As mentioned in my first post, i have a working Velbus system where i am trying to add some extra funtions trough Openhab.
Therefore i found a example of creating a rule to set a switch on/off.
The only problem is that i don’t seem to get the example even working…
Maybe a little help could put me in the right way…
This is my example code:
rule "test"
Channel 'velbus:vmb6pbn:********:23:input#CH3' triggered PRESSED
if (OUT_STP.state == ON) {
OUT_STP.sendCommand(OFF)
if (OUT_STP.state == OFF) {
OUT_STP.sendCommand(ON)
End
In my test OUT_STP is a thing defined as a switch, which is connected to a relay-output of an Velbus Module.
I already managed to get the pressed command working ==> when i open the log from openhab and press that button, i see home.event.ChannelTriggeredEvent - velbus.vmb6pbn:******:23:input#CH3 triggered PRESSED
Any suggestions?
Many thanks and a happy New Year!
MDAR
(Stuart Hanlon, UK importer of Velbus hardware)
4
If you’re interested.
You can create the inverse rule to set the feedback led of the VMB6PBN
Correct LED states are
CLEAR_LED
SET_LED
SLOW_BLINK_LED
FAST_BLINK_LED
VERY_FAST_BLINK_LED
As mentioned here
You’ll need to add a Feedback_LED Item for button 3, but something like this will do the trick
rule "test Led feedback"
Item OUT_STP changed
Feedback_LED_23_3.sendCommand("SET_LED")
else {
Feedback_LED_23_3.sendCommand("CLEAR_LED")
Ok,
This is even getting better…
Works like a charm…
Where can i find these string commands?
I also have an onkyo connected and this way, i can use a velbus pb to control volume. Also maybe my harmony hub with connected stuff…
Many thanks
MDAR
6
Those of other bindings…
Like i said, for example the harmony binding.
MDAR
8
Arrrr
You’ll be needing a Harmony guru…
MDAR
9
Hey Ward,
One tiny thought.
To take into consideration ‘other’ states that your switch item might be in, for example null when first booted, this tiny change might be suitable
rule "test"
else {
