[SOLVED] VoiceCommand rules don't works
Tags: #<Tag:0x00007f74532345f0> #<Tag:0x00007f7453234488>
Hi.
Using OH 2.4 on RPi 3, I’m trying to test Voice Control from Android App but rule script seems NOT be triggered …
The event is correctly printed in the log:
2019-04-10 17:16:21.893 [ome.event.ItemCommandEvent] - Item 'VoiceCommand' received command test
… this is my voice.rules:
rule "Voice Control"
	Item VoiceCommand received command
	logInfo("VoiceCheck", receivedCommand)
… other info messages are printed in the log …
Any idea ?
Thanks.
IMHO logInfo needs two strings like:
logInfo("VoiceCommand","My received Comand: {}", receivedCommand)
I’ve tried two simple and static string, too … and neither your snippet works :frowning:
But … are there specific requirements for this scenario (for example a specific binding …) ?
OK, I’ve solved …
The reason it doesn’t work is that … VoiceCommand Item isn’t an implicit item (as I thought …) but must be declared (in a .items conf file …)
Glad you found a solution, but what exactly do you mean by " must be declared (in a .items conf file …)" ? I’m having the same issue
Ok Never mind, found it
Create an .items file containing “String VoiceCommand”
