpdate(18.4)
var i = 0
if (temperature_vasca.state < temperature_min.state as Number) {i = 1}
else if (temperature_vasca.state > temperature_max.state as Number) {i = 2}
vc.postUpdate(i)
dif.postUpdate(temperature_vasca.state as Number - ((temperature_min.state as Number + temperature_max.state as Number) /2))
sitemap tmp label="TMP" {
Text item=temperature_min
Text item=temperature_max
Text item=vc
Text item=temperature_vasca valuecolor=[vc==1="blue", vc==2="red"]
Text item=dif
Text item=temperature_vasca valuecolor=[dif < -1.5 = "blue", dif > 1.5 = "red"]
