I have a couple of Aeotec nanometer 4 button remotes that I use as garage door controllers. They work just fine, as such. I glue them onto the back of the remote but I can’t find a clip that actually fits comfortably on the visor. They eventually pop off. Anyone else in a similar situation that might have an idea?
Check https://www.thingiverse.com/ and print your own
If you do not have a 3D printer many of these sites let you order an item printed by someone else.
I’ve done just this myself through Thingverse. The cost was much lower than expected and the print quality was excellent .
If I wanted something, I could convince my son. He made the case for my Pi.
Which one do you use?
If you print, make sure you use at least ABS filament. PLA will definitely deform or melt in the car
I used a guy who is local I found through Treatstock. I wanted to pick one close by that had good ratings. Luckily I found a guy in my city with five stars. I was very happy with the quality of the prints, the cost was lower than I expected, and the prints arrived much faster than expected.
To bring this thread to close, I settled on this:
Fits great.
