[Solved] Variable declaration Rules file question
I’m loving this stuff. Can anyone see any issue with the below? I tried declaring the variable and setting it in the first rule (to grab the KWH at the start of the new day - I’m crazy about knowing the amount of energy I’m using). Although It doesn’t seem to be working - if I declare it in the rule the other rule doesn’t see it - but I recall reading the variables in the rules files are global between the rules in the file right?
here is what I have. In the morning though - It goes all “NULL” on me (or at least seemed to when I check the log). So I set it up top and just look at my zwave log and set it manually but that isn’t ideal going forward.
Thanks for any pointers!
var Number kwh = zwave_device_dcac0cb6_node2_meter_kwh.state
var Number total
var Number dailyC
var Number dailyKWH
var Number initialKWH
var Number price = 0.111
rule "Calculate Daily Charge"
	Time cron "0 0 0 * * ?"
	initialKWH = kwh
rule "Calculate Monthly Charge"
    Item zwave_device_dcac0cb6_node2_meter_kwh received update
    total = kwh * price
    dailyKWH = kwh - initialKWH
    dailyC = dailyKWH * price
    totalCost.postUpdate(total)
    dailyCost.postUpdate(dailyC)
    logInfo("RULE", "initialKWH: "+initialKWH)
    logInfo("RULE", "dailyKWH: "+dailyKWH)
Also - I realize I need to rename my rules - probably something like “get current KWH” and “Calculated costs”
“var Number kwh = zwave_device_dcac0cb6_node2_meter_kwh.state”
looks a bit fishy to me.
Maybe you could try to put it in a rule that is triggered by Startup, e.g.
var Number kph
rule "startup "
System started
kwh = zwave_device_dcac0cb6_node2_meter_kwh.state as DecimalType
Outside a rule is definitely not working.
Even more, maybe a simple startup rule won’t work reliable, because there is no guarantee that the item is initialized yet. But there is no need for this var, so, instead of initializing this var (after item has changed from uninitialized), use the state itself in the rules:
var Number total
var Number dailyC
var Number dailyKWH
    initialKWH = zwave_device_dcac0cb6_node2_meter_kwh.state as DecimalType
    total = (zwave_device_dcac0cb6_node2_meter_kwh.state as DecimalType) * price
    dailyKWH = (zwave_device_dcac0cb6_node2_meter_kwh.state as DecimalType) - initialKWH
    logInfo("RULE", "initialKWH: " + initialKWH.toString)
    logInfo("RULE", "dailyKWH: " + dailyKWH.toString)
You could even get one log line using this statement:
logInfo("RULE", "initialKWH: {}; dailyKWH: {}",initialKWH, dailyKWH)
I actually wrote a lengthy post before realizing I only “glanced” over your actual suggestion. Foolish me!
I’m going to try you’re approach - and I’m going to reset my cron timing to happen sooner than having to wait until midnight (I’m so not that patient!)
Appreciate the help with the rule - I’ll report back!
@Udo_Hartmann
Brilliant!! Works a treat - I can’t believe I didn’t catch on earlier. Just instantiate them above, then set them below.
Probably using the wrong words - I’m just starting with development but all is working well.
Thanks again!
